Adding a Heatercore bypass valve?
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
How hard would it be to add a heater core bypass valve? Iv been wondering this but since I got my ac working yesterday I want it to be as cool as possible. I'm looking more towards the factory setup like on the 90s where it was controller by vacuum
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: Adding a Heatercore bypass valve?
You could do that, how is that one controlled? Is there a vacuum switch inside the car?
Engine: L31 350
I couldn't tell you honestly. I remember it having two ports on it for coolent lines and a vacuum port in the top that you plugged a hard vacuum line on
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
I was going to do the same thing. Ended up buying a $4 ball valve from lowes, sprayed it black, and put it in the hose. Cheaper and cleaner IMO. Only thing is I have to pop the hood to get the heat if I want it. Takes all of 15 seconds to do though.
Engine: L31 350
That's why I like the idea of the stock bypass on the older cars. I think it opened up as you moved the lever to heat
Car: 88 IROC
I am going to look at the possibility of hooking a choke cable up to it. Not really worried about that right now.
I know some older vehicles had a similiar setup. I know 69 F100s had a manual valve on the heater core that worked off a cable connected to the HVAC controls.
My problem with the factory unit is the extra ports.
Car: 91 firebird Formula 350
Transmission: N/A, working on a t5 swap
Axle/Gears: 3.73 posi
I'd really like to see a picture of where that ball valve is, and how you did it. it completely cuts off flow to the heater core?
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
(OOPS, just noticed the old post...
)Bit of a misnomer... The bypass valve allows coolant through the core anytime the heat control lever is not in full COLD. Used to have to keep the temp lever in full COLD to keep the heater from burning my feet during the summer (no working temp control door). And yes, it's controlled by a secondary vacuum switch that is actuated by the temp control lever, on the bottom of the control head. That's why the vacuum system has 2 black vac lines, one is vacuum inlet and the other is heat control.
Anyways, the ball valve would be quite simple... Get 2 intake coolant hose ports and one 1/2" ball valve. Put the ports in the valve, put the valve in one of the lines running to the heater core pipe running down the frame rail, and you're done...
Car: 88 IROC
Just do what was mentioned in a post or two above, cut one of the lines going to the heater core, insert ball valve. It is really that simple. Put it where you want to put it that you can easily get to it.
Car: 88 IROC
No.
More like this.
Just run the coolant lines cleaner and closer to the crease between the intake and the valve cover. I have the valve roughly above the #4 cylinder.
More like this.
355tpipickup
Sep 13, 2015 11:35 PM
