can a chip run this setup?
Old Feb 21, 2010 | 09:28 PM
mackjar66's Avatar
Car: 1989 GTA
Engine: pending install 383 tpi
port polished l98 heads 2.02 1.60 valves with this cam from comp 08-305-8, HSR intake and fuel rails, stroked to 383, running 36lb injectors. I have a speed density car 1991. Anyone running a chip on a similar setup? cant afford the fast xfi or accel right now. Any input would be great. thanks
Old Feb 22, 2010 | 10:29 AM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
Re: can a chip run this setup?
why couldn't it? granted, it's going to be a PITA to tune with that kind of duration, but the aftermarket ECUs aren't any more versatile than a well documented GM ECM, which you running $8D, you definitely have one of the more well understood masks.
Old Feb 22, 2010 | 10:52 AM
mackjar66's Avatar
Car: 1989 GTA
not sure which one I am running. All I do know is that I have a LB9 in a 91 formula WS6.
Old Feb 22, 2010 | 10:55 AM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
if you've never changed it, then yes, it's $8D running on a 1227730 ECM.
Old Feb 22, 2010 | 11:42 AM
mackjar66's Avatar
Car: 1989 GTA
ya its never been changed i bought the car from the original owner and he never did anything to the car. As far as ECM's go how good is this $8D
Old Feb 22, 2010 | 11:50 AM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
well it's been patched to allow for a lot of things the factory never intended... i believe there is a thread for it, something like S-AUJP or Super AUJP, something like that. there was also a boosted 8D mask that was at least being attempted at one time, i'm not sure of the results though.
Old Feb 22, 2010 | 12:00 PM
mackjar66's Avatar
Car: 1989 GTA
well hopefully PCMforless can hook me up on a great tune
Old Feb 22, 2010 | 12:01 PM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
tip: buy from a knowledgable individual, not a company.
Old Feb 22, 2010 | 12:13 PM
mackjar66's Avatar
Car: 1989 GTA
why u say that? I have seen more good then bad about PCM. I would rather dyno tune but I have yet to find someone that can actually do it here in town
Old Feb 22, 2010 | 12:19 PM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
more often that not, a company just does generic changes with no regard to how it actually performs(hypertech is horrible for this, actually had one of their chips from ~1988 in an 85 IROC).
with the kind of motor you have built, i wouldn't trust those kind of changes. and depending on what they're charging, you may be able to tune it yourself cheaper.
Old Feb 22, 2010 | 12:24 PM
mackjar66's Avatar
Car: 1989 GTA
not sure what exactly is need to tune myself, guess Ill have to research it
Old Feb 22, 2010 | 12:33 PM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
assuming you have a laptop: an ALDL cable, a chip burner and a chip or two.
ALDL cable could be made yourself if you're good with stuff like that, or buying one isn't too expensive ~$60 at aldlcable.com
burner: a willems is super cheap, but requires a bit more conectration than a BURN2 from moates(~$85)
chip(s): $5 each at moates.net. and since they are EEPROM, they take all of 1/4 second to erase and maybe 3-4 seconds to program.
so for less than $150, you can ensure it's a perfect tune. i can hook you up with some autotuning stuff to get fuel corrected pretty quickly using tunerpro V5 and either excel or openoffice.
Old Feb 22, 2010 | 12:41 PM
mackjar66's Avatar
Car: 1989 GTA
cool when I get the motor finished Ill have to hit you up for the programing thanks
Old Mar 9, 2010 | 06:57 PM
DVR408 88 iroc's Avatar
Car: 88 iroc
Engine: 5.7 TPI
Transmission: TCI Street fighter
i want to chip my 88 iroc 5.7 and wanted to know what chip would you guys prefere and does it reprogram the settings for the transmission too? thanks
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
NBrehm
Aug 25, 2015 11:49 PM
NWAsonoma
Aug 18, 2015 05:45 PM
Street Lethal
Aug 13, 2015 08:28 PM
Exxon Limited
Aug 9, 2015 08:13 PM
