Tuning with the EBL
Old Feb 26, 2025 | 08:49 AM
  #5351
Yariv's Avatar
Re: Tuning with the EBL
What are the differences between EBL_F_3006.BIN and EBL_F_3005.BIN. Way back, BobR used EBL_F_3006.BIN for my set-up. Auto 1985 Corvette with BluePrint heads (Aluminum) with 700R4?
Old Feb 26, 2025 | 08:55 AM
  #5352
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Do the file compare in tuner pro to see the difference. He states the heads and engine size in the txt document.
Old Feb 26, 2025 | 09:03 AM
  #5353
dabomb6608's Avatar
Car: 86 Trans Am/85 K5 Jimmy
Engine: 406 FIRST/350 TPI
Transmission: TKO 600/700R4
Axle/Gears: 9Bolt/10Bolt front & back
It was my understanding that the VAC column in the CSV dumped file is what is used for the Open Loop- AFR vs RPM & VAC table. Which if you look the VAC is just an inverse of the 0-100 MAP range. So at 80 MAP you have 20 VAC, 50 MAP = 50 VAC and 20 MAP = 80 VAC. I always assumed that table was ranged 80 VAC to 0 VAC because the VE starts at 20 kPa and goes to 100 kPa.
But that isn't really correlating with what Street Lethal said above. I didn't think that table was based off of inch of mercury (Hg), but I very well could be wrong.
Old Feb 26, 2025 | 11:09 AM
  #5354
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
We'll measure engine vacuum in Mercury (inHg). I'm so used to looking at a boost/vacuum gauge and not the EBL, but ideally a well behaved engine will pull around 17" to 20" of Hg at idle, which is about 40-kPa. A cammed engine for the street, maybe in the 13" to 16" Hg range which is about 55-kPa at idle. Larger cams like mine will see roughly 10" to 11" of Hg at idle, which is about 65-kPa at idle. Steady speed cruising will see roughly 6" to 9" of Hg, which is about 80-kPa. In RobertFrank's case his OL table data is reading correctly. Each cell is averaged and influenced by the cell next to it. So him being 80-kPa at cruising speeds places him at about 6" of engine vacuum (Hg), which can be confirmed with a vacuum gauge. His Open Loop target is preset to 12.8 AFR at that range purposely during warmup, as once Closed Loop enables that table is ignored until it goes into Open Loop again. Since he is forcing an Open Loop tune, he needs to set those two far right columns (10 and 0) in that OL table as 14.7 AFR up until about 2000-RPM, but keep them at 12.8 AFR from 2400-RPM and higher because that is the transition point into wide open throttle.
- Rob
Old Mar 12, 2025 | 06:25 AM
  #5355
Rebuildman's Avatar
Car: 1990 Corvette, 1985 C-10 1979 Subun
Engine: 350, 406 HSR
Transmission: manual, 200 4r
Cold start RPM
Having trouble getting my rpm high on a cold start. I have the park IAC idle speed table set to 1050 rpm at temps 40c and below. I have the IAC max limit set 255. When the engine starts it will not idle above 800 rpm or so and the IAC is at max open 255. Spark advance about 20 deg. WB shows 11 or so AFR. All is well when it reaches 180F. My IAC setting after warmup is closed as I have the throttle blades opened a bit too much to help with the cold start. I can close the TB down to get the IAC count up to 10 or so, but it does nothing to help the cold start. This is an iron vortec head 350 using TPI.
What else controls the cold start idle rpm?
Old Mar 12, 2025 | 06:53 AM
  #5356
Rebuildman's Avatar
BPC vs VAC table?
Looking for this using Tuner Pro. Not finding it? I am running TPI setup.
Old Mar 19, 2025 | 02:46 AM
  #5357
Yariv's Avatar
Hi, I took VE tables and AFR tables from the EBL_F_3006.BIN and started to re-calibrate the VE tables using VE learn sessions. Can I trust this process? Let's say I'll do about 8-10 learn sessions, trying to cover most of the MAP and RPM areas with CL and lean HWY, which are disabled. Is it enough? should I smooth it in the end?
