Engine temp sensor reading different from CTS
Old Mar 15, 2012 | 10:30 AM
insomniac's Avatar
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
91 SD L98
So here is my situation. My fans wont come on. The ECM is programmed to ground the relay at 222 degrees. Now the engine temp guage is going above 222 but the Coolant Temp Sensor is only reading around 190 at that point.
Could I just have an air pocket by the CTS or do you think it is a bad sensor?
Since the CTS isnt reading 222 the fans wont come on.
Old Mar 15, 2012 | 03:02 PM
Cosmik Debris's Avatar
Re: Engine temp sensor reading different from CTS
The temp gauge and its sensor are sometimes not that accurate. Have you measured the actual temp with something more accurate?
Old Mar 15, 2012 | 03:05 PM
insomniac's Avatar
Engine: 5.7 L98
well icould put a pyrometer on it, but where would be the best place to take that reading?
Old Mar 15, 2012 | 04:06 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
u can try the thermo housing neck. those stock gauges are not very accurate.
Old Mar 16, 2012 | 10:04 PM
Mr Froman's Avatar
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
Upper rad hose or use a multimeter and measure the resistance of the coolant temp sensor (below the t-stat).
Old Mar 18, 2012 | 12:34 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
91 SD L98
The gauge sender is also in the head, between two exhaust ports, a considerably hotter part of the motor. You can expect a bit of disparity between the temperature gauge and ECM reading.
Old Mar 18, 2012 | 03:52 PM
ninetyone's Avatar
Axle/Gears: 3:42
how are u measuring the temp that the cts is seeing? a scanner,laptop?
Old Mar 18, 2012 | 03:53 PM
insomniac's Avatar
Engine: 5.7 L98
snap on scanner
Old Mar 22, 2012 | 12:04 PM
Agent319's Avatar
Car: 1989 Camaro IROC Z
Transmission: Automatic
Axle/Gears: Haven't checked
What parts of the sensor do I hook my multimeter to? Unhooked sensor to ground? Unhooked sensor to sensor wire lead?
Old Mar 23, 2012 | 09:47 AM
Agent319's Avatar
If the CTS is in a considerably cooler spot of the motor than the Temperature gauge sending unit how about changing positions. Put the CTS in the Temperature gauge sensor location and visa versa?
Old Mar 23, 2012 | 04:21 PM
deadbird's Avatar
Engine: TPI 305/ v6
I don't think you'd want the ECM seeing the engine temp as higher than what it's actually running, just for the sake of the gauge to read lower.
eightsixseven
Dec 16, 2024 01:50 PM
specialized
Jun 18, 2022 09:26 AM
bamaboy0323
Aug 15, 2015 07:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
mizz0313
Aug 12, 2015 06:45 AM
