Tuning with the EBL
Car: check
Engine: check
Transmission: check
Re: TCC Question
I ran a dyno the other day. I was fortune to have been able to datalog during this. I noticed my TCC indicator light in EBL turns on at 48 mph (lock up), then at 68 mph it would turn off ( un-lock).
Isn't the convertor suppose to stay locked?
LoGR ok to lock .... set to 48 mph
LoGR ok to unlock ....set to 42 mph
HiGR miles to Unlock....set to 44 mph
TCC-forced lock .... set to 100 mph
I'm not findind a scaler or table that is telling the TCC to unlock at 68mph, so why would it be unlocking?
thanks
thanks
There is a TCC write up in the Tuning Guide Book sticky, chapter 5, under the '8746/'7747/'8063 ECM section.
RBob.
Re: Tuning with the EBL
the AE PW tables are set for 64 usec increments.
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
My fault for not mentioning in my last post that the AE-RPM Multiplier is (I think) the most often used AE modifier, really it depends on what your trying to accomplish.
Edit:AE-RPM will also have a minimum resolution.
Car: Corvette
Engine: 388 HSR custom Cam see sig
Axle/Gears: D44 3:45
Re: TCC Question
LoGr is 3rd correct?
HiGr is Overdrive correct?
Dyno was done in 3rd gear, so far I'm understanding that if the TPS% opens 46.05% at 70 mph it will unlock ( that % came from my .bin in the LoGR TPS% to unlock). I'm assuming that % is basically how far open your blades are.
Under a normal cruise does it unlock because its less strain on the driveline and gives you better fuel mileage?
Since the ecm has no seperate table for the TCC to stay locked while in PE mode it will lock and unlock correct?
What would happen if I force lock it at say 50 mph? And would this best be used when running a dyno or track?
or
should I be thinking more in the lines of changing my % in the LoGR TPS% table to something closer to 100% and leaving my HiGR alone so while cruising on the highway its working as it should?
sorry, I know alot of questions in this post
Car: check
Engine: check
Transmission: check
Re: TCC Question
I've read that thread several times but I will need to read it several more times for it to sink in.
or
or
During normal cruise the TCC should be locked. Even when the stick is in 3rd and going say 40 MPH.
No separate table for PE mode.
Be careful with the forced lock MPH. Too low and it can eat the 3/4 clutch pack. It can also eat the TCC clutch.
Be sure that the WUD is correctly displaying D and OD. That is no OD display until the trans actually upshifts to OD.
There is an option flag to set the 4th gear switch as NO/NC in the calibration.
RBob.
Car: 87 Suburban 2500
Engine: 455 Wildcat ( somewhat modified ))
Transmission: TH400 ( for now )
Axle/Gears: 4.10 ( for now )
As far as your throttle issue, it sounds like there isn't enough cable travel for the throttle body. Do you have an adjustable throttle cable bracket? If so you may need to move it backwards (away from the TB). Disconnect the throttle cable and see if you can pull it forward past the throttle body linkage. If you can you could probably adjust it to get the last of your throttle travel.
That last 4% makes little difference at WOT as compared to idle, but might as well have it reporting correctly.
Think I ended up bending the bracket a little to get WOT at 100%, then the ECM sets closed throttle at whatever it reads at start-up.
As long as you can hit the mechanical stops at both ends, you're good to go.
Engine: 350 TBI
Transmission: manual
Axle/Gears: 4.11
Has anyone tried using a calibration bank for anti-theft? I'm considering using the flash switcher as a sort of electronic key so I can turn the car "off" and take the switcher with me or lock it in the house. I've been experimenting with valet mode, but thinking of a step beyond that.
Car: '92 GMC C1500 RCSB
Engine: TBI + Vortec + EBL 383
Transmission: 4L60
Axle/Gears: 3.08
I think that with the valet mode set to an unreasonable fuel cutoff, etc. it would be pretty much enough. The only way would be if they realized what they had to do to get around it. Something else you could do would be to set up a latching relay, and use one of the factory switches to engage it. The way it works is once there is power applied to the supply side, you hit the 'trigger', and the way the relay is wired it stays that way until power is interrupted, then it kills power to the circuit again. So if you have it wired into, say, the fuel pump circuit, you would turn the key on, hit your "hidden" button that's in full view, and start the vehicle like normal. Once you turn the vehicle back off, this circuit is severed automatically, and the only way it will run again is if you hit your secret button. You could also set this up with an unused circuit in the fuse panel. Say if you take it somewhere to have it serviced (alignment, stuff like that requiring special equipment), you could insert a small current fuse into this specific circuit, and the vehicle would operate like normal. When everything is done you just take the fuse out and plop it in the glove box... back to secure
I have all kinds of ideas like this rollin' around in my brain.
