Need help understanding what I need
Old Mar 23, 2019 | 01:39 AM
Gary Clark's Avatar
Car: 92 c 1500
Engine: 5.7
I have a 92 c1500 that I have slightly modified. The 350 is an older block that has been balanced and blue printed. It has a stage 3 cam, ultimate tbi mods, tbi spacer, injector pod spacer, increased fuel pressure capability, dual exhaust, and others. It has the 700r4 transmission. I'm having trouble understanding exactly what I need to be able to hook my laptop to my truck for data logging and real time programming. I also want to be able to make it possible to send the data logging results to a qualified programmer who can then send me a program file back that I can load into the ecm without having to change any hardware.
Old Mar 23, 2019 | 06:27 AM
MrWillys's Avatar
Re: Need help understanding what I need
I can help you if you send your ecm to www.moates.net and have the adapter soldered in that allows use of a 28 pin chip. For information about datalogging and tuning see my custom tuning and datalogging2 pages. www.scotthansen.net
Old Mar 23, 2019 | 07:44 AM
Gary Clark's Avatar
Car: 92 c 1500
Engine: 5.7
[QUOTE=MrWillys;6289862]I can help you if you send your ecm to www.moates.net and have the adapter soldered in that allows use of a 28 pin chip. For information about datalogging and tuning see my custom
I read something about a new ecm that has flashable memory and is far superior to the slow stock dinosaur currently in my truck. Would it be worth the money to go that route? Also if I was going to send my ecm to have the adapter installed would I be advised to locate one of the better ones from a parts yard? Thanks for your time and advice
Old Mar 23, 2019 | 07:50 AM
MrWillys's Avatar
I don't know if the EBL can replace the 16146299 that uses the $99 definition and it may. However, once you go EBL I can no longer help you and you're dependent on the members of this board and it's owner.
Old Mar 23, 2019 | 08:07 AM
Gary Clark's Avatar
Car: 92 c 1500
Engine: 5.7
Is the 1227747 ecm an upgrade to mine
Old Mar 23, 2019 | 08:08 AM
Gary Clark's Avatar
Car: 92 c 1500
Engine: 5.7
By the way you will definitely be getting my business
Old Mar 23, 2019 | 08:12 AM
MrWillys's Avatar
No, it's equal.
Gary Clark's Avatar
Car: 92 c 1500
Engine: 5.7
I like to think of myself as being of some intelligence. Understanding the foreign jargon is where I get lost. All the acronyms and abbreviations.
Old Mar 23, 2019 | 08:47 AM
Gary Clark's Avatar
Car: 92 c 1500
Engine: 5.7
so other than me trying to turn this into something more than what it is I should just take your advice from the very first post
Old Mar 23, 2019 | 08:49 AM
Gary Clark's Avatar
Car: 92 c 1500
Engine: 5.7
I will have to go get a ecm from the parts yard (cost next to nothing) I can't be without a vehicle
Old Mar 24, 2019 | 10:40 AM
HellHound's Avatar
Car: I drive trans am. Duh
Engine: Yes, I have one in the trans am
Transmission: I have one of those too In trans am
Axle/Gears: In the rear of trans am
Having a spare ecu is the way to go. If it goes down you can slap the other in. All they do at Craig's is just solder in a pin header. If you can do this, just order his parts. You need any parts just go to him. What all do you have to get you going? You said some one with programming so l have to assume you have a burner or/and an emu of some kind.
http://support.moates.net/g2-adapter-installation/
Old Mar 24, 2019 | 12:58 PM
Gary Clark's Avatar
Car: 92 c 1500
Engine: 5.7
I have the truck lol. I wanted to get advice and guidance before I started buying stuff that I have no first hand knowledge or experience with.
Old Mar 25, 2019 | 02:02 AM
GeneralDisorder's Avatar
Just get the EBL system. It's far superior than stock with many features including some self-learning capabilities for the VE tables. Faster data logging, n-alpha blending, and tons more. Lots of board members including myself that can help you tune it. It's so much better it's hilarious that anyone would even bother with factory BIN tuning when a product this advanced is available for such a low price.
https://www.dynamicefi.com/EBL_Flash.php
GD
Old Mar 25, 2019 | 02:19 AM
Gary Clark's Avatar
Car: 92 c 1500
Engine: 5.7
GD
Thank you very much. This is exactly what I was looking for. Far more advanced, easier to understand, and don't have to buy countless items, or have 7 different programs to master.
Old Mar 25, 2019 | 06:13 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Moates gp1 adapter should plug in and work fine. No need to soldier anything
then download tunerpro rt and find the definition file and datalog file for that to log and look
Old Mar 25, 2019 | 08:39 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
That ECM uses the small 24 pin PROM. Would require the G2 adapter to be soldered in.
RBob.
Old Mar 25, 2019 | 08:41 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
RBob.
ahh i see. Thought it was same as the 7427 and 730’s stuff
Old Mar 25, 2019 | 02:20 PM
HellHound's Avatar
I get that. But I dont know what all you have to get you going. I already had almost all my stuff, otherwise I may have gone the ebl route. Which I may still, I do want to try it out. But that also means I will have to start again. And I am not far off from where I need to be. I am on code $59, but the code for yours is different. Ive done the basics on those for people, and the code is pretty straight forward. The link is a copy and paste. It shows what needs to be done.
jamesbob02
Aug 9, 2003 01:32 PM
92RSB4C
Jan 23, 2002 10:06 PM
87irocz350
Car Audio
Dec 30, 2001 08:29 AM
Z28Man
Aug 3, 2001 11:43 AM
