HSR with lt4 hotcam setup wont seem too idle smooth, injectors?
Car: 1991 pontiac firebird formula
Engine: 5.7L HSR, 58mm tb,24lb inj.,lt4 cam
Transmission: 700r4,3000 stall,stage 2 shift
Axle/Gears: 10bolt 3.23 ratio
Ok heres the setup, 355 with 10 to 1 flattops and lt4 hotcam with 1.5 rockers, ported 083 heads with 2.02/1.60 valves, and hsr with ford 24lb injectors and 58mm tb. I had a guy come tune the setup with a wideband hooked up and everything and in the tune he was not able too see why the idle wouldnt smooth out so he sugessted replacing the injectors.It idles fine when cold but when it warms up it jumps 100 to 150 rpms and when put in gear its a little worse like its searchin for a idle. I went out too the junk yard and pulled some bluetops with the same ohms on lbs and put them in too see if it would help and for some reason it dropped my idle about 100rpms and made the miss at idle worse.Ive been stumped on this for a week, any opinions would be greatly appreciated
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: HSR with lt4 hotcam setup wont seem too idle smooth, injectors?
Are you running a 730?
What BCC did you start with?
If this is $8D then you might look at your main spark table (100 Kpa column) to ensure it matches the closed throttle SA table.
$8D uses the 100 Kpa column to set SA when cold. Once it warms up the closed throttle table takes over.
The other thing would be to log it and see if the idle SA is jumping around due to the RPM error tables. They can add or pull several degrees of timing when the idle RPM error is detected.
i dont have any way of doing that, ill try too get hold of my tunner and ask him if he can do that for me but hes hard too get hold of and he charges me at least $250.00 every time i have him touch it. is there any cheaper way too get it fuigured out?
Car: check
Engine: check
Transmission: check
Is there any cheaper way too get it figured out?
RBob.
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Buy the stuff to tune and log by yourself from moates or maybe used stuff if you want to save some $$. Post bin and log file here on thirdgen I'm sure someone will help you. Email me otherwise
ok cool ty for the info, can someone send me a link to where i can buy the stuff too tune and log myself?
The sticky at the top of this board has a wealth of info grouped into sections.
PROM Tuning Guide Book
https://www.thirdgen.org/forums/diy-...uide-book.html
Car: 90 IROC
Engine: 5.7L TPI
Axle/Gears: 9-bolt BW
if you have a laptop, you're most of the way there. I'd suggest TunerPro RT.
you will have to buy a cable to connect your laptop to the ALDL port, I think that runs about $85 nowadays. I got mine from AKM.
I went through this same baptism by fire. it's scary when you're standing at the threshold but it ain't that bad once you embark.
once you log data and figure out what needs to be done, then you decide whether to take the next step and burn your own chip.
ok cool i already have both so all i need too do is get the tunerpro rt and as soon as i do ill take some logs down and post and hopefully get this crazy thing fuigered out. ty everyone for the info so far
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Car: '83 trans am Lear Siegler
keep searching the threads, I pretty much have the same set up as you, with the same problem, I've spent a lot of time searching the threads, and especially in the Tuning with the ebl thread. Mine is getting under control, but I've done so much over the course of tuning, I don't remember it all.
1988iroc350tpi
Aug 14, 2015 07:52 PM
