Backfire through TBI cranking
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
7747 Ecm, $42 mask from Moate's site, Vortec heads, 4.3L.
Once it does start, it idles just dandy. Idles at 40kpa Park, 60kpa drive. Spark table is it. Everything else I could find is zeroed out. Doesn't have a startup spark in this ecu. Base timing at 0-2deg BTDC (0 Initial in the chip) Adjusted the timing based on a Vacuum gauge and the highest I got was 18hg with that timing table and dizzy position.
If I retard the timing (implying an intake valve was open while firing) I get flames, and it really doesn't want to start or idle well.
I added more fuel pressure and it seemed to make it worse too!
Any ideas?
Any ideas?
Car: An Ol Buick
Engine: Vsick
Re: Backfire through TBI cranking
Any ideas?
Any ideas?
Might try some GM injector cleaner, and see if that helps, a poor injector pattern can do that also.
Replaced the pickup in the dizzy. Still backfires.
Advance or retard 1 deg at a time untill it's hard to crank... still backfires.
Tried adding and subtracting in intervals of 2, 20degs of timing in the 100KPA area. Also tried zeroing the cool compensation and doing the same. Still backfires.
Backfires less cold?
injector pattern looks good.
plugs look sooty, porcelain is black. But they aren't wet right after cranking with backfires.
rechecked valve lash = good.
Idles well, no surging, tip in okay.
Crank AFR went from 1 to 10 at the given temp, and it still backfires. There are some open loop AFR tables in this XDF, but open loop runs fine when it starts.
What all does the 7747 look at while cranking?!
Loosing my whits. May go for a carb and use the ecm for timing!
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Incuctive crossfire (spark is jumping from one wire to the next), or just plain ol' got them wires mixed up, or an intake valve is hanging open. That's about all it possibly could be, in my mind.
Car: 91 Red Sled
You do know that the open loop AFR is calculated by the CTS lookup + Vac lookup. So your tables are showing me lean.
Go back to the stock open loop AFR tables.
Also, do you think your choke AFR table looks normal?
Because that is subtracted from the calculated open loop (cts vac added).
Because that is subtracted from the calculated open loop (cts vac added). Moderator
Car: check
Engine: check
Transmission: check
. . .plugs look sooty, porcelain is black. But they aren't wet right after cranking with backfires.
. . .Crank AFR went from 1 to 10 at the given temp, and it still backfires. There are some open loop AFR tables in this XDF, but open loop runs fine when it starts.
What all does the 7747 look at while cranking?! . . .
During cranking the ECM does this:
Spark timing is at the initial setting (physical distributor location).
Commanded AFR is from the crank AFR table (unless open loop is richer, then it uses that).
The VE tables are also used: 400 RPM row in main table, 0 RPM in adder table. Usually the 90-100 KPa area. Too low a value and very little fuel will be added.
Inverse temperature term is from the coolant sensor. This is an important sensor and should be checked with a scan tool. Basically, is it reporting the correct value.
If the ECM is in limp mode then the crank signal is used for crank enrichment.
Any chance the vehicle still has summer gas in it? If so that can cause issues.
XDF file? Does it have the main 3D VE table defined correctly? There is a bunch of pivoted definition files out there.
RBob.
-Open Loop AFR vs Coolant temp is the factory table:
-AFR at Startup is .5 leaner in the warm temps
-Open Loop AFR vs Map is stock
-Choke AFR modifier is stock
-Crank AFR Is also the factory table.
-BPW set factory 181
Accoding to the ABUL bin I've downloaded, aswell as the one I pulled from my chip.
I'm not sure about the main VE table being pivoted or not. Not sure on what that means. It was the definition file from Moate's site. I will start using the 7747-mine.ecu that you posted in another post as to be the best.
Not summer gas, only pulled the heads off 4 weeks ago. Also, hit the gas station and filled up a few days ago.
The ecm's CTS reads what I feel is correct. There is no error, it does not read -39. Falls right in line with warming up. Using Winaldl.
The plugs were black this time... from the engine starting and warming up. Shut off. Then tried to start with 5 different crank afr settings.
Lots of values changed when I put in the 7747-mine.ecu. Could this be from the old bins I was using? Possibly the import feature in Tunerpro v4.00?
Think I'll replace the plugs, find a good $42 6 cyl bin, and start over.
ABUL 42 bin from moate's site.
Thanks for all the help and knowledge guys!
Car: 91 RS
[B
I'm not sure about the main VE table being pivoted or not. Not sure on what that means. [/B]
[B
The next ECU I hope try should be RBob's UTBI
