Aldl
Old Jan 15, 2003 | 11:36 PM
86FyrBrd's Avatar
Car: 1992 Camaro Z28 Convertible Z03
Engine: 383 SuperRam
Aldl
anyone wanna make me an ALDL->Serial port cable. I just dont seem to understand how to make one (or is someone can provide simple instructions on the post for me also would be better) If I search all I come up with is sh** that doesnt make sense. So name your price, or post instructions.
thank you,
Brian
Old Jan 16, 2003 | 02:25 AM
Morley's Avatar
Give me a day or 2 and I'll post a drawing of the circut board I made for mine, all you'll have to do is make one that looks just like it and add the components.
Old Jan 16, 2003 | 10:11 AM
BillD91RS's Avatar
Take a looks at <a href="https://www.thirdgen.org/techbb2/showthread.php?s=&threadid=117913&highlight=aldl" target="_blank">this post</a>
It explains hot to make one.
Old Jan 16, 2003 | 11:30 AM
86FyrBrd's Avatar
wow man, thanks, I guess my search didnt find that post. I'll buy the parts today and maybe make it tonight!
One more question, do you know if there is anything that would stop me from permanantly connecting the cable (maybe soldering the wires on behind the connector) The computer will be in the car, and I'd love to be able to just launch a program and see instead of having to hook up a cable every time.
Old Jan 16, 2003 | 01:07 PM
Morley's Avatar
Well if you have an 86, as your name implys, then you could leave it hooked up or spliced in, BUT you'd need to take the 10k resistor off of pins A&B for normal driving (the 10k resistor you need to get the ECM to transmitt ALDL data).
Old Jan 16, 2003 | 01:18 PM
86FyrBrd's Avatar
so take it off and leave it off permanantly and it will still work, and work all the time?
Old Jan 16, 2003 | 01:39 PM
BillD91RS's Avatar
I don't see why not. I don't need the 10k resistor to get data. I spliced the aldl lines into a headphone connector and mounted it in my dash. I don't need to do anything other then plug in the cable to the connector and I'm up and ready to go.
I don't know if you will need the resistor or not but if you do you might be able to wire it in with a toggle switch or something so that with the switch in one possiton it has the resistor and in the other it doesn't
Good luck and if you have questions ask.
Old Jan 17, 2003 | 03:35 AM
Morley's Avatar
With the 165 ecm you have to have the 10k resistor across pins A&B to get the ECM to transmitt serial dats (the ALDL stream)
And I believe that when the resistor is in place the knock retard function is inop.
xodus2002
Jul 17, 2020 09:08 AM
Veaceonee
Sep 29, 2016 08:15 PM
WejaZ28
Oct 3, 2015 07:38 PM
greenyone
Sep 8, 2015 08:41 PM
Gunsbee
Sep 7, 2015 07:10 PM
