Engine Oil Cooler
Engine Oil Cooler
I put my car on a lift yesterday to adjust the emergency brake cable and found that the engine oil cooler is just sitting in front of my radiator. The thing is not even bolted or held down by any fasteners. Who does this crap?! This led me to look further into the cooling system and i found some weird things. I attached a picture that shows the hoses run to the radiator ... again, who does this crap!?! I need your help!
1. Where is the cooler supposed to be mounted in the radiator area
2.This oil lines are obviously not stock, what are they supposed to be attached to?
Does anyone have pictures of the stock setup and where i can attain to hardware to mount this properly?
Thank you,
James
Thank you,
James
Re: Engine Oil Cooler
That's not an engine oil cooler, that is a transmission oil cooler. Someone did this exact thing in you pictures to my GTA a few years ago and when I bought it last year, it was leaking bad. I ripped the whole thing out and reconnected the hard lines to the cooler as it was from the factory. I would also be interested in a GOOD way to install a transmission oil cooler...
Received 1,672 Likes
That's not engine oil. It's an add-on aftermarket transmission fluid cooler.
They come with basically tie-wraps to hold them on. Pretty weenie usually.
Car: 90 Formula 350
Axle/Gears: Dana 44 3.54
That looks like its a supplement trans cooler not engine oil cooler, cars with oil cooler have coolant running to them Ala "sandwich style" between oil filter and the block. And to answer your question of who does this?-Lazy people
That looks like dog crap.
That isnt factory, is it?
Note that the steel line hooked to the rubber line has a threaded thing on it.
Note that the other one, that appears to sort of hook to the radiator, is actually hooked to a part that threads into the radiator.
Remove the part from the radiator that the hose is hooked to, leaving behind the part that looks green. Remove the hose from the steel line.
Note that the fitting - the threaded thing on the steel line - now exposed, will screw right directly back into the hole that you just made in the radiator, that it came from.
That was how it came, factory.
Great! I don't mean to sound like an idiot and although I am by no means a mechanic, I'm giving it a good effort.
I guess i should clarify the "Is this factory? question" .. I LOOKED at the hoses and "i realize that the shade tree hoses aren't factory" which raises my factory question - Do guys believe that if it was factory at some point, some knucklehead removed the proper fittings and brackets and did this? If so, where can i get the proper fittings to reconnect these lines appropriately? If not, should I just remove the whole cooler? I haven't had any transmission issues since I've had the car.
I appreciate the advise not the sarcasm.
James
James
Axle/Gears: 10 Bolt 2.73 Open
The kits are generic. No brackets, just some ziptie retainers as sofa mentioned. You're not missing anything. If you want to keep it, work on a better installation. Otherwise, ditch it and put it back the way it was made.
Or..... here's my setup (I don't use the cooler in the radiator):
I have two coolers there - the finned extruded black aluminum tube, and the more conventional B&M super cooler. They are looped together. My trans temps haven't exceeded 170 degrees and usually run 150. Typical stock cooler trans temps are likely closer to 250 with the coolant temp being managed around 225.
GD
Zantasmo
03-10-2019 07:48 PM
geehumshriber
07-09-2007 09:00 PM
Stormshadow GTA
04-26-2001 06:24 PM
