winaldl problem
Old Nov 20, 2006 | 12:24 AM
Colts45s's Avatar
Car: 92 camaro rs
Engine: 350 tbi/416's/comp xe268
winaldl problem
ok got my cable the other day went out on a test drive and all i could get was the raw data? i bought a usb-obd1 cable and set my com port up corectly know its not hardware prob (pc tech by profession) I set it up with a 746 esm because i drive a 92 camaro rs w/305 tbi and thats what car came with. haven pulled dash to check but im pretty confident it was never changed is there a setting anyone can tell that i did wrong. I havent checked this out yet but there is a jumber on the usb connector and spec sheet says that it is in the norm position top l to top r but there is also a setting to short pin a to b do i need to do that? HELP lol new to dataloging and proming lol rough start already
Old Nov 20, 2006 | 11:06 AM
Colts45s's Avatar
Car: 92 camaro rs
ok well if anyone knows please let me know cause i tried both a shorted to b and 10k resistor and none worked. Would it be easier to use tuner pro rt?
Old Nov 20, 2006 | 11:19 AM
Dents's Avatar
Car: 91 Camaro Z28
Engine: L98 5.7L
Axle/Gears: Ford 9" with 4.30s
I'm confused ... are you getting absolutely nothing and wondering why? Or are you getting data and are not sure what to do with it? Where did you get your cable from?
Old Nov 20, 2006 | 04:05 PM
Colts45s's Avatar
Car: 92 camaro rs
i am just getting the RAW data no sensor readings no o2 readings blms etc. cant remember offhand where i got the cable but it appears to be working because i am getting dome numbers like promide and what not
Old Nov 20, 2006 | 04:31 PM
DM91RS's Avatar
Car: 91 RS
Are you getting the green flashing light at the top of the winaldl window?
Old Nov 21, 2006 | 12:04 AM
Colts45s's Avatar
Car: 92 camaro rs
no a red 1
Old Nov 21, 2006 | 04:28 PM
DM91RS's Avatar
Car: 91 RS
I no longer use winaldl but I do remember that when I had a red light it showed incomplete data and found it came from a loose connection or loose cable. The light should be green............
Old Nov 22, 2006 | 11:19 AM
Colts45s's Avatar
Car: 92 camaro rs
well i got fed up with it lol paid 30 and got tunerpro rt and the aldl function works great now i just have to learn what this all means
Old Dec 9, 2006 | 11:25 AM
Colts45s's Avatar
Car: 92 camaro rs
oh figured out why minaldl wouldn't work....baud rate was incorrect
woops
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
