Water Pump installation
Old May 8, 2018 | 09:29 PM
SBNJ84Z28's Avatar
Car: 84 Camaro Z28
Engine: 305HO
Transmission: 5 Spd
Axle/Gears: 373 Gears
OK guys, looks like I need a new water pump. I just ordered one from Summit. Question.. what do I need to do to flush all the fluids out before dropping the old water pump? Also, how many gallons of fluid to refill? Should I also do a flush after I drain the fluids?
Old May 8, 2018 | 10:40 PM
Jp's camaro's Avatar
Car: 1991 rs, 1985 z28
Engine: 3.1 v6, 305 tpi
Transmission: 700r4, 700r4
Axle/Gears: 3.23, 3.23
Re: Water Pump installation
Just drain the fluids then flush the system if you want. I believe its like 4 gallons
Old May 9, 2018 | 05:24 AM
SBNJ84Z28's Avatar
Car: 84 Camaro Z28
Engine: 305HO
Transmission: 5 Spd
I've never done this before how do i drop all the fluids?
Old May 9, 2018 | 08:15 AM
There is a plug towards the bottom of the radiator on the passenger side, unscrew it and that will drain all the coolant in the radiator. To get the coolant out of the block you can unscrew a coolant sensor and it will drain out of that
Old May 9, 2018 | 09:39 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Pull the lower radiator hose off, it will drain most of it. Has to come off anyway.
Old May 9, 2018 | 09:41 AM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
If you're not going to use the 50/50 pre mixed coolant, don't forget to use distilled water and not regular water from the hose to prevent a lot of mineral build up over time.
Old May 9, 2018 | 04:02 PM
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
Old May 9, 2018 | 04:15 PM
MY87LT's Avatar
Car: 1987 Camaro LT
ChrisFix has some really good videos. I'm actually using the one where he paints his Honda's valve cover and follow the steps to paint my valve covers this weekend.
calgutie
Sep 2, 2012 10:45 AM
Nate86
Apr 10, 2005 08:12 PM
steriko
Jan 10, 2005 12:44 PM
383backinblack
Fabrication
Aug 13, 2004 02:21 PM
383backinblack
Jan 13, 2004 06:38 PM
