$32 vs $32B
Old Nov 27, 2011 | 08:08 AM
dave w's Avatar
$32 vs $32B
I'm doing a mix and match of TPI parts. I have mostly an 86 305 TPI system, but the wiring and ECM are from an 88 TPI donor vehicle. I plan to use 22lb ~ 23lb injectors when I install the TPI system onto an old school SBC 350.
I've found several $32 & $32B 5.7 liter .bin files, but I am wondering if there is any advantage of using the $32 vs $32B .xdf / definition for a mostly stock old school SBC 350?
My previous TPI experience was using $8D.
dave w
Old Nov 27, 2011 | 08:48 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: $32 vs $32B
I would use $6E and eliminate the 9th injector.
RBob.
Old Nov 27, 2011 | 09:06 AM
dave w's Avatar
Re: $32 vs $32B
RBob.
I like the idea of eliminating the 9th injector.
Any other things I should look for in the $6E definition? Mostly I'm trying to keep things simple, so if I need TPI service parts I can say the TPI system is 89 Vette. I'm wondering if the MAF is the same for $32B vs $6E.
dave w
Old Nov 27, 2011 | 10:58 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: $32 vs $32B
Don't forget to disable VATs. And once tuned enable highway mode for better mileage. '86 through '89 TPI used an analog MAF, all the same.
RBob.
Old Nov 27, 2011 | 11:04 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: $32 vs $32B
$6e is the way togo I have used arar with iron heads and no pinging.
Old Nov 27, 2011 | 03:06 PM
dave w's Avatar
Re: $32 vs $32B
arar? maybe arap?
dave w
Old Nov 27, 2011 | 05:11 PM
Engine: Lb9
Transmission: M20
Re: $32 vs $32B
yes the corvette arar
Old Nov 27, 2011 | 05:52 PM
dave w's Avatar
Re: $32 vs $32B
Dang it, I don't have the arar .bin
Old Nov 27, 2011 | 06:02 PM
Engine: Lb9
Transmission: M20
Re: $32 vs $32B
pm me with your email and I will send it tomorrow
Old Nov 27, 2011 | 07:13 PM
dave w's Avatar
Re: $32 vs $32B
PM Sent
Old Nov 27, 2011 | 07:25 PM
Engine: Lb9
Transmission: M20
Re: $32 vs $32B
I have a old laptop for reprograming, Forgot I had all my .bin backed up on a jump drive. File sent. Not modified in any way. (take the vats out) !!
Old Nov 27, 2011 | 08:45 PM
dave w's Avatar
Re: $32 vs $32B
OK, I found out that the injectors Rochester #5235047 are 305 injectors that flow about 19 lb / hr. I am wondering if I change the injector flow in the $6E .bin file, will I be OK with using the 5235047 injectors on a 350?
dave w
Old Nov 27, 2011 | 08:53 PM
Engine: Lb9
Transmission: M20
Re: $32 vs $32B
go to southbayinjectors.com and get the bosch3 22#hr ones. I would not raise the fuel pressure and over work the injectors and risk a o-ring failure.
Old Nov 30, 2011 | 05:02 PM
J_D_'s Avatar
Re: $32 vs $32B
dave w
I dont see why not. They will cycle longer but they should be ok as long as the motor is not modded big time.
tmellott89
Oct 14, 2015 02:06 PM
tmellott89
Aug 16, 2015 02:58 PM
MikeT 88IROC350
Jun 23, 2003 08:39 PM
doc
Dec 17, 2002 01:31 PM
TRAXION
Nov 6, 2000 05:17 PM
