fast xfi
Old Jan 14, 2006 | 09:57 PM
GTABANDIT's Avatar
fast xfi
just installed fast xfi plug in play kit from dan white racing .
Install took only minutes . i have a lot to learn first time dfier and have had good help from friends on base tune just gettin my feet wet but the system is awesome! unlimited tuning
Old Feb 25, 2006 | 03:36 AM
BLOWN25TH's Avatar
Car: 25th Anninversary Z28
Engine: Pro Charged 355
Transmission: Built 700R4
How is this install doing?
Old Feb 25, 2006 | 12:58 PM
weberflorida's Avatar
Car: 1991 Camaro Z28
What are your engine specs that you put that thing on? Just wondering. I am about to swap to a tpi from a tbi on my engine and was wanting to get a efi set up that could handle boost for future upgrades.
Does the one that you ordered do that? I mean does it come with sensors, wiring harness and all that stuff?
Bill
Old Feb 25, 2006 | 03:06 PM
GTABANDIT's Avatar
Install is doing fine . I have been slow to tune but i have worked on the cranking and idle features in spare time and am ready to put the car under load " preferably on a dyno" but i may have to ride and drive. I have been xtremely busy with work and family!
The kit came with a plug in adapter harness to interface with the stock wiring also the proper harness to convert to speed density a wide band o2 and the software . The engine is a 10to1 383 wafr 195 heads mini ram 30bls inj comp 228/234 550/550 cam. the wide band o2 and easy to navigate software of the xfi kiks --- ! It also has a help section that is very beneficial. ps it is capable of 5 bar map sensing so boost should be no problem
Old Feb 25, 2006 | 09:51 PM
That is cool man. 5 bar is a lot of pressure. Thanks brother
Bill
Old Feb 25, 2006 | 10:08 PM
Hey also how easy is the tuning with it? Do you just plug your laptop in it and change settings and it keeps in the ECU? I just got done reading about it and some other setups seems like a awesome setup. How much was the unit that you got and what did it come with?
Bill
Old Feb 25, 2006 | 10:09 PM
Sorry I did not read your last post good. Don't worry about all my questions just tell me how much the setup was if you could.
Bill
Old Feb 26, 2006 | 08:07 PM
GTABANDIT's Avatar
Plugs direct into laptop and realtime tuning without "flashin" or stalling of engine
Old Mar 2, 2006 | 10:59 PM
That is pretty sweet man. When I get back from Iraq i will probably pick something like up. I want to be able to grow into something. I am thinking of doing a supercharger or a turbocharger in the near future I just wanted to have the tranny and rear built and the fuel setup first.
Thanks for you answers.
Bill
InfernalVortex
Apr 20, 2021 11:31 AM
seiplentz
Aug 19, 2019 06:02 PM
grngryoutmyway
Oct 18, 2016 05:48 PM
Nervous2
Oct 8, 2015 10:53 PM
customblackbird
Oct 1, 2015 04:30 PM
