electric water pump?
Old Apr 10, 2016 | 04:26 PM
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
anyone run an electric water pump or know someone who does? any recommendations? I'm thinking about going with one, I plan to run it off of a relay, and piggyback the relay on the fuel pump relay circuit so that anytime the fuel pump is running, so is the water pump. thoughts?
Old Apr 10, 2016 | 04:45 PM
BOTTLEDZ28's Avatar
Transmission: A4
Re: electric water pump?
I ran an electric water pump for a few years on a 383 HSR 10:1 engine and had no issues at all. It was a daily driver too. It was wired to a switched 12V source in the fuse panel using the supplied harness and relay.
Old Apr 10, 2016 | 04:52 PM
ericjon262's Avatar
do you remember who made the pump?
Old Apr 10, 2016 | 05:01 PM
WickedBowtie's Avatar
Car: 1989 Camaro RS
Engine: 383
Transmission: TH400
Axle/Gears: 9 inch, 35 spline drag spool,4.56
I run a summit brand on my car. I have it on a switched 12v circuit. I have not had any issues yet.
Old Apr 10, 2016 | 05:02 PM
BOTTLEDZ28's Avatar
Transmission: A4
Proform pump from Summit
Old Apr 10, 2016 | 05:32 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
you can get them in a few diff colors,,or chrome..
Old Apr 10, 2016 | 05:39 PM
BOTTLEDZ28's Avatar
Transmission: A4
I ran that same exact belt/bracket setup on my last car along with the Proform water pump. It worked well for me.
Old Apr 10, 2016 | 08:11 PM
this set up is temp..till the V1 T trim is bolted on and set up.
Old Apr 10, 2016 | 08:32 PM
heat seeker's Avatar
Car: 89 Formula
Engine: 383 SBC/HSR
I've run this one in my car for a year and have loved it. Low profile and flows 55gpm. I've run two meziere pumps and had problems. Wired it to my ignition and also included and override toggle switch.
http://www.summitracing.com/parts/sum-314350
91banditt2
Aug 11, 2021 10:54 AM
ars2pd
Apr 12, 2016 01:33 PM
Albani
Apr 11, 2016 11:02 AM
martindforsythe
Apr 10, 2016 03:54 PM
fred81292
Apr 10, 2016 12:43 PM
