Nascar goes EFI 2013
Old Feb 18, 2013 | 01:43 PM
Ronny's Avatar
http://www.buildingspeed.org/blog/20...i-to-real-efi/
Old Feb 18, 2013 | 04:34 PM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
Re: Nascar goes EFI 2013
and it's about damn time!
neat that they went multiport.... for a second, that video looked like it was going to imply TBI.
also, doesn't a further location away from the intake valve help at higher RPMs? i remember seeing a couple N/A indy/F1/etc engines and those were actually firing the injectors above the individual throttle plates.
Old Feb 18, 2013 | 04:40 PM
Ronny's Avatar
I believe so. At the detriment of lower RPM's.
I believe the immediate observation was the idle has improved.
I hear they are experiencing some quirks with ECU(?) as it relates to a circuit breaker tripping when they turn off ign and the after coasting turn ign back on. I giuess trying to save fuel? But if it has DFCO why do that?
Old Feb 18, 2013 | 06:05 PM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
i wonder if they aren't allowed to run DFCO in the software?
Old Feb 18, 2013 | 06:14 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
I wouldnt think they could but I feel that its gonna be a mess for some race teams as for EFI. Im sure they is many many guidlines on there tune.
I agree with EFI but in nascar there is so many guidlines that it may be a mess sifting out what can be done and what is done.
Old Feb 18, 2013 | 06:28 PM
two-if-by-sea's Avatar
Car: 89 RS Vert, 89 Formula, 89 Bird
Engine: L03, TBI 350, none
Transmission: 700R4, 700R4, none
Axle/Gears: 3.42, 3.45, none
2013? Or 2012? This article was from last year. Remember Tony Stewart in Phoenix last year --> http://aol.sportingnews.com/nascar/s...jection-system
Old Feb 18, 2013 | 07:27 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
They were using DFCO last season (2012). It was obvious by the lack of flames out the exhaust on a lift.
Even better was the announcer trying to get "deceleration fuel cut off" out of his mouth. It was alien to him.
The reason it has taken so long to get EFI into NASCAR is cheating. So much can be done in that brain box that could be against the rules. And how does it get checked...
RBob.
Old Feb 18, 2013 | 09:50 PM
Dominic Sorresso's Avatar
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Axle/Gears: SuperDana 44 4.10
RBob,
Are you crewing for Hendricks Motorsports? ;-)
Old Feb 19, 2013 | 12:05 AM
xch3no2's Avatar
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
They have the McLaren ECU well protected from any unauthorized changes.
It's not a *****-out injection system like a drag car or LSR rig would use, it has to be NASCAR simple, no upstream injectors for the top end. The wild EFI's inject at multiple points...like a blown nitro engine.
Old Feb 19, 2013 | 09:03 AM
EagleMark's Avatar
RBob.
Easy! One ECU, it's locked before race, no changes or watching data during race and they are checked after race.
http://www.nascar.com/en_us/news-med...ibilities.html
Old Feb 19, 2013 | 10:11 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
That doesn't mean that code changes can't be made before the race.
RBob.
Old Feb 19, 2013 | 10:17 AM
Ronny's Avatar
I believe changes are done and allowed during time trials. Looks like Danica Patrick has a "good tuner".
Old Feb 19, 2013 | 10:46 AM
EagleMark's Avatar
Right, then can do data and make changes to ECU before race. Not during.
I think the level playing field and no cheats is they all have the same ECU so I assume same OS. Can only tune what is there and no advantges or disadvantages to anyone.
Since they are locked with their tune before a race and checked after a race I don't think any code changes would go un-noticed, calibration changes to tune are allowed and up to team to tune.
Data collected and shared after the race is engine specific and does not show data or driving like times when a driver lifts and brakes for turnes etc... just data, no ECU maps.
Old Feb 19, 2013 | 10:55 AM
Ronny's Avatar
Note Nascar does not use sensors for:
individual cyl measurements(EGT?)
incoming 02 (IAT?)
Altitude
Knock
Old Feb 19, 2013 | 11:15 AM
PhoenixFirebird's Avatar
Car: 1989 Firebird Formula
Engine: 385
Transmission: Full Manual TH350
Axle/Gears: Moser 9" 3.70
This is interesting, being that I grew up with Nascar. I thought they already were EFI though? I recall last year hearing about teams having fuel shortage issues because of the swap to EFI.
I agree with the above though, it hasn't happened sooner because of the strict rules and guidelines. They have templates and restrictions for EVERYTHING. I'm sure you guys are familiar with the penalties handed out over the years for teams trying to be creative in different areas, and are fined for being outside the guidelines, even if ever so slightly.
Old Feb 19, 2013 | 11:23 AM
J_D_'s Avatar
The Holley system they use is pretty close to what you can buy from Jegs. I'd bet McLaren got big $$$$$ for the programming. At Daytona testing there were about 7 guys at a long table with laptops each looking at the numbers for ONE car.
Old Feb 19, 2013 | 11:26 AM
Engine: 385
Honestly, I'm surprised there weren't more lol. Its a pretty big change.
Old Feb 19, 2013 | 11:30 AM
Ronny's Avatar
QUOTE]
Originally Posted by PhoenixFirebird
I thought they already were EFI though? I recall last year hearing about teams having fuel shortage issues because of the swap to EFI.[
Yes they went EFI in 2012. My error. I thought it was this year !
Old Feb 20, 2013 | 10:46 PM
EagleMark's Avatar
What's stranger then EFI in NASCAR is them thar forign vehickles like a toyoda?
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Pinguiclia
Oct 12, 2015 04:47 PM
customblackbird
Oct 1, 2015 04:30 PM
MitcherNeaf
Sep 24, 2015 09:23 PM
ericjon262
Sep 11, 2015 06:07 PM