Old Mar 19, 2025 | 08:35 PM
  #5358
Byron454's Avatar
IMHO yes trust the process, yes smoth after/between learns, do more learns, have fun with it, after 8-10 it should be running OK?
definatly look at the VE tables and see what they look like, as long as your exhaust gas sensor is reporting correctly the learns will show you
what the motor wants, do what makes the motor happy.
Old Apr 4, 2025 | 12:17 AM
  #5359
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
Truly sorry to hear RBob's passing.
Bought an EBL Locker for my Formula restoration, circa 2020.
Life has finally allocated time for me to get the engine running & tuned.
Was looking for where to download the A-to-D converter necessary for the WUD.
Bottom line, I have the complete package (EBL, installation discs, & doc printouts)
which I would be willing to fire-sale to a good home. Make offer ...
I also have the Edelbrock High rise & Enhanced Truck 2 barrel Injector, fire-sale ...
Add my voice to the condolences, & loss of technical expertise.
Ken Koester / l_dis_travlr
koester_ken@comcast.net
Old Apr 4, 2025 | 03:07 AM
  #5360
Airwolfe's Avatar
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
Since your profile shows you have a 1990 Formula 350 do you have the P4 EBL system?
Old Apr 15, 2025 | 02:42 AM
  #5361
Yariv's Avatar
Hi all,
Just wanted to share an experience with you.
I’ve been using EBL for several years now. Lately, I wasn’t satisfied with the tune, especially with the VE tables. I copied new VE tables from EBL_F_3006.BIN and started the VE learn sessions for a fresh start. I made about 12 sessions, CL was disabled, and no PE nor lean cruise. The sessions included WOT, cruising at varies MAP and RPM, hard and light accelerations. After I finished the 12 VE learn session. I turned CL, PE, and lean cruise on.
Later on I started to use Chat GPT for some corrections in varies condition. Of course Chat GPT knows about my setup. It made a few corrections regarding WOT, spark and some VE cells.
In the end, I asked it to smooth the VE tables:
Old Apr 15, 2025 | 11:23 AM
  #5362
drive it's Avatar
Just use the smoothing function in tunerpro
Old Apr 15, 2025 | 11:40 AM
  #5363
Yariv's Avatar
Any how-to instructions?
Old Apr 15, 2025 | 11:46 AM
  #5364
drive it's Avatar
At the top of the VE table look at function-there is a smooth. I usually put in value point 8 then click execute 2 to 3 times.
Old Apr 15, 2025 | 03:11 PM
  #5365
Buccaneer's Avatar
Car: 82 Corvette - CFI
Engine: 383 - Renegade, AFR 195, Bullet cam
Transmission: 700R4 - 3,200 Yank TC
Axle/Gears: 3.31
Just curious, did you input the entire VE table values into CHAT GPT? If so, that does show the power of AI and it's just getting started. It doesn't look that bad actually. This is our bone stock CFI tune VE table low speed that came with the EBLs we sent out. The tune was done by Street Lethal. You are getting there... We used three C3 82 corvettes running the EBL back when we did this.
Old Apr 15, 2025 | 04:07 PM
  #5366
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
I'm curious to see how it would be beneficial to use ChatGPT in using the ebl flash. I was even thinking it would be AWESOME to have a complete stand alone A.I system for tuning. Would probably take all the fun out of it lol
Old Apr 15, 2025 | 11:30 PM
  #5367
Yariv's Avatar
As I wrote before, after 10-12 VE learn sessions, I started using GPT. Using this feature in TunerPro, I exported the data (bin) to a text file and fed it to Chat GPT.
Old Apr 16, 2025 | 11:56 AM
  #5368
Buccaneer's Avatar
Axle/Gears: 3.31
That is obviously a NEW feature in TunerPro RT, newer ver than 5.0? I'm still using the older ver 4.14 that I like and works.
Old Apr 16, 2025 | 12:09 PM
  #5369
Yariv's Avatar
VE learns are part of the WUD software.
Old Apr 16, 2025 | 02:10 PM
  #5370
Buccaneer's Avatar
Axle/Gears: 3.31
WELL aware of What's Up Display capabilities, but you made it sound that Tuner Pro was involved, not WUD. I've only been using EBL for over 12 years now though.
