Cooling problem? Or sensor?
Old Dec 11, 2011 | 11:28 PM
olveracm's Avatar
Car: 88 Firebird WS6 red
Engine: 305 TBI
Hey guys it's me again
I got a problem with my firebird again
When I start it, it starts fine and it idles fine. BUT when I run it on the freeway after it has been idling at 190-220 it starts to go up to 280
I don't think it over heats because I think the engine should turn off or atleast start acting funny but it doesn't.
I wanna know if there is some type of sensor.
I looked up on ALLDATA about the sensor and having low current resistance when HOT and having high resistance when COLD.
I don't know what sensors it could be but I do not think the engine is overheating.
Any thoughts?
Old Dec 12, 2011 | 08:17 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: Cooling problem? Or sensor?
Do you have a AIR DAM under your car?? Without one results in cooling problems.
Old Dec 12, 2011 | 11:14 AM
olveracm's Avatar
Engine: 305 TBI
I think it does, what is the purpose of that ?
Old Dec 12, 2011 | 12:16 PM
DJP87Z28's Avatar
Look under the car and see if you have one. Major part of the cooling system at speeds above 45 mph when your fans should be off.
Old Dec 12, 2011 | 01:18 PM
olveracm's Avatar
Engine: 305 TBI
Thanks I will check it out when I get home !
Old Dec 12, 2011 | 05:55 PM
olveracm's Avatar
Engine: 305 TBI
Old Dec 12, 2011 | 06:01 PM
olveracm's Avatar
Engine: 305 TBI
I don't think it has one.
Old Dec 12, 2011 | 07:04 PM
DJP87Z28's Avatar
Well you found your overheating problem.
Old Dec 13, 2011 | 06:42 PM
olveracm's Avatar
Engine: 305 TBI
thanks
Is it really that usefull?
Old Dec 13, 2011 | 07:12 PM
olveracm's Avatar
Engine: 305 TBI
ok so I have read here and yes it is
answered my own question /
thanks everyone!
Old Dec 13, 2011 | 07:18 PM
dredre08's Avatar
Car: 1986 Trans Am/1988 Camaro Iroc-Z
Engine: 305 TPI/350 TPI
thanks
Yea man i had the exact same problem youre having, overheating when i get on the highway but holds temp at idle and I refused to believe that a piece of plastic was causing my car to overheat despite the numerous times people have told me otherwise on this site.... I bought one and like magic my overheating problem vanished!!!!..... Get The Air Dam........
Old Dec 13, 2011 | 08:40 PM
olveracm's Avatar
Engine: 305 TBI
Haha wow that sucks
Well now I have to buy it
U know of any good places that might sell it?
are NAPA or Autozone not included since it is a body shop?
Old Dec 13, 2011 | 09:53 PM
dredre08's Avatar
Im pretty sure autozone or Napa doesnst sell them, I got mine off ebay for like 50 bucks, but I think hawks and thirdgen ranch sells them as well....
Old Dec 14, 2011 | 06:16 AM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Third gen ranch has them for like $30 shipped. But MAN your radiator support is rusty O.O wow!!
Old Dec 14, 2011 | 05:42 PM
olveracm's Avatar
Engine: 305 TBI
Oooh alright thanks!
And evilemokid94 I know, You think it will still support it?
Old Dec 14, 2011 | 06:55 PM
olveracm's Avatar
Engine: 305 TBI
http://www.ebay.com/itm/82-92-CAMARO...53#ht_226wt_65
Will this one work guys?
Old Dec 14, 2011 | 08:36 PM
Mrs.Crasher0083's Avatar
Car: 88 Pontiac GTA and 4 Camaros
Engine: 5.7
Trust what everybody says about the airdam!!!!! Everything you described sounded like a bad/no airdam. The pic proved it all. You NEED that and your problem will be solved.
Old Dec 15, 2011 | 05:14 AM
Engine: L31 350
Yes the one you posted will work
Old Dec 15, 2011 | 02:08 PM
olveracm's Avatar
Engine: 305 TBI
Thanks!
Old Jan 14, 2012 | 03:14 AM
olveracm's Avatar
Engine: 305 TBI
Hey guys just got the air dam on Wednesday.. What I guys think about it.
Old Jan 14, 2012 | 03:17 AM
olveracm's Avatar
Engine: 305 TBI
Is it big enough?
Old Jan 14, 2012 | 06:30 PM
dredre08's Avatar
Looks good!, did it fix your overheating problem?
