Wideband O2 Advice
Old Jul 24, 2013 | 08:47 AM
kurtis72's Avatar
Car: 83 & 91 Z28 + others
Engine: l69 & lb9
Transmission: t-5
Wideband O2 Advice
I have a 91 TPI car, and want to add a wideband o2 sensor and gauge. Can someone recommend one that has a good 0-1v output for the ECM?
Old Jul 24, 2013 | 11:41 AM
Ronny's Avatar
Re: Wideband O2 Advice
Check out Craig Moates site. I happen to use an Innovate and has been flawless past 5 years.
Old Jul 24, 2013 | 03:07 PM
efiguy's Avatar
I'm sorry but Innovates suck, here's proof. The NTK is a lab grade, the best you can get. Look how far the Innovate is from that.
There are better ones out there, Accel and AEM to name a couple.
Old Jul 24, 2013 | 03:49 PM
Ronny's Avatar
It that being tested against a known A/F sample of ext gas? IOW the other two tested reported correctly?
All I can say is my tune is asking for stoich in CL(14.13 E10) and my sensor reports just that with expected switching a tad over and below stoich(lambda). My sensor is a Bosch(VW Jetta I believe).
Old Jul 25, 2013 | 07:26 AM
kurtis72's Avatar
Engine: l69 & lb9
Transmission: t-5
Ronny: what model do you have? The moates site seems to have several choices.
I don't have any experience with their o2 stuff, but I bought my EEPROM burner, chips and carrier from moates.net and they seem to work fine.
Old Jul 25, 2013 | 08:01 AM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
I got the one from www.dynamicefi.com
It hooks up to the EBL P4 Flash I got from there too, so I can tune.... Wideband not hooked up yet though....
So if your ecm is stock, ecm won't see any difference.... I think... someone chime in...
Rafael
Old Jul 25, 2013 | 08:24 AM
efiguy's Avatar
Originally Posted by Ronny
It that being tested against a known A/F sample of ext gas? IOW the other two tested reported correctly? Yes, NTK is lab grade. it's what everything else is calibrated to.
All these widebands use the same Bosch sensor. It's the controller that makes the difference.
Any of the "free air" calibrated O2's aren't very accurate.
And unless you can compare it to a test grade O2 you'll never know that.
Old Jul 25, 2013 | 02:17 PM
Ronny's Avatar
I purchased mine in a group buy here quite a few years ago from Innovate. It does have a controller. Mine is in fact calibrated to "free air". I do calibrate periodically but honestly did not see any changes. I would order one from Moates whatever brand he offers. I would take efiguy suggestion as well on the NTK as well if not too costly. It may be the best out there.
Old Jul 25, 2013 | 11:37 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Um, I don't mind sounding like an idiot so I will ask. What is the graph showing, response time of the sensors? And how do we know how "bad" it is if the X and Y axis are not shown on that graph? Who did the test, how did they do it , blah blah blah. I have the innovate wideband and on all my datalogs my sensor appears to be very quick and responsive, even down to the thousandth of a second.
Old Jul 26, 2013 | 12:21 PM
efiguy's Avatar
Originally Posted by Tibo
Um, I don't mind sounding like an idiot so I will ask. What is the graph showing, response time of the sensors? Yes And how do we know how "bad" it is if the X and Y axis are not shown on that graph? Who did the test, how did they do it , blah blah blah. An independent lab, I'll try to get the name. I have the innovate wideband and on all my datalogs my sensor appears to be very quick and responsive, even down to the thousandth of a second. I don't doubt that, but how can you verify it's accuracy?
Until you have the two side by side, the Innovate and a lab grade, it's hard to tell. Once you do it's night and day, I promise.
I had an Innovate, then sold it and bought a better one.
Old Jul 26, 2013 | 05:23 PM
Dominic Sorresso's Avatar
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Axle/Gears: SuperDana 44 4.10
I've used the Zeitronix ZT-2 for the last 8 years. Very reliable and accurate.
IROCThe5.7L
Aug 10, 2015 11:24 AM
Jhert10
Sep 15, 2014 02:04 PM
nuggie
Sep 8, 2013 01:08 PM
c4mo
Jul 13, 2011 01:58 PM
mike1986fyrbird
Apr 3, 2006 11:36 AM
