Help with VSS
Old Jan 8, 2009 | 04:58 PM
lnsper's Avatar
Car: 92 RS
Axle/Gears: 3.27 4 wheel disc
Help with VSS
I did a TBI to TPI swap on my 92 RS 305 by repinning the 746 to a 730 everything is working great it started up first try did my timing and it runs great but I am not sure what to do about the VSS buffer do I need to remove it I test drove the car today and got a code 42 VSS but I am not sure if it is from the buffer or the rearend that I installed at the same time it has a 2.73 and I put in a BW 9 bolt with a 3.27 gear any help would be great
Old Jan 9, 2009 | 08:24 PM
DSmith's Avatar
Car: 1989 Camaro
Engine: 383
Re: Help with VSS
If the Car was running before you did the engine and ecm swap it should run now if you have the VSS on the correct pin. Changing the gears will make the ecm and speedometer think you are going faster than you are but it will not keep the VSS from working. Check your wiring, must have missed something.
Old Jan 9, 2009 | 09:48 PM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
Re: Help with VSS
the 730 ecm has the buffer built into the ecm, no need for the external buffer box anymore, just the high low signal from the vss to the ecm. yellow and purple wires.
Old Jan 11, 2009 | 01:11 PM
lnsper's Avatar
Car: 92 RS
Re: Help with VSS
Thanks Quick Style
That's what I thought but what do I do with all the other wires on the buffer and will my cruse still work I also would like to find a wire diagram for the buffer.
I went to my local Chevy parts depot and they gave me this chart to calculate my gearing it looks like I need a LT Blue 45 teeth driven gear but they said they cant get it any more and that I should try a tyranny shop
Im not to sure how to post a pic of the chart they gave me
I will keep trying
Thanks for the help
Old Jan 11, 2009 | 02:25 PM
QuickStyle's Avatar
Car: 91 Z28
Re: Help with VSS
im not familiar with the conversion, i was just giving the info that i know of about the 730 ecm. as for the cruise, with the 730 ecm there is a black box right next to the ecm that i think is the cruise control module.
that 45 tooth driven gear will only work with your rear ratio if your drive gear is the blue 18 tooth, which it should be if your stock ratio was 2.73. The dealer told me that they couldn't get the gear for me also but after talking to the right person i was able to get it but i had to buy it in a pack of 5 for i think like $12 bucks. so i still have some of the gears laying around here somewhere.
Old Apr 1, 2009 | 09:06 PM
Morit's Avatar
Car: Firebird 88
Engine: 406
Transmission: th400
Axle/Gears: 3.50
Re: Help with VSS
Just a quick question...
The 730 harness:
At the C207 connector (one of two connectors that connects dash harness to engine. computer harness right near the computer) there is a grey wire going from the computer that is suppose to operate the speedometer.
My old harness with the buffer box
has a fan relay right there. Though I know where to connect the wire from a fan relay I need to know which wire from a buffer box operate the speedometer.
I assume connecting the wire I am looking for from now unused speedometer with the grey wire from the C207 connector will make the speed work.
Old Apr 4, 2009 | 10:32 AM
lnsper's Avatar
Car: 92 RS
Re: Help with VSS
http://www.austinthirdgen.org/mkport...SS_V8_vinE.jpg
This is what I used to rewire mine look around on this site it has alot of easy to find wireing tips
Old Apr 9, 2009 | 11:57 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: Help with VSS
Some more food for thought on the 730.
The 730 has two inputs for the VSS
a.) One is for magnetic VSS = 5 Volt Sine wave
Pins B10 +, and B9 -
4 pulses per revolution, 4000 pulses per mile expected
b.) One for Optical input = 5 volt square wave
Pin C6 +
The nuber of pulses is much higher on this input, searching can find the values. I don't remember right now.
There is a selection bit within the bin to choose which input to use.
You "should" be able to use the buffer box output into C6.
The 730 will output to the dash (B11) and to the cruise control module (C1) at 2000 pulses per mile if you have them connected.
These were for 91-92 SD setups running $8D, If you are running a different mask confirm the wires by the original schematics.
HTH
Old Apr 10, 2009 | 01:50 PM
Morit's Avatar
Car: Firebird 88
Engine: 406
Transmission: th400
Axle/Gears: 3.50
Re: Help with VSS
Actually I do know pretty well about the 730 VSS wires etc...
But I am having this engine in an older body with speed buffer and need to rewire speedometer..
I should connect the B11 wire from a 730 wit a wire that goes to the speedometer in my 88 body (originally 2.8l).. But I dont know which one is that, probably one of those on a buffer box..
And I am too lazy to disassemble dashboard and gauges again to check
Old Apr 15, 2009 | 01:40 AM
3rdGenFreak1227's Avatar
Car: 86 IROC Z
Engine: LQ4
Axle/Gears: 4th gen 10 bolt 4:10
Re: Help with VSS
I have wiring diagrams in front me from Alldata for the 91 305 TBI VIN E, and they only show one VSS input on pin A10 at the PCM its a brown wire coming from the VSS buffer box. The PCM out of a 91 TBI SD car should be a '7730 correct? Or are my wiring diagrams wrong? This would be great to know because I'm getting ready to swap the 165 computer out of my 87 305 TPI MAF car to the '7730 from a 91 TBI SD car using my factory harness, the pinout wasn't that bad, I have it all done on a chart just by comparing the two diagrams. I was told since the TPI is batch fire I can just hook the wires from my right bank to the RH injector driver and the same for the left bank to the LH injector driver. If there are discreptencies in the diagrams I have it would be great to know before I dive into this lol.
Old Apr 20, 2009 | 04:07 PM
JP86SS's Avatar
Re: Help with VSS
To be sure of what you believe is needed, check here on the schematics page for both of the ECMs.
http://www.cruzers.com/~ludis/
Connect items by function and confirm the pins. sometimes just going pin to pin without knowing what it actually is will cause headaches later when you try to fire it up.
There WILL be a pin somewhere wrong when you are done, it just happens.
Old Apr 20, 2009 | 06:00 PM
Morit's Avatar
Car: Firebird 88
Engine: 406
Transmission: th400
Axle/Gears: 3.50
Re: Help with VSS
I tried. And failed :P
I know what an 730 ECM pins where and how does it work..
But I am really unable to make it work with my underdash wiring (with buffer box.. even if I dont need it now.. ) :-P
$750 L98
Feb 1, 2025 02:25 PM
GTAman
Jul 3, 2024 07:29 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