Old Apr 16, 2025 | 02:37 PM
  #5371
Yariv's Avatar
You can smooth with TunerPro RT (I'm using ver 5). But I let GPT to do the smooth. I also tried as @drive it suggested. I got almost similar results.
Old Apr 18, 2025 | 08:54 AM
  #5372
PlayingWithTBI's Avatar
Car: 88 C1500 Silverado
Engine: 383, XR282HR CAM, Al Heads.
Transmission: Phase 2 700r4 w/2300-2500 TC
Axle/Gears: 4.10
IMHO, the "Interpolate" (in TP Pro 5.0) function works better/quicker than simply smoothing.
BTW - I haven't been here in a while but, on another forum I heard someone may take over running/building the EBL. Has anyone heard this?
Old Apr 18, 2025 | 12:30 PM
  #5373
drive it's Avatar
I haven't heard of that, but I think it would be fantastic to see Bob's legacy continue.
Old Apr 22, 2025 | 06:25 AM
  #5374
Yariv's Avatar
Hi, I know you are using Camaro, and this parameter might be irrelevant. I'm running EBL on my 1985 Corvette.
Entry: DGD - Injector Flow Scalar
Value sent to the Digital Dash (Corvette CrossFire's) as the injector flow rate constant. Used to
calculate the MPG and fuel used values. The value to be entered is the flow rate of one injector in
pounds per hour. If using a 4bbl or dual 2bbl TB's, the flow rate is that of two injectors in pounds per
hour.
With the various densities of fuel this value may need to be tweaked a little. Increasing the flow rate
will lower the MPG.
My DGD parameter is 47.2 (I cannot remember why I put this value). The Vette consumed about 24.5 MPG (full, drive, full). The DIC shows much worse, about 19 MPG. How can I fix it? My injectors are Bosch III 25.4 lbs.
Thank you.
Old May 17, 2025 | 09:40 AM
  #5375
tuningnewb's Avatar
Need help with WUD
I put the WUD on a new computer, and it seems to work. I can read all the sensors, record a data log, look at trouble codes, etc.
However the option to FLASH a new BIN is grayed out. I've never experienced this before.
Anyone have any suggestions?
Old May 17, 2025 | 10:04 AM
  #5376
billvv's Avatar
It's possible that the serial connection for the 'receive' wire (at the ECM) is open, or that another application has grabbed the 'transmit' signal on the computer. I had that happen when I was sharing the com port with WUD and WinLog-EBL (with com sharing software). I could see a screen and datalog for both applications, but when I needed to flash I had to close the WinLog-EBL screen.
Old May 17, 2025 | 10:11 AM
  #5377
tuningnewb's Avatar
Any thoughts on how I would check the 'receive' at the ECU? I rebooted, and went to WUD without opening anything else, so I don't think it is a conflict with other software.
Old May 17, 2025 | 01:36 PM
  #5378
Buccaneer's Avatar
Axle/Gears: 3.31
Just curious, what version of Windows are you running with WUD?
Old May 17, 2025 | 02:32 PM
  #5379
tuningnewb's Avatar
New computer is Windows 11. Old one was Windows 10.
Old May 17, 2025 | 07:12 PM
  #5380
Buccaneer's Avatar
Axle/Gears: 3.31
OK, thanks. Well, that's odd, never saw that before and have been using EBL for 12+ years now. Did this jus happen when you loaded it to the new laptop or did it also that this with the old one?
Old May 19, 2025 | 06:39 AM
  #5381
tuningnewb's Avatar
I never had the problem before either. This is my first time trying to FLASH with the WUD on the new computer so I don't know if it has always been an issue on this new laptop or something changed. Like I said, all the other features are working normally.
I also tried to run WUD 'as administrator' thinking maybe there was some permission issues in Windows, but that didn't help.
Old May 19, 2025 | 09:49 AM
  #5382
drive it's Avatar
I would try the uninstall and reinstall.
