megasquirt tpi conversion
Yes i have an 84 camaro and plan on converting to tpi using a megasquirt ecu. Has anyone done this before and are there any tips you can give me so i dont just blow a bunch of money and have it fall apart.
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: megasquirt tpi conversion
First off, you need to search for broad topics such as this before posting this very broad question. There are many threads on this site covering this:
https://www.thirdgen.org/forums/dfi-...asquirtii.html
https://www.thirdgen.org/forums/dfi-...t-350-tpi.html
https://www.thirdgen.org/forums/dfi-...ful-hints.html
There is also this article on diyautotune:
http://www.diyautotune.com/tech_arti...lock_v8_v6.htm
You def will need to check out the msefi web pages.
everything in those pages i've read but i'm still having issuing figuring out how to wiring my ignition coil to either an ms1 or ms2. also which would honestly be better. the ms1 can control my ignition but i dont know how to go about doing that exactly because i dont know how to wire my coil.
I felt like a just did a whole lot of
but any help would be extremely appreciated thank you guys.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Car: 1991 Z28 Vert
the wiring between ms1 and ms2 is slightly different
here s athread that may intrest u as we r helping a fellow v6 member install and ms1 w extra code on his v6
https://www.thirdgen.org/forums/v6/6...rbo-2-8-a.html
while it is a v6 the setup and wiring is identical , the only difference is he has 2 less injectors
Car: 1991 Z28 Vert
ms1 is not fuel only , u just need to run the ms1 extra code
the cpu itself runs fuel and spark or fuel only, or spark only depending on the config
b&g base code has been outdated and unused for years , this is the fuel only code
Car: 1984 Trans Am
Axle/Gears: Stock
...Back to trying to answer Damion Allen's question...
Are you buying the build it yourself board or the already completed one? For wiring the coil your two eaiest options are spelled out in the megamanual
GM HEI http://www.megamanual.com/ms2/GM_7pinHEI.htm
Direct coil control http://www.megamanual.com/ms2/vb921.htm
Make this decision early as it effects what you install on the board.
I myself went with the direct coil control as it gives me the most control with the easiest execution. Basicaly the the connectors on the side of the HEI cap I left in place. I routed a wire on the (-) of the coil inside the cap (undernieth the rotor) to the relay board (or megasquirt). I am using the same connection as the ignition module (-) (which I had removed previously.)
Car: 89 Camaro RS running MS2X
Engine: .48/.60AR T3/T4 2.8L V6
Transmission: Rebuilt 700R4 2500 stall
Axle/Gears: Next to break...
I went with the hei 7/8 pin setup, running ms1 extra code. Works great. Boils down to personal preference, and i made a table of contents page on my thread for easy access to whats in the thread. Its the Another turbo 2.8 thread project linked.
I went for the ms1 processor cause i wasnt worried about the IAC valve, if you want to keep your IAC youd have to go with a ms2 processor. If your good with electronics and a soldering iron, id shoot for the v3.0 board, its a build it yourself option thats a little cheaper and has a prototype area for additional circuits. I didnt use the relay board, reused the stock relays, so you have a bunch of options to say the least.
Btw, im running ms1 fuel and spark. Its the code that allows you to run fuel and spark, so its still ms1, just running the extra code to control everything. Once you really get into it it gets easier. My car is running and driving, once i replace the burnt ICM, lol.
Sanjay
Aug 12, 2015 03:41 PM
