ecu def file intercange ability
Old Feb 17, 2004 | 04:08 PM
clippjr8's Avatar
what all ecu files can the 6e def file be substituted for? example: you can substitute the 6e for the 32b.
Old Feb 17, 2004 | 04:20 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
6E bins should only be read using ECU files built for 6E code (some examples of available ECUs are 6EV011.ecu, ARAP.ecu, APYP.ecu).
If you're asking if you can run your 6E car with a 1227165 on 32 or 32b code, I believe the answer is yes, but why would you do that? 6E, I think, is superior. Could be wrong.
Old Feb 17, 2004 | 06:26 PM
clippjr8's Avatar
no, that is not what i mean. what i want to know is if you can use the 6e binary file in place of any other files other than 32b.
Old Feb 17, 2004 | 07:15 PM
Mangus's Avatar
Transmission: T5WC
read the second sentence of my reply. ;-)
Old Feb 17, 2004 | 07:53 PM
clippjr8's Avatar
i must be asking the wrong question. I understand what you are saying mangus, but thats not what im trying to find out. can i use a 6e arap bin file in any other computers other than the 1227165?
Old Feb 17, 2004 | 07:55 PM
Mangus's Avatar
Transmission: T5WC
'808 (counterpart to the '165).
Other than that, nope.
Old Feb 22, 2004 | 09:41 PM
trigger GTA's Avatar
Car: 92 TA vert
Mangus
if you could be so kind to help me out also
"the 165 can use the 6EV011.ecu, ARAP.ecu, APYP.ecu." as you said.
is there some place that explains what the diferences are from one to the next
eg. Moates was so kind as to make a list of files here http://www.moates.net/fileman/
in the stock bin section i see that there are many bins for the 165. is there a way to tell what one would be the best to start with and not have to open each and every one to compair the differences. or even for that mater what one was made for engine,trany, year, or whatever
Old Feb 22, 2004 | 09:45 PM
Mangus's Avatar
Transmission: T5WC
Those are some loaded questions.
I'd like to believe that, due to the diligence of myself and some other old timers on these boards, that the 6Ev011.ecu file is the most complete. I haven't personally looked at ARAP.ecu or APYP.ecu, so I can't (rather, shoudn't) comment on them.
As far as what bins are best to start with, I can't really answer that. I can say, though, that you should start with an auto bin if you're driving an auto (ARAP), or with a manual bin if your car is a manual (APYP). Other than that, no idea. depends on your setup and goals. This is usually a tough question to answer, but do some research and figure out the right questions to ask and you'll figure it out.
InfernalVortex
Apr 20, 2021 11:31 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
Jerzyperson
Carburetors
Nov 13, 2015 01:07 AM
KO1
16
Oct 15, 2015 05:00 PM
MitcherNeaf
Sep 24, 2015 09:23 PM