Old May 31, 2025 | 06:58 PM
  #5383
GrimsterGMC's Avatar
Car: GMC Seirra K1500
Engine: 5.7 TBI
Axle/Gears: 10 Bolt 4.11:1
G'day, I am just getting back into tuning my 1988 K1500 with 350 TBI/ 700R4/ 4.11. It is all stock except for Hedman long tube headers and has 280,000 miles on the clock. It has been some time since I set up my current tune and over that time I have been doubting myself as to whether I was on the right path, so I thought I would start again from scratch with the benefit of having read alot more on here about it. The one question that has me perplexed is the starter bin provided on the disc. I am using EBL F 2011 as per my truck, and I set the BPC calculation from the EBL Utility at 164 for 55#/Hr injectors running 11 PSI. Now when I go out and do a Open Loop wide band VE learn the WB shows it running at AFR of 9 and the VE learns show -12 everywhere. I tried taking 10% of the whole VE table and was still showing -12 everywhere so I did the -10% again and it came up to AFR 10 but still -12 across the board. My question is should I be changing the BPC setting, and therefore everything else that is associated with it, or should the VE tables be dropped considerably. Why this has me perplexed is I can't understand why Rob would have provided a bin with the base VE tables so far from ideal? When I looked at the factory tunes VE tables they are considerably lower than the EBL bin. I am aiming for a tune that provides smooth running and acceptable mpgs as it is my daily driver. Any advice will be much appreciated.
Old Jun 1, 2025 | 09:42 AM
  #5384
Ccato's Avatar
Engine: 383 Stroker
Axle/Gears: 373
Hello,
First time posting and hoping for help with my tune. I've been running EBL for about 6 months and still trying to move past open loop. 1991 K1500, Smeding 383 Stroker 407hp/462tq 9.8:1 compression, 212/222 duration @.050, 700r4, and SPR Performance 46mm throttle body with matched 65#/hr injectors (actual flow 78#/hr), set at 14 psi. I have finally installed a WB O2, which has drastically helped with VE tables. I ran out of room on the table, so last week I adjusted BPC and working to get the lower MAP areas dialed in. I did try transitioning to closed loop but my VE tables were going through very large changes, so I am back to OL. SA tables are based on 84Elky thread, no further adjustments made yet but it REALLY woke the engine up. For the VE learns I have disabled PE, DFCO, Hiwy, and BLM/INT locked at 128. Apart from some idle adjustments, AE - MAP PW and AE - TPS PW were reduced 25% to account for injector changes. I have tried O2 gain adjustments with PRP - Gain Multiplier vs Airflow and Gain vs O2 Error in either direction with no change in my O2 mv or gms/sec.I have gone as far as increasing one or both by 25%, and decreasing by 50%.
1. For SA tables in the high MAP and low RPM area, should this be decreased and why? Most references I see have this area reduced significantly. I have experienced 0 knock with any table used. I know my sensor works as I get a false knock when turning off the engine due to an exhaust rattle (new muffler and hangers ready to be installed). I want to tow with this truck if that helps.
2. Do prop gains affect OL? I haven't seen a meaningful change in the O2 mv or gms/sec. As I understand these should be around 6-7 at idle for my application.
3. Injector DC is at 80% WOT with my adjustments to AE, but idle is at 6%. Is this appropriate?
4. I want to start incorporating PE and Hiwy lean cruise, when is an appropriate time in the tune to add these back in?
5. What next steps do you recommend?
Attached are some images of VE, SA, and datalog. Datalog has mixed driving, WOT from a stop at 14:30 and 15:30. Thanks for the help
File Type: csv
Old Jun 1, 2025 | 09:59 PM
  #5385
Ccato's Avatar
Engine: 383 Stroker
Axle/Gears: 373
GrimsterGMC, I think we've chatted a couple of times over at GMT400. I had a hard time getting my VE tables dialed in but finally figured it out with enough trial and error. Whatever changes you make to BPC you must do the inverse to your VE table. So if you decrease BPC by 5%, increase VE table 5% and that will get you much closer for the next learn. The values I landed on seem to be working well even though it isnt identical to the EBL utility. The more spread you have under "100" the better the fidelity. The VE table will resemble your torque curve.
