can chips go bad.........
Old Apr 8, 2001 | 09:46 AM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
my question is can the chips go bad when left erased?
A few weeks ago I erased two chips and left them in the Datarase II's storage area. now I wanted to program them and both came up with errors. so I checked and they now are not erased. so I tried to erase them again and again but, still no luck. also I tryed to read the hypertech chip I have and now it has an error when I try and read in in tunner cat. I thought the hypertech chip may have seen some sun light because I left that on the desk(oops) but, what about the other chips are they bad? or did the pocket programmer take a $#!+ ?
Old Apr 8, 2001 | 02:02 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Maybe you are not using the proper eprom with your programmer to change them or you haven't erased them long enough.
I found my 27C256s liked about 15 mintues to properly erase them. The amount of erasing time differs from the type of eprom you are using and the manufacturer of the eprom too.
As for eproms going bad, they will eventually hit a point when they have been erased "one time too many". Eproms can only be exposed to UV light for so long before they can no longer be used.
Old Apr 8, 2001 | 03:39 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Make sure the pocket programmer is plugged in to the wall outlet. I catch myself doing this after not using for awhile.
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Apr 8, 2001 | 08:33 PM
Engine: ls1, LB9
I kept checking and it is set for the right e-prom. also I must have about 40 min in it now trying to make sure they have been erased. I even tryed the programmer on my lap top which also worked before. tryed differant outlets and still nothing the converter does get worm like they all do so that is getting power for sure.
maybe I will e-mail them tomarrow and see if there is a way to check it before I try to send it in. or order a chip.
Old Apr 8, 2001 | 08:36 PM
Car: Death Mobile
Engine: 666 c.i.
You ARE doing this all in DOS aren't you? I found trying to execute EPROM.EXE or FILEPROM.EXE within Windows causes errors.
Old Apr 8, 2001 | 08:59 PM
CanadianBeast's Avatar
Is it possible to wreck the eprom by leaving it in the programmer while not in use but still plugged in? I think this is what I did because I pulled my Jet chip put it in the programmer, read it, saved it, and then rushed to tunercat to take a look but forgot to take the eprom out of the programmer. So then I took and erased it so I could burn in the ARAP bin and it wouldn't work, it just kept showing an error right as it started to program.
Old Apr 9, 2001 | 07:38 PM
Engine: ls1, LB9
did you see if it was still erased? because thats what mine did (error when try ing to program) and now it still says it is not erased.
Old Apr 9, 2001 | 09:41 PM
I've tried it like 5 times, it's definately erased, it just won't program.
Old Apr 10, 2001 | 06:53 PM
Engine: ls1, LB9
interesting.
mine just wont erase I was under the impression that they won't wright again after being erased but, perhaps in my case it was the other way around.
Old Apr 12, 2001 | 08:10 PM
Engine: ls1, LB9
has any one had an eprom go bad? what did it do?
my new gm chip should come in tomarrow but, this is just pissing me off. the programmer acts like it reads it but, says it is not erased and when I save it to file and try to verify it it says e-prom did not verify to file.
Old Apr 16, 2001 | 01:10 AM
craiger's Avatar
I have no experience with programing chips for cars but i have been going to school for computers for the last year and a half. I am doing the Cisco CCNA/CCNP cert. I also am A+ certified. In the A+ class they emphasised that you should protect ALL COMPUTER CHIPS from ESD! STATIC electricty which can cause dammage to the circuits so to avoid dammage, you put the chips in an esd bag and or make sure you are grounded when touching them. This does not mean you will destroy them if you touch them, but it is very possible. I'm not sure about rom chips or eprom's but this may be why your chip is not working right, maybe not? Not trying to make you worry, just giving you some valuable info.
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Gunner242
Dec 25, 2015 04:49 PM
KO1
16
Oct 15, 2015 05:00 PM
jaridjohn
Oct 5, 2015 07:01 AM