I have all kinds of ideas like this rollin' around in my brain. Moderator
Car: check
Engine: check
Transmission: check
I've also zeroed out the VE table. Engine won't run without fuel. Doesn't even have a hint that it wants to run.
RBob.
Engine: 350 TBI
Axle/Gears: 4.11
Thanks for the input. Zero'ing the fuel is what I was thinking but unsure. I played with the valet mode this weekend and didn't quite get the hang of it - found myself jack-rabbiting out in traffic and having to restart in the middle of an intersection. Operator error but still unnerving. I watched the WUD more carefully after that. The one thing that I wasn't sure about is how the MPH fuel cutoff works in conjunction with RPM timing retard. I could get the speed up to 20-30 MPH by keeping the RPM's below the timing cutoff. I had the MPH fuel cutoff set at 6 MPH and thought it would have kicked in and it didn't. I wondered if the MPH fuel cutoff is applied only if the RPM timing limit is already exceeded. I read the calibration html file but it didn't sink in the first time. I have to give it another try this weekend. Thanks again!
Car: check
Engine: check
Transmission: check
There is a stall saver RPM limit. If the engine speed is below this value the fuel won't get cut.
OVSPD - Stall saver RPM
RBob.
RBob.
Car: Red 91 RS Camaro
Engine: LO3 with Comp Cam
Axle/Gears: 4th gen rear
What do I change to raise the lean cruise minimum value so that I can let the VE learn work a lot more of the time?
Also What disables the EGR in the BIN?
Car: check
Engine: check
Transmission: check
EGR disable is usually by the CTS threshold. The EBL Flash also has an option flag to enable/disable the EGR.
RBob.
Car: check
Engine: check
Transmission: check
Its been a while since I have been in here. Summer tune went pretty well. Now its Fall and cooler temps. One thing I haven't resolved yet is the Hole Shot. Sitting at idle and mashing the pedal. I get a pause about 1/2 sec if not longer before I get an engine response. What would I look at to adjust. Its not backfiring so it may not be lean, not sure. I need the tables that would help with this. As always .. Thanks
Scott
1988 1/2 Ton 4 W/D Suburban
383 Stroker (Roller)
Performer Edelbrock Manifold
670 CFM Holley TBI
3" Exhaust No Cat(shhhh), Flow Master 40
190 LPH In-tank Fuel Pump 21 PSI
EBL (Dynamic EFI) Computer
Scott
670 CFM Holley TBI
Car: 1991 Pontiac Firebird
Engine: 355 TBI
Transmission: 7004R
Axle/Gears: 3.27/42 ?
I have the same issue with my tune. I'm not sure if its because of my stock torque converter or the tune but I cant burn out without the brakes from a dead stop because of the hesitation at take off. I would assume it has to do with some adjustments to the AE but lets see what the experts have to say.
Engine: 355 TBI
Transmission: 7004R
This thread, second from last post by TrofeoS/C has a Vortec timing table in it:
https://www.thirdgen.org/forums/diy-...ark-table.html
As for the AE, if the engine chugs a little then goes, it is too much AE. If you get a cut-out and/or pop then it is not enough AE. Can also look at the INTegrator during/after the period of AE. If it is dropping then too much AE, and if increasing then not enough.
A slight increase in the INT along with good throttle response is the ideal situation.
RBob.
RBob.
I think this might be able to help us out with out take off issue, Scott. Thanks RBob.
BIG displacement engine.
TBI.
Heavy truck.
OK, if I "mash the pedal" on my bored 455 TBI in the 3/4 ton, it'll miss at best.
It'll sometimes die completely.
If I roll on the pedal, fairly fast but not a stomp, I have a wheel spin problem in a 6000 pound truck ! Why ?
Well, it's TBI, so at idle we have a lot of vacuum in that manifold, with a little mixture flow. Assuming it's warmed up, ( it's a lot worse when cold ) what happens when you snap the throttle ?
The engine doesn't turn much, but the blades go full open fairly fast. Pressure in the manifold rises rapidly, pretty much before the fuel can move, so the fuel in the manifold instantly condenses out, falling out of the air, and wetting the manifold. Air flows into the cylinder(s). Air by itself won't burn, so the engine doesn't do anything, except miss, or lose a few RPM. It's gone ultra-lean, but there's not even enough fuel to backfire. The pump shot, AE shot, has dumped fuel into the almost stopped air flowing into the manifold, but it doesn't get to a cylinder for a while. When it does, if it hasn't picked up too much of the fuel condensed onto the manifold surfaces, it might fire. If it has picked up fuel from the manifold surface, we have a real rich mixture, which again may not burn at all. By now, the engine is real close to flooded, and stalling completely.