If you changed injectors, check the flow rate and adjust accordingly in AE - MAP PW and AE - TPS PW. My setup is at 14psi and I have 65#/hr injectors that flow at an actual rate of 78#/hr @14.7psi. Stock injectors were 61#/hr I assume at about 13 psi. So calculate (StockFlow/NewFlow), or (63#/hr / 76#/hr) = 0.82 for my application. Highlight the cells in the two AE tables and multiply by your flow difference. Here is the calculator I used for mine. Fuel Injector Calculators – DeatschWerks. That will also affect your DC%. This can be taken a step further with adjusting the duration via AE - MAP Filter and AE - TPS Filter, but I have not done this yet. As I understand a lower value yields a slower flow but nets higher volume.
Adjusting BPC and AE tables brought my VE tables from a low of 16 and high of 53 to a spread of 27 to 98. Last week I ran out of room and had cells exceeding 100, so I increased my BPC and decreased VE +-7%. You may have to do the opposite. I hope this helps.
Old Jun 2, 2025 | 12:30 AM
  #5386
Engine: 5.7 TBI
G'day mate, thanks for the reply. I was just reading your thread over on GMT400 and followed you. I will read up on what you have done as it relates to my situation.
Old Aug 24, 2025 | 03:36 PM
  #5387
Ryangreen19's Avatar
Car: 1968 C10
Engine: 327 w/TPI EBL P4
Transmission: TH400
After chasing a no start issue and replacing the distributor to fix it, I am starting over with a fresh tune. I am happy with the VE learns so far but I am running into an odd issue where the ECM appears to lose power for a second or so while driving. I have captured it in a datalog when this occurs. The engine stumbles for a brief second and then continues to run. Datalogging continues. I noticed that the Prom ID is blank as well.
Is this a sign that the 12v ignition power connection or the ECM grounds are unstable? It is rare that it happens, perhaps once in a ten minute drive.
Does the EBLP4 setup have a battery that allows this datalog to occur and capture the issue even though 12v ignition power could be missing?
If there is no battery to power the ECM, then its not likely a complete power loss is it.
Ryan
Old Aug 25, 2025 | 08:05 AM
  #5388
tuningnewb's Avatar
yes, sure sounds like an electrical issue. Bad grounds can cause a lot of strange things to happen.
What happens to all the other electronics in the car when this happens? Do you see the tachometer bounce around, or lose any lights, instruments in the dash?
Ryan
Old Aug 30, 2025 | 05:00 PM
  #5389
Car: 1968 C10
Transmission: TH400
To be honest I have no idea what happens to the rest of electronics. Good point. See if this issue is isolated to the ECM or the whole car. It is so brief, it is hard to watch for. I only experience it as a very brief stumble and can then find it in the datalog.
Old Sep 6, 2025 | 02:43 PM
  #5390
Originally Posted by robertfrank
So I'm battling a few things that I'm sure you guys can help me with. I've noticed that I'm having too much residual fuel in my low map (20-25map) when i let off of the throttle. its causing super fat spikes then levels out. What tables should i adjust to dial that back a touch? if I take fuel from there its fine for the before said situation but if I'm trying to tune those areas with throttle I'm way too lean i.e. when going downhill with throttle. Also, I'm chasing knock like a ****. Attached are my current Main Spark table and the most recent learn I did showing what I'm seeing. I really don"t want to keep removing spark to not make the engine lazy. What are your thoughts?
So I'm revisiting this issue sans the knocking (turns out it was a bad intake pushrod). I'm still getting a pretty good rich spike on the throttle lift in the low map areas. I set my enleanment factor to .98 and it hasn't helped as much as I'd like. Letting off the the throttle i spike to about 12.8-13.5 but If I lower the VE tables in those areas during actual throttle it runs lean at around 15.9-16.3 in the 20-30 MAP. how can I reign it in ?
Old Mar 31, 2026 | 10:07 AM
  #5391
ACMX92's Avatar
Car: 1985 Corvette
Engine: 1985 L98 350, stock for now
Transmission: ZF S6-40 6 speed
Axle/Gears: Dana 44 3.54s
I wanted to throw my current BIN and most recent WOT datalog up here for some critique. I have a ZF6 swapped 85 Corvette running Flash II. Bone stock bottom end, 10.0:1 compression, AFR 195 Comp port heads, 280XFI roller cam, 1206 Miniram intake, 36lb/hr injectors, 52mm BBK throttle body, long tube headers, x-pipe into LT1 mufflers, 3.90 gears. Dyno last year was 340whp @ 5900RPM and 310lb/ft @ 5400RPM. Had issues with erratic rpm signal above 5000rpm and the throttle cable was too long so I was a bit shy of WOT. Manifold pressure at the end of the pull dropped to 93kpa. After fixing the throttle I now have 96kpa all the way up to the 6400rpm redline. A new small cap HEI distributor also significantly cleaned up RPM signal.
