Caprice chips
Car: 1991 Camaro RS
Engine: stock 305
Axle/Gears: 4th gen with 342's
Caprice chips
I was wondering if the stock tbi chips from a caprice is any better than the stock chip in my in my 94 suburban?
Re: Caprice chips
I will assume the ECU is same on both? I dont see how a different stock chip could be better? That chip is specific for the gearing, weight, intake, trans, cold start etc etc etc. If the truck is modified then you need to retune. I did the opposite as I ran a stock truck .bin 350 cid in my 84 vette day one of ECU swap. It did not run very well.
Re: Caprice chips
Chips are specific for the vehicle as well as specific for the engine in same and trans and the Kalifornia thing and maybe gears and maybe outside USA. ECU are for a broader range of vehicles. Now some of use will use a ECU that was not intended for use in our vehicle. I used a 7747(truck ECU) in my 84 Vette and burned a few chips to get it to run right. I now run aftermarket ECU.
Car: 1983 G20 Chevy
Transmission: 4L60
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
Re: Caprice chips
they would probably be tuned relatively similar. both are heavy vehicles and require low end torque over top end power.
that being said, the transmission will make it impossible to do.
you would be better off getting a chip burned for you
Car: 1991 Camaro RS
Engine: stock 305
Re: Caprice chips
thanks for the info guys and i agree with the chip thing also...but i cant justify getting all the stuff and the $$ spent and the time it would take just learning how to do it correctly just for one chip for my truck...
Car: 91 z Clone
Engine: 6.4l LSX
Axle/Gears: s12 3.73
Re: Caprice chips
quit being ghey paul. suck it up and buy one of those EBL, EDL things you are always whining about.....
Gunner242
Dec 25, 2015 04:49 PM
KO1
16
Oct 15, 2015 05:00 PM