Eventually, all this stuff clears out. 1/2 second or so. Maybe more, maybe less.
If the engine is still turning, a cylinder can ingest a flamable mixture, and the engine can then re-start and run.
This doesn't happen with port injection. The ECM can have the cylinder ingesting a flamable mixture immediately, so there should be no hesitation at all.
Now, what happens if I "roll" on the throttle, taking 3/4 second or so to hit WOT ?
The mix in the manifold has time to accelerate towards the cylinders. Pressure doesn't come up fast enough to condense and rain the fuel out of the air, so I get a flamable mixture of about what I want. Cylinders fire. Mixture accelerates and rams into the cylinders. Torque comes up rapidly. In my case, enough torque to break things if I'm not careful. Typically, the drive wheels lose bite even under 6000 pounds of steel, make noises, and the truck slowly starts to move. You're NOT going to accelerate 6000 pounds of anything instantly. ( unless you hit it with a train ) Give it a second, and it responds nicely.
Now, if I hold the break, bring the engine up against the converter, THEN mash it as I release the break, it's a whole 'nother story. Torque is applied against things already wound up, so nothing breaks, except traction. Mixture is already moving through the manifold, so it doesn't hesitate, it just goes.
Stay just below the traction limits, and things happen in a happy, and impressive fashion.
As I recall, it's all very consistent with the way the pro-gas car used to respond so many years ago.
Part of going fast, is driver technique. I don't want to hit my truck with a train. Sure, that'll accelerate things, but in a destructive fashion. I want to push it with all the torque it can take, but no more.
SO, my question back to you, is what happens if you roll on the throttle, taking 3/4 second or so to hit WOT ?
Are you sure you're not asking something of TBI that it simply can not do ?
Transmission: TH400
Keep adding early AE till it says 'nuff.
One benefir of the EBL .xdf is ability to add fuel at lower RPMs. One over 2000 you can trim back values using RPM modifier. I have light car and in RPM AE table I have at 600rpms 46% and 2000 4% then I pull fuel equally with neg% to -50% at 4800 rpms.
I found the need with my cold manifold to bring in AE sooner. My AE filters are at 3.5% at running temps.
All of the symptoms you are witnessing I fixed in those tables.
Well Great info. There are:
AE-Map filter
AE-Map PW
AE-Tps Filter
AE-Tps pw
AE-Cts multiplier %
Ae-RPM Multiplier %
So, I wanted guidance on what will effect what. Always a great help from all of you.
Regards,
AE-Map filter
AE-Map PW
AE-Tps Filter
AE-Tps pw
AE-Cts multiplier %
Ae-RPM Multiplier %
Regards,
Engine: gone
Transmission: gone
Axle/Gears: gone
Man i am goign to have to spend a whole day reading the 33 pages of this thread..(headache is happening)
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
Am sorry to interrupt the thread, but am in need of the more knowledgable- Voltage to FP shows 6.8,pump does not run.I bypassed wiring to pump direct to battery and pump and engine runs, so I ran new wire from relay (orange 12v supply ok) replaced tan/white just out of relay,picked up oil press sw, and ran back to tank. Engine starts and runs ok,but EBL display shows 0 volts to FP and sets SES.I was ready to splice in a section of the old harness to feed signal to ECM,but am at a loss as to whether or not is there a voltage modification to the FP circut in the ECM? Could such circut in ECM be the source of this low voltage? I have noticed in old logs that FP voltage is sometimes higher than Batt,which seems like a pertty good trick,unless the Batt is drawing charge. I have looked thru wiring diagrams but have not found even a hint. Thanks, Val
Car: check
Engine: check
Transmission: check
The ECM provides 12 volts to the FP relay coil. This is to activate the relay to power up the fuel pump. It is common for the transistor that provides the +12 volts to the relay to fail. It is also easy to replace, there is a thread on the DFI & ECM board that has pictures.
The BAT gauge on the WUD is really the ignition switched power. The annunciation for this has been changed to IGN.
RBob.
RBob.
Car: 91 Z28
Engine: Dart 406ci, Miniram
Transmission: TCI 700r4
Axle/Gears: 3:73
Ok here is my ?, I have a mini ram 406 With ZZ10 cam, Having some issues getting it to idle. Any pointer you guys have please fire them this way. thanks
Thanks for the reply,but the relay coil circut(455/A1) is intact and functional,the circut in question seems to be called FP/signal (120/B2 in alldatapro wiring diagram) and connects the ECM into the relay power out line to the fuel pump.Sorry for the confusion,Val
Car: check
Engine: check
Transmission: check
Note that the ECM also uses the FP voltage for the injector compensation. So it is important to have it connected to the ECM.
