O2 threshold tables
Old Jun 30, 2010 | 06:28 AM
34blazer's Avatar
Car: '86 Grand National
Engine: LZ9????
Transmission: 2004R
O2 threshold tables
hey all!
running an 8062 ecm with the $4E mask built by saar. i have a fairly aggressive solid cam and im trying to get the idle rpms to run a little leaner. i read that adjusting the values in the; rich,lean, and mean O2 threshold tables will help me dial it in. well the lean and mean O2 tables have the same values, and the rich is zero'd. im hoping it isnt supposed to be like that, if not, what should the values be in those tables? also, when im driving, (for lack of a better word in my vocab) the engine feels herky jerky lol. would these tables affect that? it starts to break up around 4k rpms too, it spits and pops out the exhaust. going to the parts bin today to get some plugs as i think these ones are toast. thanks in advance!!
Old Jun 30, 2010 | 11:41 AM
Ronny's Avatar
Re: O2 threshold tables
Have you looked at a stock.bin to see what GM placed there? craigmoates
Old Jun 30, 2010 | 01:58 PM
34blazer's Avatar
Engine: LZ9????
Transmission: 2004R
are you talking about the disassembly? if so i dont know how to read that yet lol.
Old Jun 30, 2010 | 02:11 PM
Ronny's Avatar
No not disassembly. Just load a known stock bin in TP and see what is there. I did move myr ich-median-lean up 10% in value to attain a slightly richer CL A/F and put commanded to 14.3. maybe I am just wasting gas.
I dont understand how rich can be zero. are you using the correct calibration file .xdf .ecu?
Old Jun 30, 2010 | 02:19 PM
34blazer's Avatar
Engine: LZ9????
Transmission: 2004R
the original bin/xdf i downloaded from TPs website was just a basic mask, it didnt even have half the parameters that robert saar sent me. im using what he built. $4E bin and xdf. thats all i know lol. i dont know where i can find another bin to see if those values are different.
Old Jun 30, 2010 | 02:32 PM
Ronny's Avatar
craigmoates. downloads. stock binaries.
Old Jun 30, 2010 | 04:08 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Ditto, first thing that came to mind.
Try locating and importing a different $4E definition (XDF or ECU file)
Open your current bin file and see if the values display the same.
Then using the same ECU or XDF file, load the "stock" bin file and see if the values are similar or way off. The stock values "should" have worked. Maybe not as well as they should but that is how the factory had them set.
What is the BCC of the bin file? (like ATBA,AMRW, etc)
Where you at in Brunseltucky? LOL
You may be pretty close to me.
Old Jun 30, 2010 | 05:22 PM
34blazer's Avatar
Engine: LZ9????
Transmission: 2004R
LOL yep right here in brunstucky pearl and hickory ridge. pardon my lack of know, just started tuning a couple of months ago. dont know what the BCC is or where to find it though.
Old Jun 30, 2010 | 09:48 PM
34blazer's Avatar
Engine: LZ9????
Transmission: 2004R
negative on the fileman d'loads, found a similar thread on this too. guess im not the only one.
https://www.thirdgen.org/forums/diy-...er-ecu-4e.html
Old Jul 1, 2010 | 11:24 AM
JP86SS's Avatar
Most of the stuff for $4E is from Saar that I have found.
Most on the V6 board or from your thread on the TP site.
Probabbly send him a PM for the definition he used to create it from.
I DL the 4E xdf from the TP site and saw the same thing you did when using the ONLY bin file I could find for it.
I forget what the BCC was right now but can confirm it tonight at home.
TBI is not my strength but may be able to help you somewhat.
I'm off Drake near Pearl so maybe we can take a look at it together this weekend and figure something out.
Shoot me a PM with your #.
Old Jul 1, 2010 | 01:03 PM
34blazer's Avatar
Engine: LZ9????
Transmission: 2004R
awesome. pm'd. since there isnt hardly anything for the 8062 and what i have is far from complete, im going to switch out my ecm's with the '747 and give it a whirl. ill go back to it as i learn more in the future.
Old Jul 1, 2010 | 04:49 PM
34blazer's Avatar
Engine: LZ9????
Transmission: 2004R
ok, i put my '747 in the truck with the 4.3 5spd bin, calculated the BPC and took it out for a spin. runs alot better, and doesnt surge anymore. im thinking the $4E bin is messed up, ill figure it out when i learn more. thanks for the replies!!!
Old Jul 3, 2010 | 12:03 PM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
found out why the Rich table was messed up.... the conversion somehow got set to "/.2240|0|0|0|".....
oh well, i fixed the equation, sending it to mark now. were there any other oddities you found that i might be able to fix, since we're on the subject?
Old Jul 3, 2010 | 02:45 PM
34blazer's Avatar
Engine: LZ9????
Transmission: 2004R
would those tables cause the engine to surge at part throttle?
Old Jul 3, 2010 | 04:22 PM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
those alone? not likely.
Azrael91966669
25
Jun 20, 2017 04:04 AM
antman89iroc
36
Jan 31, 2016 08:42 AM
86CamaroDan
Sep 29, 2015 10:08 PM
IROCThe5.7L
Sep 17, 2015 07:48 AM
ULTM8Z
Sep 16, 2015 09:15 AM
