TRAXION
Old Oct 29, 2000 | 10:00 PM
BlueBottleJunky's Avatar
TRAXION
I see you recently went to the mini ram and picked up a little over 3 tenths and what...4 mph... Is the car a little sluggish on the street now? Ive been told the mini ram is kinda tempramental on the street.....but goes like hell at the track...BTW....what cam ya runnin?
Old Oct 30, 2000 | 08:07 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
BBJ,
Two of the reasons that the MiniRam gets bad publicity for low RPM operation are...
1) Tuning
2) Gearing/Stall
You have to tune and gear the car appropriately.
On the street with drag radials and all of my traction mods (see web page) I can roast the tires through all of first and most of second. How's that for torque? I am running a 2800 stall converter and 3.73 gears.
It drives completely normal to me on the street. I am running a custom PROM that I designed myself.
Check my webpage in my sig for my cam and my mods.
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's after installing Hooker LT Headers and reducing weight.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
Old Oct 30, 2000 | 07:34 PM
TRAX, Cool, Im runnin 3.73s myself and will probably end up with one of those expensive Precision Vigilante converters....LOL....I saw in one of your posts you plan on a 224/230 cam swap. Ive been told by a few people that that is too much duration for basically stock compression engine. True or false? I plan on around 10.25 comp with the 58cc heads and thinner than stock gasket. Could I run that much duration with only 10.25? Sorry for all the questions...guess I took the opinions from our intake makers a bit too serious, they say the ZZ9 is the best stick for a stock compressioned mini rammed 350. Im starting to think they are talking a bunch of #%&@.
Old Oct 30, 2000 | 10:58 PM
TRAXION's Avatar
Yes, it is very true that you want to increase static compression when increasing the duration of the camshaft. But, my car isn't stock compression :-) Although I am running the stock pistons ... my heads are 60cc and not 64cc. That's about a half point difference in compression. I am running about 10.25
The 224 cam will work AOK with that compression.
Tim
Old Oct 31, 2000 | 06:17 PM
TRAX.....you must be running a thinner head gasket too. You got me thinkin now if I should go a bit longer on the duration than that 219 Lingenfelter stick. BTW.... if I were to go with say....58cc and a thinner gasket (the ones TPIS sells) would I run into any piston to valve clearance problems? Better to be safe than sorry... John
Old Nov 1, 2000 | 10:07 AM
TRAXION's Avatar
BBJ,
If you have a MiniRam motor than a 220+ duration cam would rock. I wouldn't go any higher than 226 (which is darn high). Regarding compression ... just use the stock FelPro gasket with a 58cc head on a 350 and you will have PLENTY of compression. No need to go to a thinner head gasket. I am running a stock type felpro head gasket (#1010) with 60cc chambers and it is obviously enough compression for my motor
Tim
Old Nov 1, 2000 | 07:32 PM
Well, I think I am going to try the ZZ-409 (.520/226/287 adv.) to go along with my 65cc Canfield 197s. This should make for an awesome package with the mini-ram. For some reason, I am still concerned that I may not have enough compression (9.8) What's your thoughts on this TRAXION? P.S. I've got plenty of gear and converter.
Old Nov 1, 2000 | 07:33 PM
Old Nov 1, 2000 | 10:09 PM
TRAXION's Avatar
BBJ,
Yes, I agree with you. If you are going to run heads that have chambers that big then your compression will not be high enough. I would run a thinner head gasket if you run those canfield heads ... or, have the canfield heads milled down to 60 or 58cc.
Tim
Old Nov 2, 2000 | 05:29 PM
Tim......... the 9.8 compression is with the thinner gasket. Stock compression is 9.3 on a '88 L98 unless I'm mistaken. The problem with milling the heads is that the design of the Canfield heads does not allow for any milling ( I think ). So, at this point, I think 9.8s about it till I do a lower end rebuild.Do you still think I'll be alright with the ZZ-409?....... John
Old Nov 2, 2000 | 08:47 PM
87Z-ya's Avatar
I think the zz409 or something similar would be perfect for your setup. I know the computer on my car is all horked up but I can still tell the miniram would love more cam than what I have.
87z 383,afr 190's, crane hyd roller(224/230-.509/.528,112 sep),Ported and polished mini ram, 24lb inj, 3.42 gears, strange 12 bolt, tremec 5spd, , 1,3/4" slp headers.(stock 305 hypercrap chip), other stealth goodies.
Runs 14's all day long.
Old Nov 2, 2000 | 09:07 PM
87Z......what compression you running with that 383? ...... John
TRAXION
66
Jan 25, 2002 11:04 PM
1bad91Z
Aftermarket Product Review
Nov 29, 2001 11:07 AM
John Boy
Aug 1, 2001 06:02 PM
TRAXION
Jun 22, 2001 05:11 PM
okfoz
Jun 22, 2001 07:38 AM
