Limp Mode between Chips
Old Mar 14, 2005 | 12:05 AM
TheMysticWizard's Avatar
Car: 1987 Firebird Trans AM
Engine: 383 TPI...very soon
Transmission: TH700R4
Okay so I posted last time, and never got an answer... so here it goes again...
Is the limp mode different between different chips?
For Example... Would a 86-87 MAF memcal have the same limp mode as a 88-89 MAF? or is it different because of the cold start injector?
Also, are the limp modes different between engine sizes and transmissions? Would a 305 manual limp mode be the same as the 350 auto limp mode?
Old Mar 14, 2005 | 05:51 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: Limp Mode between Chips
I doubt anyone has a *for sure* answer on that. The limp home mode isn't a test mode for the EPA, so they could change it at any time. Weither they did or not form time to time would be a guess.
I'd still recommend using a memcal from an application as close to what you're running. It still has to set some firmware items.
Old Mar 14, 2005 | 09:39 AM
Okay thank you...
So I'm going from a '87 305 auto (with cold start) to a 383 auto without cold start... I guess I should look for a 88-89 350 Auto memcal then? And just tune the prom on top of that...
Right?
Old Mar 14, 2005 | 11:56 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Okay thank you...
Right?
Yep.
The newer the stuff is that you use, the more refinded it is. In your case the using the 89 stuff gets you the final version.
Old Mar 14, 2005 | 12:02 PM
Maybe I'm pushing a little far here... but does anyone know the GM Part Number or anything for the 89 350/auto Memcal?
Old Mar 14, 2005 | 01:57 PM
Slow89Iroc-Z's Avatar
Car: 1989 Iroc-Z
Engine: 350ci SBC
GM part number for '89 ARAP:
16134193
Old Mar 14, 2005 | 11:41 PM
16134193
Would I need to change anything in that PROM to just test run it on my car? Just to get an idea what I will need to change in my tuning.
Is the ARAP a thirdgen chip or was it from a Corvette?
Old Mar 15, 2005 | 10:38 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
ARAP is a 'Vette calibration. Best to do a search as it has been covered. Off hand the fan outputs are inverted, VATs is enabled, the SA tables are too hot, no longer need cold start injector, cranks a lot before the injectors fire, and a couple of other things.
RBob.
Old Mar 16, 2005 | 02:38 AM
Bill usn-1's Avatar
Car: IH Scout
Engine: 345 V8 TBI
Transmission: 727
Any one have a valid GM part # for the NETRES chip.
I run the 7747 and have searched by the number off the chip, the chip numbers listed on Ludis' site and the GMECM site.
I have not been able to get any of the number to cross on the partsdirect or other parts sites.
There's lots of V6 chips in the JY but the V8 7747's are getting a little scarce.
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
KO1
16
Oct 15, 2015 05:00 PM
jaridjohn
Oct 5, 2015 07:01 AM
