Plastic Radiator Tanks. Are they worth it?
Old Sep 30, 2011 | 06:38 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Sup guys. I need some advice. Im low on money at the moment and Im thinking about buying the $130 radiator from Autozone or Orielly's strickly because my financial status. So im gonna post another thread with another topic to get the proper feedback.
So, is it worth buying a radiator with the plastic tanks?
Specs:
Row No1
Core Height26 1/4"
Core Width17 1/4"
Core Depth1 1/4"
Inlet Header2 3/8" x 18 5/8"
Outlet Header2 3/8" x 18 5/8"
Inlet1 5/16"Outlet1 9/16"
Engine Oil Cooler None
Transmission Oil Cooler11 1/2" (Concentric)
_________________________________________________________________
Orielly's
specs:
Plastic Tank/Aluminum Core
Fits Without Air Conditioning
With Heavy Duty Cooling
With Air Conditioning
Max Cooling
26-1/4 X 17-1/4 X 1
1 Row
They have Lifetime warranty.
Old Sep 30, 2011 | 08:52 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: Plastic Radiator Tanks. Are they worth it?
if they have the lifetime warrenty, it so go for it. if they ever crack you get it replaced for free, so no worries.
Old Sep 30, 2011 | 09:06 PM
Well my biggest worry is that these cheap radiators are 1 row. I live in 110* summers. So if anyone has experience with a 1 row radiator that is cooling a 350, does it help keep the temps down?
Old Oct 5, 2011 | 01:31 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
these single core aluminum/plastic are the same design/size as the factory equipment found in the mid/later 3rd gens (as opposed to the copper/brass found in the earlier models). should work fine in a stock application
Old Oct 5, 2011 | 03:41 PM
thanks for the feedback A1Dan.
Old Oct 7, 2011 | 07:19 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I've been using an OE replacement, from CarQuest (IIRC), for a number of years with no issues in my IROC. I've run it with both the old 305 and now with the 350/330.
JamesC
Old Oct 7, 2011 | 06:12 PM
Thanks for all the feedback guys (travis401, 1ADan, and JamesC). I said the heck with it and I purchased a all aluminum radiator 3 row for $220 from ebay. Ive read some good stuff here on the "Cooling" sticky. So Im gonna take my old radiator and to the junkyard and recycle the aluminum core.
http://cgi.ebay.com/ebaymotors/Chevy...item43a9fd96d8
Old Nov 10, 2011 | 09:40 PM
porkenstein's Avatar
Car: 91 RS Convertible
Engine: LSA
Transmission: 6060
Axle/Gears: 373
When did the Camaro's start using plastic tanks?
Old Nov 11, 2011 | 06:54 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
FWIW, both my 87 TA and my 89 RS had the aluminum/plastic setups.
Old Nov 11, 2011 | 06:57 AM
JamesC's Avatar
So'd my 85.
JamesC
Old Nov 11, 2011 | 06:30 PM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
3rd-gens used GM Harrison plastic/aluminum radiators right from the beginning in 1982. The aftermarket has made copper/brass replacement radiators for 3rd-gens.
My '82 and '84 T/As still have their original Harrison radiators and I've never had any problems with leaks. The '84 has almost 170K miles on it.
Bubbajones_ya
Jul 6, 2024 08:32 PM
Twin_Turbo
Mar 14, 2016 10:10 PM
gta892000
Sep 16, 2015 12:37 AM
Saxondale
Sep 15, 2015 06:42 PM
gteatr6
Interior Parts Wanted
Sep 10, 2015 09:55 PM