I have done a ton of revisions to this tune (67 since the H/C/I swap, 45 updates with the stock L98 before that). I am pretty happy with WOT performance and plan on going back to the dyno and/or the drag strip soon to see if I have improved on some areas. My focus lately has been CL cruise and MPG. Idle quality is great in my opinion considering the cam I am running. It is pretty happy around 850RPM with 57kpa of manifold pressure. AFR hovers around mid to high 13s. Now I am just fighting some erratic AFR and light surging during cruise. I have played with Prop Gains and swing points and it has gotten better but I feel like there is definitely room for improvement. NB learns are still pulling fuel in spots. My last tank of gas with a bunch of highway driving was about 14mpg. Anyone here running a similar setup with any suggestions for improvement? I know a lot of people at this point just stick with open loop but I am not giving up just yet lol
Attached Thumbnails Tuning with the EBL-wotdl.png   Tuning with the EBL-sa.png   Tuning with the EBL-ve.png
File Type: bin
File Type: csv
Old Mar 31, 2026 | 12:25 PM
  #5392
dabomb6608's Avatar
I get some of that erratic AFR and surging as well. Given we both have manuals and similar(ish) setups it might just be nature of the beast when it comes to tuning these cams on a batch fire setup.
BTW, give this XDF a try. You can hover over any parameter in tunerpro and it will show that parameters description which I pulled from the EBL documentation files. It is a huge assist when playing with things.
File Type: zip
Old Mar 31, 2026 | 12:30 PM
  #5393
???'s Avatar
brilliant.. I was thinking how annoying it is that nothing was commented like I'm used to seeing with other codes.
will he down loading this soon.
Old Mar 31, 2026 | 03:06 PM
  #5394
ACMX92's Avatar
Car: 1985 Corvette
I figured that as well, but wanted to make sure there wasn't some sort of major BLM change someone with a similar combo came across that would smooth things out. I'm still really happy overall though. I figured anything below 2000rpm would be almost useless with this cam but I've been able to get it to cruise happily as low as 1400rpm with light load. Just has the occasional surge at cruise that usually clears up pretty quick.
Thanks! That XDF is awesome! I've had the EBL calibration tab open in my laptop web browser for years now going back and forth xD I was thinking today how nice it would be to have a way to highlight areas during a datalog, read through the WhatsUp document and realized the space bar or tab key already does that. So that is my next plan is to start marking problem areas in my tune and start manually adjusting the VE and SA tables to smooth it out a bit more.
Old Apr 1, 2026 | 03:29 PM
  #5395
dabomb6608's Avatar
Sounds snappy for sure. I'm wanting to get my AE to a point that it revs snappy like that.
Couple things I noticed on your tune that may or may not be hurting you.
Launch mode is active, I've always thought that was more for auto cars to get up against the converter sooner. Mine is zeroed out.
Static SA at idle isn't set. I like having a static SA in idle mode. I then make sure the SA main table also matches idle SA around idle rpm/kPa.
Your SA idle high low compensations are abrupt. I tamed mine down for the first few rows to make it more progressive.
Might read up on SA - Latency. I don't have a right answer for you but it can have wide effects on SA.
INJ - Small PW Correction - Port Only I thought it was always recommended to 0 out that table. Thats how mine is setup.
Old Apr 2, 2026 | 03:11 PM
  #5396
ACMX92's Avatar
Car: 1985 Corvette
I forget who I grabbed the TPS AE values from but they are massively increased compared to stock. It seemed too absurd of a value to work but it completely cured any lean bog I had prior. It is also very short duration so by the time I grab the next gear my AFR corrects within a frame or two. I tried setting the ICbAE flag the other day to see how that worked but it killed a lot of my AE and felt terrible.
I actually disabled launch mode yesterday after reading some of your posts and going through your tune. It definitely makes taking off from a stop so much smoother. Especially since I have a twin-disc clutch with an aggressive compound.
