Need help with prom
Old Oct 3, 2020 | 06:46 PM
Kyle Lawrence's Avatar
Need help with prom
Hello, I am trying to help out my Dad with an issue when he swapped his ECU in his 1986 irocz z28 camaro, it has the stock TPI 305 in it vin code F. The issue is he has received two different ECUs from summit racing, as you all already know they are now updated from the originals when you receive a remanufactured one. The issue is when he received his remanufactured ECU from summit the insert that the 14 pin prom chip sits in was missing. I'm guessing that someone previously had taken it out, sadly my Dad can't install his factory prom chip from his stock ECU without that insert. My question I would really appreciate an answer for is what other prom inserts can be used to install the 14 pin factory AC Delco chip into the ECU ? Thanks ahead of time for any help with this.
Old Oct 3, 2020 | 07:44 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Need help with prom
Should have a 1227165 or superseded number. Doesn’t use a calpak. The netress and prom are in a memcal.
got a picture of what you have and service number?
Old Oct 3, 2020 | 07:45 PM
Engine: Lb9
Transmission: M20
Byw prom should be 28 pin.
Old Oct 3, 2020 | 09:30 PM
That's what I meant. 14 on the bottom & 14 on the top, sorry I didn't clarify that.
Old Oct 3, 2020 | 09:34 PM
Engine: Lb9
Transmission: M20
? You got some sort of piggyback adapter?
a prom 27c128 has 14 legs per side.
Old Oct 3, 2020 | 09:38 PM
That's what was meant, it has 14 on the bottom & 14 on the top so 28 pin
Old Oct 3, 2020 | 09:42 PM
Engine: Lb9
Transmission: M20
Got a package of what you have ? Missing the prom ?
sorry not following.
Old Oct 3, 2020 | 09:46 PM
The prom isn't what's missing, we have the 28 pin prom. The insert is what's missing that the prom fits into & then the insert with the prom snaps into the housing on the back of the ECU.
Old Oct 3, 2020 | 09:52 PM
Engine: Lb9
Transmission: M20
66 pin header ?
Old Oct 3, 2020 | 09:58 PM
Looks to be correct. Looks like my Dad's stock one
Old Oct 3, 2020 | 09:59 PM
Engine: Lb9
Transmission: M20
Your replacement must be the wrong service number.
Old Oct 3, 2020 | 10:02 PM
The remanufactured ECU from summit racing is the correct number to replace the stock one is what the listing said.
Old Oct 3, 2020 | 10:13 PM
This is the replacement remanufactured ECU from summit racing. The left side is where the prom goes but the insert that the prom goes into is what's missing. The chip fits into the insert & then they snap into the housing on the bottom left.
This is my Dad's stock ECU. 1986 irocz z28 camaro, TPI 305, vin code F
Old Oct 4, 2020 | 08:14 AM
Engine: Lb9
Transmission: M20
Wrong ecm you need a 1227165 , or 16198259,88999194,16198445
or cardone 77-7165, 776571
blue streak em7165
https://www.summitracing.com/parts/aaz-77-6571
Old Oct 4, 2020 | 08:17 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The '9128 that Summit sent you is for an '85 TPI car. It won't work in your Dads '86, which uses an entirely different ECM.
RBob.
Old Oct 4, 2020 | 08:24 AM
Engine: Lb9
Transmission: M20
The ecm You got from summit I think is a 85 only tpi vin F superseded 1226870.
Old Oct 4, 2020 | 11:21 AM
blue streak em7165
Ok, thanks for the information. It just makes no sense that summit racing can't send out the right one to begin with.
Old Oct 4, 2020 | 11:23 AM
Engine: Lb9
Transmission: M20
If you look at the application listing on there site for your ecm you purchased it says 86-89 tpi. Not correct.
Old Oct 31, 2020 | 01:03 AM
Re
What would cause my Dad's 1986 irocz camaro's cooling fans to run constantly while running after replacing the ecm ? He has the correct one now, it's a cardone & he got it from o'reilly's. Thanks for the help ahead of time.
Old Oct 31, 2020 | 06:54 PM
GeneralDisorder's Avatar
Re: Re
Is the SES light on?
GD
Old Oct 31, 2020 | 06:56 PM
Engine: Lb9
Transmission: M20
Have a scanner to see if fan is being commanded on ?
if it comes on when key on engine off could be a bad ecm.
Old Nov 1, 2020 | 08:00 AM
Re: Re
GD
He said it currently didn't have any.
camaroman9191
Feb 24, 2010 11:40 AM
avengersteve
Jun 25, 2007 09:28 PM
Vidman
Feb 24, 2007 12:04 PM
Ronny
May 18, 2005 02:41 PM
85F-body
Jan 6, 2001 10:35 AM