You can also find wiring diagrams on our web site:
www.dynamicefi.com/EBL_Drawings.php
RBob.
Car: check
Engine: check
Transmission: check
RBob.
Car: 91 Z28
Axle/Gears: 3:73
This is with the EBL P4, I have only adjusted the idle ranges i have it idling at times for a min then it tries to dip around 450 rpm and it just wont have that. I have added fuel and a couple of deg of timing to the ranges of 800-400 rpm
Car: check
Engine: check
Transmission: check
On a warmed up engine shoot for 20-30 IAC steps with no load.
RBob.
Car: check
Engine: check
Transmission: check
Car: 91 Z28
Axle/Gears: 3:73
This is how my low speed ve table looks
27.84 28.63 34.51 38.43 47.06 52.16 56.08 56.86 58.04 59.22 60.00 63.53 66.27 70.98
31.76 34.51 38.04 41.96 50.59 54.90 57.65 58.82 60.39 61.57 62.35 64.71 66.67 70.98
33.73 37.65 41.18 46.27 55.29 59.22 61.18 62.35 63.92 65.49 66.67 68.24 69.80 73.73
38.04 41.96 45.49 49.02 59.22 61.18 63.14 65.10 65.88 67.45 69.02 70.59 72.94 75.29
39.61 44.31 49.02 52.94 61.18 63.14 65.49 67.06 68.24 69.41 70.20 70.98 72.94 75.69
41.18 45.49 49.80 54.12 62.75 64.71 66.67 67.84 69.02 69.80 70.59 71.37 73.73 76.08
47.06 51.37 55.69 59.61 63.53 65.49 67.45 69.02 69.80 70.20 70.98 72.55 73.73 76.86
48.63 52.94 57.25 60.78 64.31 66.27 68.63 69.80 70.98 71.37 72.16 72.94 74.51 77.65
49.41 53.73 58.04 61.96 65.49 67.45 69.41 70.59 71.37 72.16 72.94 73.73 74.90 77.65
50.59 54.51 58.82 62.35 66.27 68.24 69.80 70.59 71.37 72.16 72.94 73.73 75.29 77.65
51.76 55.29 58.82 62.35 66.27 68.24 69.80 70.59 71.37 72.16 72.94 73.73 75.29 77.65
52.94 56.08 59.61 63.14 66.67 68.24 69.80 70.59 71.37 72.16 72.94 73.73 75.29 77.65
53.73 57.65 61.57 64.31 66.67 68.24 69.80 70.59 71.37 72.16 72.94 73.73 75.29 77.65
54.12 58.04 61.96 64.71 67.06 68.63 70.20 70.98 71.76 72.55 73.33 74.12 75.69 77.65
54.90 58.82 62.75 65.10 67.84 69.02 70.59 71.37 72.16 72.94 73.73 74.51 76.08 78.04
55.29 59.22 63.14 65.49 68.24 69.41 70.59 71.76 72.55 73.33 74.51 75.29 76.86 78.04
55.69 59.61 63.53 66.27 68.63 69.80 70.98 71.76 72.94 73.73 74.90 75.69 77.25 78.43
Car: check
Engine: check
Transmission: check
The idle areas will be in the low speed VE table. You can also set up and run auto VE Learns. There is information on setting up and running them in both the Intro to Tuning on our web site, and the What'sUp Help file that was supplied on the CD.
If you did the standard install of the CD there is a program group for the EBL P4. Within that group are three help files: calibration entries, the What's Up Display, and general info.
RBob.
RBob.
Car: 91 Z28
Axle/Gears: 3:73
well my car cant go on the road im just trying to get it idling good then ill do that, I do have to be on the road for the VE learn correct?
Car: check
Engine: check
Transmission: check
Thanks for the info,I had disabled the flag to dump the SES but suspected that the input might be used for fueling/something other than the WUD. The pin outs are always good to have,(printed them out at the get go)but I guess the unknown is what else does the FP signal (B2)influence. It is very nice to have a source that knows all of the inner workings of the little devil,again, Thank You. Val
Well, no, but it is longer than mine. ( slightly, but then so is my truck )
It's already in the docs, as I recall.
Basically, you connect the wires to the header on the terminals you like, tell the software that it's there, what kind it is, and you're pretty much done.
Car: check
Engine: check
Transmission: check
no bueno
Alfred, to the bat-cave!
