How radiator fans are controlled?
Old Jul 1, 2025 | 12:55 PM
Jlands's Avatar
Hello,
Can someone .... that knows for sure 100%.... explain how the stock dual fans are controlled on a 1990 5.7 iroc z? I have searched the threads and i am seeing mixed answers. I would like to know the easiest way to make both fans come on earlier.
Thanks.
Old Jul 1, 2025 | 01:37 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: How radiator fans are controlled?
The easiest way to get them both to come on earlier is change the settings in the ecms prom on/offs. The secondary fan can be controlled by the ecm if you tap the green/white wire from the primary fan to the secondary relay.
primary is ecm controlled secondary is a/c request or temp head switch. Wells sw555 head switch is another option for secondary fan.
Old Jul 1, 2025 | 02:32 PM
BHR's Avatar
BHR
Originally Posted by Jlands
Hello,
Thanks.
The fastest and cheapest way is to install a manual fan switch off the relay, you can turn both on and off as you please
https://www.ebay.com/itm/116039849584
https://www.thirdgen.org/forums/cool...an-switch.html
https://www.thirdgen.org/forums/cool...-run-both.html
https://www.thirdgen.org/forums/cool...de-switch.html
Old Jul 1, 2025 | 02:36 PM
Engine: Lb9
Transmission: M20
Originally Posted by BHR
a manual switch sounds like a pita, don’t forget to turn the fans on or overheat 😝
Old Jul 1, 2025 | 02:42 PM
Engine: Lb9
Transmission: M20
Just so you can see how it’s wired, it also kicks off over 35mph unless commanded.
Old Jul 1, 2025 | 03:43 PM
Jlands's Avatar
Thanks everyone for replying.
Old Jul 1, 2025 | 03:44 PM
Jlands's Avatar
Really appreciate this,
Thanks.
Old Jul 1, 2025 | 05:18 PM
Engine: Lb9
Transmission: M20
https://www.sprperformance.com/copy-...5-5a9953ccea0c
Old Jul 1, 2025 | 05:25 PM
Jlands's Avatar
Perfect.
Thanks.
Old Jul 1, 2025 | 05:26 PM
Engine: Lb9
Transmission: M20
Pretty sure you have to contact Sean directly to purchase but a great upgrade
Old Jul 1, 2025 | 06:06 PM
Jlands's Avatar
Got it.
Thanks.
Old Jul 8, 2025 | 11:40 AM
Jlands's Avatar
Hey, thanks again for the picture. Looking at the drawing, am I correct that anytime the secondary fan comes on, the pcm detects that and turns on the primary? Meaning that a lower temp fan switch on the secondary would turn on both fans?
Thanks again.
Old Jul 8, 2025 | 11:48 AM
Engine: Lb9
Transmission: M20
I think with either a/c request of fan sw grounding the primary comes on. I like to program in the computer chip 200f on 185f off on the primary. You could test by grounding the head temp switch. You can but different on/off 3/8 single wire switch’s at summit or jegs.
Old Jul 8, 2025 | 11:51 AM
Jlands's Avatar
Appreciate it.
Old Jul 9, 2025 | 06:15 PM
Jlands's Avatar
Alright. I did some testing. FYI, like many of us, i am not the original owner, but car is the same as I got it.
I start the car cold, no fans. I turn on ac with temp gauge still @100 and both fans come on. I turn ac off and both fans go off. I wait for car to warm up. Driver's fan come on at about 185ish. I let idle. It stabilizes at 220. Driver's fan still only fan on. All that sounds good. Whether it's stock or some mod, I like that the both comes on with the ac. But..... I don't understand the controll circuit you uploaded for the secondary fan. If the temp switch and the ac switch were "both" normally open, it would make sense.Hi coolant temp, secondary comes on... hi ac pressure, secondary comes on.
So, what is it that I'm trying to ultimately do. I want both fans to be on at @ 220ish without the ac on. Seems just replace the switch... got it. But my ocd needs to understand how the ac switch works.
Thanks.
Old Jul 9, 2025 | 06:17 PM
Jlands's Avatar
Or, if anyone can explain this.
Old Jul 11, 2025 | 08:30 AM
Engine: Lb9
Transmission: M20
The drawing might be the confusion. Anjf aujp tunes have a n/o fan switch
Old Jul 13, 2025 | 11:18 AM
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
I recall being confused by what you outlined in yellow myself. I think what it is really trying to say is never mind, I'm still confused. Why would pressure switch open when a/c on? The idea is to provide a path to ground when fans turn on right? seems backwards.
Here is what I presume is normal operation, as my car has not been altered.
https://www.thirdgen.org/forums/cool...ervations.html
Old Jul 13, 2025 | 11:22 AM
Jlands's Avatar
Thanks alot for replying.
Old Jul 13, 2025 | 11:23 AM
Jlands's Avatar
Originally Posted by LiquidBlue
I recall being confused by what you outlined in yellow myself. What it is really trying to say is fans will shut off if pressure gets too high or turn on when temp reached. the way it is drawn is, well eh....
Thank you very much. This is exactly the info I was looking for.
BBOWWLER
Apr 19, 2014 07:47 AM
Slow87
May 19, 2012 09:31 PM
fbody83
Jan 1, 2005 01:46 PM
355SS
Aug 4, 2003 10:26 AM
