EFI POW WOW
Car: An Ol Buick
Engine: Vsick
EFI POW WOW
Just a heads up......
Things are in the works, again.
There will be a EFI POWWOW II
It's a strictly a Hotrod EFI deal. Primarily GM. minor tangents about aftermarket stuff, engine to ecm management relationships, stuff tolerated.
Lots of plug reading. Bring your best glasses. And tools to pull your's if ya want folks to stare at'em.
Adults Only, and this is at my home so Please, Good manners. I hope that is all that needs said.
Anyway, all the software (tunercat, halteck, lectromotive accel fueltronics, diacom). The ecm bench, will be up and running. The GN will be viewable. Ya wanna talk, ecms, this is it. Period. last one was 2 days and 9am Sat morning til midnight Sun took about 15 mins, time worps will occur.
No food or restroom here. Great Food 1 block away, Pizza 1/4 mile.
Bring note paper.
Lots of ground gets covered, Lots.
We had 4 prom burners running and couple guys really took advantage of it <g>...
Some interesting reading material,
DIY WB O2 sensor on display and probably used.
If your disappointed, you didn't ask any guestions. Ain't no dumb guestions here, I have alot more time to give whole answers then the snippets that I post.
Will be spring break or 2 weeks after school ends (medical stuff sets the final schedule, and I just can't control that)
If you been around someone ill prior to coming you Have to tell me. That is a must I am immuno system supressed, If just one or two guys, then I'll ask you to wear masks, more then that and I will, just part of the deal. Just so no surprises.
Cheers
Grumpy
Hey Grumpy,
Will this be open to "newbies" too? I'm just getting started with EFI tuning (tuning in general, for that matter), but this sounds like a great opportunity for someone to drastically shorten the learning curve and soak up some killer knowledge. If you're only looking for guys who know enough to ask moderately challenging questions, I understand...sniff... Although hopefully I won't be a total newbie by then.
BTW, I promise not to make any wet spots on the carpet or anything!
[This message has been edited by shawn87gta (edited January 29, 2001).]
I wouldnt mind coming, its a long way though. Maybe I can talk todd from southwest research into coming. He knows all about the wbo2. I'd like to learn more on everything and hopefully the speed pro will be in.
Car: Death Mobile
Engine: 666 c.i.
Damn, that sounds interesting. Not having kids (or being in the US) when approximately will that be? I REALLY would like to try and schedule a vacation around that time and try to make it. It would make one heck of a Diacom run for my readings.
PS, the medical sounds serious. I hope this is not a "time is of the essense" situation. Very sad to hear that, my sincerous regrets.
Car: An Ol Buick
Engine: Vsick
[/B]
Last one, we had a PhD., and was designing his own ecm, and a guy I had to show who to get a 2732 prom out of it's socket.
Anyone asking a guestion gets the floor. All you have to do is speak up.
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
Grumpy, I am definatly interested. That times close to when "hopefully" I'll be swapping to the 749. Should be a short jaunt over to your place. Thanks also for the heads up about your illness,as I have three bringers of bugs at the house.
Mask is not a problem. Be well and look forward to meeting you. Bob
Mask is not a problem. Be well and look forward to meeting you. Bob Member
Car: 88 GTA + Dakota on N20
Engine: 383 4 bolt
Wow sounds pretty cool. I live in Toledo, OH
so it isnt that far but im really a newbie at this so if i get good enough to get my car out of the garage LoL can i come?
Car: An Ol Buick
Engine: Vsick
Period.
It's very unlikely you'll ever see the info., that I have on hand. Anywhere but here. And some interesting GM developement Hardware. Yes the real heads up display mentioned in the sy docs. Not to be confused with the HUD that a jet fighter uses.
Car: 1998 Camaro Z28
Grumpy,
Sounds like an excellent opportunity! It seems like its getting more difficult to find someone these days to share their knowledge, experience, etc. My hats off to you. I wish I had started sooner on chip burning so I could ask more intelligent questions! Anyways, Im about 2-3 hours from Dayton I believe, so count me in if you have room for one more.
Later
Later
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Sounds great!
I'm in the process of acquiring the stuff to burn my own EPROMs. I should have plenty of questions for your POW WOW.
Grumpy, are you talking in March or later like in May?
'87 L98 TPI IROCZ, AFR190 heads, 3.70 gears, ZZ9 cam, 2400 Art Carr TC, SLP 1 3/4" headers, SLP cat-back, no cat, no AC, no MAF screens, Accel manifold base & SuperRam, Edelbrock double roller timing chain, MSD ext coil & distributor, trans cooler, 52mm TB with airfoil, TB coolant bypass, AFPR(58psi), K&N filters, Hotchkis lowering springs, Car-Pro custom chip, Lay Ind. ram air kit, 265/45R16 Kumho V700 tires.
ET 13.39sec @ 107.21mph
'90 Eagle Talon AWD, no rust thru 9 winters
'99 Camaro SS, red, 6-spd, T-tops, Mcleod clutch, Pro 5.0 shifter, MAF processor, Direct Flow airlid, K&N filter.
313.7Hp & 320.6ft-lbf, ET 13.55sec @ 105.1mph
next mod: 4.10 rear gears
Car: 04 GTO
Transmission: M12 T56
Even though i'm still in lurking/learning mode, sounds like it'd be a worthwhile trip. I am a sponge, i just need to throw my *** in the bucket and start washing my car...ed
Ed Maher - Moderator @ The Carb Board
92 Z28 Convertible - Quasar blue / Tan top
LB9 4L60 GU2 G80 - stock, soon to be sleeper
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
Grumpy,
Could you put some directions to your house, that would be just another days drive for me to attend that gathering. I normally drive from Lima to Dayton everything other day to go to College. If everything works out maybe i could meet up with the people from Akron and Toledo when the they are coming by!
Let me know guys,
Brendan
1987 IROC-Z L98 350 SuperRam, Edelbrock Performer 6085 Aluminum Heads, LPE RollerCam 219/219, Crane Gold Race 1.6RR, TF 1 pc Moly Pushrods, Underdrive Pulleys, Edelbrock TPI High Flow Base Manifold, Accel 58mm TB, ADS 24#, Crane AFPR, K&N, Edelbrock TES Headers, Catco Hi Flow Cat, 3" Borla Cat-Back, Accel Cap & Rotor, MSD 8.5mm, MSD 6AL Ignition, MSD Blaster 2 Ignition Coil, Hayes Clutch, 1LE Aluminum DS, 94' Z28 Disk Rear, Wilwood Adjustable Proportioning Valve, Torsen Series 3 Posi Carrier, Precision 3.73 Gears, Southside Machine Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
To see the ROC, Check out the webpage Here
Let me know guys,
Brendan
Car: Death Mobile
Engine: 666 c.i.
That's ok Ed. I did exactly the same thing. I just waited until I got the equipment and started actually "doing it".
Kind of makes you feel like a stalker, doesn't it?
