Oil Cooler
Old Aug 24, 2021 | 05:46 PM
allos's Avatar
Car: 89 GTA, 84 T/A
Engine: L98 stock, Carbed 350
Oil Cooler
I picked up a Vortec 350 to put in my 84.
It has this oil cooler attached to it, from what I can find it was designed to run to a cooler in the radiator, like the transmission lines do.
Does anyone know much about these units?
Is there a thermostatic valve built in, or did it just rely on running through a warm radiator to ensure it didn't get the oil to cold?
Does this unit have any advantage to a cheap sandwich adapter?
I wouldn't mind running it to an external cooler, but don't really want to mess with having to plumb a valve.
Thank you.
Old Aug 24, 2021 | 11:12 PM
dixiebandit69's Avatar
Car: '89 Firebird Formula
Engine: TBI 305
Axle/Gears: 10-bolt, 3.42s, Torsen diff.
Re: Oil Cooler
To the best of my knowledge, there is no thermostatic valve in that unit, it just goes to the radiator.
You could run the lines to an air/ oil cooler if you wanted; GM has done it before.
Old Aug 25, 2021 | 01:23 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Re: Oil Cooler
If I recall they leak a lot!
Some 3rd gwens had oil coolers that went to the radiator...perhaps you can find a radiator and plumb like stock?
Old Aug 25, 2021 | 07:30 PM
allos's Avatar
Car: 89 GTA, 84 T/A
Re: Oil Cooler
I did see a radiator GM 21466 that has the cooler, but it is 250, and my radiator is only about a year old.
jamesv
May 21, 2019 01:42 AM
-=Z28=-
Apr 14, 2017 07:47 PM
89IRO
Aug 7, 2004 10:13 PM
88305tpiT/A
Dec 22, 2002 09:31 PM
86IROCZ
Apr 10, 2002 11:32 PM