Old Jan 14, 2012 | 06:35 PM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
Looks good, Let us know if it fixed your problem. After I put mine on it stopped over heating
Old Jan 14, 2012 | 11:22 PM
olveracm's Avatar
Engine: 305 TBI
Alright just making sure it's not to small..
And I wish I could tell you but it snowed the day I put it one (how ironic) and now I'm waiting for it to clear up.
I will let u guys know ASAP as soon as a drive again in the freeway.
Old Jan 15, 2012 | 09:36 AM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
the airdam doesnt "scoop" air and force it through the radiator. it creates a low pressure zone that sucks air up into the radiator behind it. there have been a few people that actually trimmed down the stock airdam for ground clearance and i dont belive they had any problems. so if its a stock airdam from a 3rd gen f body, no its not too small .
on a side note, the air dam is actually MORE important on the birds, just for the fact they have less air flow comming in from the front of the car than the camaros (they dont have a grill opening after all).
Old Jan 15, 2012 | 10:33 AM
olveracm's Avatar
Engine: 305 TBI
"no its not too small ." <-- Haha
But ooh here i thought it did scoop up air. Hmm.. Thanks!
"MORE important on the birds, just for the fact they have less air flow comming in from the front of the car (they dont have a grill opening after all)." <--- yeah I figured that out my self.. Cause yeah there is no grill. But I wanna drive it soon.
Old Jan 16, 2012 | 10:31 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Originally Posted by travis401
the airdam doesnt "scoop" air and force it through the radiator. it creates a low pressure zone that sucks air up into the radiator behind it. .
To add, the baffling/ducting under the nose works in conjunction with the air dam to draw air through the radiator.
The baffle works similar to an upside down airplane wing.
51 & 52 vary on base or t/a. The air dam you bought appears to be the center section to a Camaro (T/A is very similar)
104 (L & R) are the side pieces to 51 for t/a
49 & 50 are the baffle parts under the nose
Old Jan 17, 2012 | 10:33 PM
olveracm's Avatar
Engine: 305 TBI
yeah Thats true..
But i still have left to try to drive it.
Old Jan 28, 2012 | 06:42 PM
olveracm's Avatar
Engine: 305 TBI
well, so today i finally got the bird on the highway.. uhhhh.. it reached 220 degrees. or so, (almost 220) uhhhh... eventually when we got off the freeway, it reached the 3/4 of the guage.. seems to be a little better, because last time it hit red line or what ever that # is. uhhhh.. HELP! i think that if we stayed on the freeway, it would have gone higher..
Old Feb 1, 2012 | 11:59 PM
deadbird's Avatar
Engine: TPI 305/ v6
check to make sure the is no garbage between your radiator and condenser. make sure the condenser fins are mostly straight.
A 305 TBI is almost to weak to produce enough HP to make it run hot if it didn't even have a radiator. If the air dam didn't help, there is something else blocking the air flow past the radiator.
Old Feb 8, 2012 | 01:11 PM
olveracm's Avatar
Engine: 305 TBI
Thanks deadbird i did figure it out.. it was the timming.. it was way off.. the engine used to sound sloppy and now it sounds realy smooth..
only problem is that when i get on the freeway it went over to 220 and then almost over heated and then after like 2 mins it dropped down to 1/4 of the guage..
you think it's the collant?
how much should i get if i need a whole system flush??
Old Feb 8, 2012 | 06:59 PM
travis401's Avatar
Car: 91 Camaro RS
sounds like the tstat may have gotten stuck closed until it heated up to 220 then opened.
Old Feb 8, 2012 | 10:58 PM
olveracm's Avatar
Engine: 305 TBI
Yeah the thing it that it's new.. I don't know how or what I'm gonna do a whole coolant flush tomorow and change the coolant tempature switch tomorrow.
Old Feb 9, 2012 | 09:40 AM
travis401's Avatar
Car: 91 Camaro RS
new parts can be bad too...
Old Feb 9, 2012 | 10:24 PM
deadbird's Avatar
Engine: TPI 305/ v6
+10
Old Feb 10, 2012 | 10:15 AM
olveracm's Avatar
Engine: 305 TBI
Originally Posted by deadbird
+10
Alright well it was the coolant.. I did the flush and it worked just fine..
It didn't over heat on the street and on the freeway.. It seemed to work.. but it was running cool. which is fine cause before it was running really hot!
db057
Sep 4, 2015 07:57 AM
soarestransam
Aug 24, 2015 08:15 AM
Bert87
Aug 23, 2015 03:50 PM
92camaroJoe
Aug 13, 2015 06:07 AM
