new engine, stock tune
Old Apr 5, 2010 | 04:38 PM
Nater36's Avatar
Car: 1989 Firebird Formula
Engine: 310 HSR, TFS heads, zz4 cam
Axle/Gears: 9 bolt 3:70
Hello everyone.. I am getting a 305 tpi out of a 90 irocz auto soon(within a couple of weeks).. It has a zz4 camshaft, ported plenum, ported TB and 22lb injectors.. bored .030 .. I have the tuning equipment but still havnt learned it yet.. My car has the 165 ecm.. problem is I know its not going to run right with that cam and injectors... I dont want to unsolder the damn chip like ive read you have to do.. Im able to use the connector that sits in the chips place with my own burned chip(27sf512) correct? If so therein lies my problem.. where can i burn the stock tune onto that chip.. I have the stuff from moates.net.. please help asap!!
Old Apr 5, 2010 | 06:10 PM
monkihead's Avatar
Car: 1990 RS
Engine: 305 TBI
Axle/Gears: 3.08
Re: new engine, stock tune
bin defintions if you use tunerpro
http://www.tunerpro.net/downloadBinDefs.htm
look at bottom of page and log into moates file system. there should be a stock bin in there. its where I found mine.
Old Apr 6, 2010 | 12:08 AM
Nater36's Avatar
ok.. i found the 89 F up at top.. which one do i download? from where it says bins? if so there are 3 choices..
Old Apr 6, 2010 | 12:35 PM
Ronny's Avatar
one may be manual trans one auto and one Federal? Search the broadcast code for each application.
Old Apr 6, 2010 | 01:29 PM
monkihead's Avatar
Car: 1990 RS
Engine: 305 TBI
Axle/Gears: 3.08
what does the white sticker on your ecm say?
Old Apr 6, 2010 | 01:54 PM
Ronny's Avatar
each .bin has a broadcast code. Search that four letter code and find out what that application actually is. Match it up to your application.
Old Apr 6, 2010 | 11:56 PM
Nater36's Avatar
alright, easy enough.. while using tuner pro i just click load buffer select whichever my application is then click program chip and thats it?
Old Apr 7, 2010 | 10:25 AM
Ronny's Avatar
I dont use TP so cant answer. I recall there is a tutorial on how to do on TP. click help?
or visit their website or search here.
Old Apr 7, 2010 | 10:52 AM
Nater36's Avatar
i found the 4 letter code i beleive.. it is ANYX.. Im not finding it anywhere in the .bins
Old Apr 7, 2010 | 11:40 AM
Ronny's Avatar
Search user as Magnus Tunerpro or TP
Old Apr 7, 2010 | 12:16 PM
Nater36's Avatar
search for the user name?
Old Apr 7, 2010 | 02:21 PM
Ronny's Avatar
In advanced search place Magnus for name then keyword TP or try Tunerpro
Old Apr 7, 2010 | 02:28 PM
Nater36's Avatar
no matches found no matter how i type it in... i did however find someone that said they had a copy of the .bin last year and sent him a pm... now just to see if he will reply
Old Apr 7, 2010 | 02:40 PM
Ronny's Avatar
ANYX_LB9_5spd_3.45.bin found this here http://www.moates.net/files.php
see DIY-EFI 1227165 .bin here http://www.moates.net/files.php
Old Apr 7, 2010 | 02:50 PM
Nater36's Avatar
wow... i didnt realize that was a list... i clicked the plus instead of the actual name the last time i checked that haha.. i thought it was just for uploading... thanks a lot man
Old Apr 8, 2010 | 09:21 AM
Nater36's Avatar
How the he** do i download the $6e file as xdf???
Old Apr 9, 2010 | 03:43 PM
monkihead's Avatar
Car: 1990 RS
Engine: 305 TBI
Axle/Gears: 3.08
right click, "save link as"
Old Apr 9, 2010 | 05:28 PM
Nater36's Avatar
thx
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
InfinityShade
Aug 22, 2015 08:00 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
