4th Ten Coolant Mod With Driver Side Battery?
Old Jul 6, 2020 | 05:26 PM
thainglo's Avatar
Has anyone done this? I am in the process of finishing my serpentine conversion on on my 85 with a complete setup from my 88 parts car. I see lots of pics and info with using the 4th gen bottle on the passenger side as it acts as a battery tray. Was initially planning to go that route but now ruining i will put the battery on the driver side, similar to the 88 setup. Keeps battery closer to alternator and I have the complete wiring harness.
looking for ideas and thoughts.
Thanks!
Old Jul 9, 2020 | 09:25 AM
zman1969's Avatar
Car: 90 Formula 350
Axle/Gears: Dana 44 3.54
Re: 4th Ten Coolant Mod With Driver Side Battery?
you would need to relocate your air filter and evap canister to install on pass side
Old Jul 9, 2020 | 08:50 PM
NoEmissions84TA's Avatar
He could move the evap canister to the underside of the driver's side battery tray.
Old Jul 9, 2020 | 08:55 PM
TJQIROC's Avatar
Car: '16 Camaro SS, '88 IROC
Engine: 6.2 Gen V
Transmission: 6 spd TR6060
Isn't that where the vacuum ball is located?
Old Jul 9, 2020 | 09:32 PM
Not on my 84 T/A. I suggested it because it's just an easy flip - IF there already isn't something occupying that real estate.
Old Jul 9, 2020 | 09:57 PM
TJQIROC's Avatar
Engine: 6.2 Gen V
Oh, my mistake. My 88 had the ball under there.
Old Jul 9, 2020 | 10:06 PM
TJQIROC's Avatar
Engine: 6.2 Gen V
Thanks!
Adding the 4th gen coolant AND washer tank really cleans up to look. I would recommend it highly. Many posts on doing it including myself.
Old Jul 12, 2020 | 02:47 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
https://www.thirdgen.org/forums/auto...en-washer.html
Old Jul 12, 2020 | 04:14 PM
thainglo's Avatar
Thanks for the link! That is the only example i could find with the coolant bottle being installed on the driver side. Looks like it can be done!
Old Jul 13, 2020 | 09:04 AM
85Z28NOS's Avatar
Car: 85 Camaro
Engine: 454 RamJet
Transmission: LT1/T56
Axle/Gears: 8.8w/4.10
Old Jul 17, 2020 | 07:37 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Or just mount it under the pass tray.
Ct1987
Jul 12, 2020 07:25 PM
MustangEater82
May 28, 2015 11:17 PM
jpearsall187
Dec 13, 2011 09:16 PM
DARKmj16
Fabrication
Oct 19, 2010 12:58 PM
Rich2279
Fabrication
Sep 22, 2008 08:43 PM
