what type sealant for t-stat water neck?
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
does it really matter what type sealant i use on the t-stat water neck? i don't even have 100 miles on this top-end rebuild and am already having to reseal it. granted, the surfaces ain't perfect anymore, so in addition to the gasket, i use sealant on both sides of it to compensate for the pits, etc. in the mounting surfaces. i think i used the black rtv last time and the gasket i use also has an integrated "o-ring" type seal in it, so should help seal a little more. if someone knows a more reliable sealant, please advise. thx, as always.
- keith
- keith
Re: what type sealant for t-stat water neck?
- keith
- keith
I've found that putting the parts together only finger tight and waiting about an hour before final torque goes a long way towards a leak free seal. Some manufacturers list that as their standard procedure.
We've also been experimenting with Permatex' "The Right Stuff" with very good results. It's said that you can forgoe the hour wait with this newer product too.
Go to the parts store and buy a new cast-iron water outlet, and throw that stupid stock chinesium one in the trash.
Car: '91 Z28
Axle/Gears: 323's
sounds good to all... for now will try the re-seal effort but if it happens again in the (too) near future, then will go for the replacement. thx...
- keith
- keith
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
I use permatex gasket maker on just about everything especially water stuff. I used it to adhere my taurus fan to my radiator and it is STUCK.
Car: 83 Camaro Z28 (CFI)
Engine: 305 V8 (CFI)
http://shop.advanceautoparts.com/web...hTerm=permatex
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
I payed $10.00 for mine a few years back.(Fel-Pro)
