Please help me learn, I'm desperate
Old May 5, 2007 | 09:09 AM
puntank4200's Avatar
Car: '88 Camaro
Engine: v6-173-2.8L
Transmission: Automatic
I have a aldl cable, i have winaldl and turnerpro. I've downloaded everything i can find for my car off of moates.
How do i read my current sensor readings. My car is in a world of hurt, i need to know what sensors are bad, I'm a med student so i don't have money to buy all new sensors.
I really need someone to walk me thru, how to pull current values off of my car. Treat me like i'm a child in the walk thru if you most. I have finals this week and my car is running rich.
I've tried hooking up my cable to my laptop, then hooking up the other side to the 12v power and the diagnostics port. Ran winaldl for every ecm and no values were seen.
Old May 8, 2007 | 02:18 PM
Ronny's Avatar
Re: Please help me learn, I'm desperate
no CE light?
rich most likely a coolant temp sensor. tells ECU it is cold.
Old May 8, 2007 | 02:42 PM
Car: '88 Camaro
Engine: v6-173-2.8L
What program will work with my car? I don't want to just start replacing sensors, unless I know they are no good.
Old May 8, 2007 | 02:56 PM
Ronny's Avatar
winALDL is what i used. no CE light? search for a test for coolant sensor. I would think it can be tested with an ohmmeter.
Old May 8, 2007 | 05:56 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
The v6 requires the ALDL mode 10 k Ohm resistor.
Follow these diagrams, and use winaldl.
http://winaldl.joby.se/aldlcable.htm
I personally have used winaldl no problem with an 88. Without the R3, the ECM only sends gibberish, but you should still see "some" values. If not, maybe you are better off building your oen cable. The first diagram from that site works great. you can buy all the parts at radioshack for 10 dollars. I threw in a voltage regulator as well.
Old May 8, 2007 | 06:21 PM
Car: '88 Camaro
Engine: v6-173-2.8L
I get gibberish with winaldl, but It doesn't tell me anything. What is a CE light?
Old May 8, 2007 | 08:28 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
CE light means the check engine light, also some times called a MIL, malfunction indicator light.
Old May 8, 2007 | 08:40 PM
Car: '88 Camaro
Engine: v6-173-2.8L
No light, occasionally got a 34, but fixed with new relays. My thermostat is 180.
Old May 8, 2007 | 10:28 PM
Toehead's Avatar
take a screenshot with winaldl.
The raw data is gibberish, did you try viewing the dash or one of the tabs?
you NEED the r3 resistor or it wont work.
Elephantismo
Feb 13, 2019 12:51 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
Quzyle
Oct 15, 2015 03:35 PM
drumstixer
Sep 29, 2015 03:02 PM
mfp189
Sep 27, 2015 09:25 AM