I've been so happy with the idle with this cam that I figured the compensation wasn't hurting me. I did take your advice and try to smooth out the idle area and compensation tables. I am curious if that will make a noticeable difference. I also want to try and get it a bit leaner in closed loop. It idles in the high 12 low 13 AFR window. Overall I have been happier with my idle quality after the H/C/I swap than I was with the stock top end tune.
I've played with the latency table, I had a lot of KR on my stock L98 tunes and tried all sorts of things to figure out why I was getting knock despite commanded SA being in the low 20s. I think most of my issues there were really from insufficient AE. My AFR would spike lean on matched downshifts.
After swapping to a small cap HEI and my timing seems to match what expected peak timing should be and I have almost no knock. I might see 60-80 counts on the WUD during a 20 minute spirited drive.
I tried looking for some more info on the small PW correction and there doesn't seem to be much chatter coming up on a google search. I haven't changed it yet but I might play with that next after I test out a few more changes I made today. I pulled 6-10% of fuel out above where I believe peak torque should be for this top end and I'll do a few pulls and see what the wideband shows. Previously, my VE table was increasing all the way to redline.
I appreciate you taking a look and offering some advice!
Old Apr 2, 2026 | 03:25 PM
  #5397
???'s Avatar
I don't know if the flash is the same as the p4 but when I was searching the tuning thread for injector data, what I found for my injectors showed some data for the small PW correction, so I pasted it in.
the searchable pdf of the tread is very helpful
Old Apr 2, 2026 | 09:13 PM
  #5398
ACMX92's Avatar
Car: 1985 Corvette
After some research I think I have a good understanding now but please correct me if I am mistaken. The minimum linear PW for the 36 lb/hr Accel injectors I have is 1.38ms, so I do not need a small pw offset for any PW greater than that since they should all be covered by the main injector correction table. For smaller PW I just made sure to set my enter Async at 1.38 and exit at 1.68. I am only in this range at very low map while coasting so I can't imagine these changes will do anything other than save a bit a fuel on decel, which I am all for. Since I have zeroed out the small pw offset table I am curious if I will see a noticable change in WB AFR.
dabomb6608, I did try to match the SA idle high and low compensation tables and I feel like I need to go with a middle ground. The less than 2 degree SA swing allowed my idle to fluctuate almost 100rpm in either direction. I did pick up a few kpa of vacuum by flattening out the SA and VE tables in my idle areas though which is cool. I'm also idling a bit leaner like I hoped for.
Now I just need to see how the injector changes do and try to tighten up my AE a bit more. Goal is to hit the track on Wednesday so I'll probably switch back to open loop for a bit and do some wideband learns. I have made so many changes lately that I want to make sure I don't go too lean up top. Datalog show a few spots above 5600rpm where I get above 12.8:1, which is likely from the VE I removed after what I believe is my torque peak. I'd like to hit the dyno again too. Feels like I have picked up a ton of power since I did this pull.
Old Apr 4, 2026 | 09:58 AM
  #5399
dabomb6608's Avatar
One thing I learned to watch on my idle was what my VE table was doing at that spot. I initially had a large increase as kPA increased. That caused fueling to oscillate which in turn caused idle to as well. I just reviewed a datalog from yesterday and looks like mine does tend to vary by a 100 ish rpm though. I might give it a shot bumping my SA comp tables a little if you had good success with it.
Old Apr 23, 2026 | 07:31 AM
  #5400
dabomb6608's Avatar
I've noticed a discrepancy on some descriptions for AE Filters within the EBL documentation vs what I have found in this thread.
In documentation it says " A table of TPS filter coefficients based on coolant temperature. Used to lag the TPS value used to create the delta MAP term for AE PW. A smaller value will be a greater lag. Used to determine the duration of the TPS based AE. Also affects the magnitude of the TPS based AE." Within this thread I see it mentioned several times that the filter would be lowered to make AE come in sooner. So opposite of what the documentation says.
I want to make sure I have it correct as I am actively making changes to my AE and also want my modified XDF to be correct as well with the descriptions I added for each parameter. Can anyone verify which is correct? Intuitively a higher number is more filtering with greater lag...
