Using a GM ECM in a straight 6
Hey guys, i got a crazy idea, could it be possible to use gm ecm to run a chevy 250 straight 6?
I was thinking of using a HEI, and maybe a tbi setup.
thanks for your help guys.
Transmission: 5-speed/T-5
Re: Using a GM ECM in a straight 6
Not so crazy.
It's a Nissan I6, but the priciple is the same.
Don't worry it's actually mounted now.
I have also changed from the dizzy to DIS since the above pictures were taken.
In my case, I was able to install a later Nissan dizzy that had a magnetic reluctor, very similar to what is found in an EFI controlled GM dizzy. I simply connected the Nissan dizzy to a GM ICM, that I pirated from a 2.8L S-10 dizzy. This gave the ECM RPM reference, and gave the ECM the ability to control the timing.
IIRC there are HEI style dizzys available for the Chevy I6 that would make the conversion somewhat easy, in that you can get the magnetic reluctor that way and then use a 7 pin HEI module to inteface with the ECM.
The next hardest part is setting up the Fuel, but if you can get your hands on either a 2.5L or 2.0L/2.2L TBI throttle bodies, these would be fairly easy to adapt to your existing manifold being single barrel TBI units. If you wanted to go a little more custom, you could get a 4 BBL manifold and use a TBI unit off 4.3 or SBC, with an adaptor plate.
Even more custom yet would going MPFI.
I short, there's no reason you can't, just time and some money to get it all together, amybe a couple custom adaptors too.
A fellow did a TBI conversion few years ago and was posting their progress on the GMECM mailing list...
http://www.baizefamily.com/c10pg1.htm
http://www.baizefamily.com/c10pg2.htm
http://www.baizefamily.com/c10pg3.htm
http://www.baizefamily.com/c10pg4.htm
http://www.baizefamily.com/c10pg5.htm
http://www.baizefamily.com/c10pg6.htm
http://www.baizefamily.com/c10pg7.htm
http://www.baizefamily.com/c10pg8.htm
http://www.baizefamily.com/c10pg9.htm
http://www.baizefamily.com/c10pg10.htm
http://www.baizefamily.com/c10pg11.htm
http://www.baizefamily.com/c10pg12.htm
http://www.baizefamily.com/c10pg13.htm
http://www.baizefamily.com/c10pg14.htm
http://www.baizefamily.com/c10pg15.htm
http://www.baizefamily.com/c10pg16.htm
http://www.baizefamily.com/c10pg17.htm
http://www.baizefamily.com/c10pg18.htm
http://www.baizefamily.com/c10pg19.htm
http://www.baizefamily.com/c10pg20.htm
http://www.baizefamily.com/c10pg21.htm
http://www.baizefamily.com/c10pg22.htm
http://www.baizefamily.com/c10pg23.htm
http://www.baizefamily.com/c10pg24.htm
http://www.baizefamily.com/c10pg25.htm
http://www.baizefamily.com/c10pg26.htm
(there is no main page that lists all these)
Here are the ECM def files. From Tunercat.
$48 1227748 87 - 88 Pontiac Fiero 2.5L 4 Cyl. LR8
87 - 90 Celebrity, 6000, Cutlass, Ciera, Century 2.5L 4 Cyl. LR8
27C128
$46 1227730 87 - 88 Corsica, Baretta, Tempest 2.8L LB6 V6
27C256
$55 1227730 87 - 88 Celebrity, 6000, Ciera, Cutlass, Century 2.8L LB6 V6
27C256
$44 1227783 87 - 88 Buick / Pontiac / Olds, LG3
3.8L, V6
2732A
$5F 1227748 89 Grand Am, Cutlass, Skylark
2.5L, L68, 4 Cylinder
27C128
$8CB 1227748 90 - 91 Grand Am, Cutlass, Skylark
27C128
$89 1227727 90 - 92 Buick/Pontiac/Olds W-Body LR8, 2.5L 27C128
$58A 1227749 87 - 90 Sunbird, Grand Am, 2.0L, LT3
Turbo
27C128
$5B1 1228253
GM used TBI one barrels in early years but not sure if their ECU are hacked. My prior CF used two one barells that I recall were used on other GM apps.
27C128
27C256
27C256
3.8L, V6
2732A
27C128
27C128
Turbo
27C128
$5B1 1228253
Car: 1983 G20 Chevy
Transmission: 4L60
GM Brazil and Mexico BOTH built MPFI 250 I6 engines they dubbed the 4100 MPFI. The manifold looks very TPI like and I can tell you its NOT a crossflow head, so it would probably bolt right up if you could obtain one. That being said I know the California version of the 4.1 250 I6 in atleast the G-Van had a computer controlled carb and distributor around 1984. This EST distributer is compatible with either a TBI or MPFI ECM. I think a MPFI setup running a V6 7730 would run VERY WELL.
So bassically, the 7730 V6, would run the inline with no big troubles?
Car: 1983 G20 Chevy
Transmission: 4L60
Really? I live in Mexico, and haven't seen one, now that i think about it i know we had fuel injected inline sixes in the early 90's, it's been ages since i've seen an inline down here that's running, but they can be bought for cheap around 150 bucks or less.
Really....They came in vehicles produces as late as 1998 or so....Grandblazer, Silverado, and the like.
I think your getting confused with southamerican models, for example the GrandBlazer doesn't exist here in Mexico, we have the same models as in the US, only drivetrains change a little, but i'm still pretty sure that in the very early 90's we had I6's in some trucks.
Now that i think about it, i'm pretty sure that the last I6's where all 292's
efiguy
Sep 27, 2015 01:30 PM
