L31 TBI 746 ECM
Old Jul 9, 2014 | 09:10 PM
Spaceboy1980's Avatar
Car: 1990 Camaro RS
Engine: L31
L31 TBI 746 ECM
If you want to read about my swap so far here is the thread:
https://www.thirdgen.org/forums/tbi/...-vortec-4.html
My set up is a DCtrumpet 46 mm throttle body base with New AC Delco 2172286 injectors for a 350. I have a LT4 hot cam, Alex's parts spring kit and a RPM Airgap intake with adapter. I am trying to build my initial start up bin. Fast355 recommended using the LT1 timing table so I have adapted that to my L03 bin here:
I noticed the table only goes to 3600 rpm, does the timing stay the same above that?
Any suggestions what to start with for my fuel table? DCtrumpet told me to set the fuel pressure to 18-20 psi, anything I have to change in the bin to compensate for this?
I have been reading the stickies and using search, there is a lot of good info out there.
Old Jul 10, 2014 | 09:34 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: L31 TBI 746 ECM
Once over 3600 RPM the 3600 RPM row will be used.
With increased fuel pressure the injector offset and multiplier values typically need to be increased.
RBob.
Old Jul 10, 2014 | 04:13 PM
Car: 1990 Camaro RS
Engine: L31
Re: L31 TBI 746 ECM
That is what I figured about the timing table. There isn't very much accuracy there, I guess it is a primitive ECM. Thanks for that info.
As for the offset, I understand what it is but I cannot locate where to adjust it in TunerPro. This is all above my head at the moment but I am digging in. Thanks again.
Old Jul 10, 2014 | 04:41 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: L31 TBI 746 ECM
The injector PW multiplier table is at $3E9
The injector offset (bias) is at $2DA
Can search the ECU/XDF in Tuner Pro via the address.
As for the table using the 3600 RPM row when over that, it is that way in all four table directions. Below 400 RPM uses the 400 row.
Same for the columns. The final value retrieved from the table is also interpolated between the row & columns.
RBob.
Old Jul 10, 2014 | 09:07 PM
Car: 1990 Camaro RS
Engine: L31
Re: L31 TBI 746 ECM
I think I had the Fbody Lt1 spark table because I found one you had posted. I subbed it into my bin and it looks better than what I had.
What is a good ballpark for the injector multiplier table and offset? Should I just leave it alone first then see what my BLMs are?
Old Jul 14, 2014 | 10:15 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: L31 TBI 746 ECM
Just swap the stock 350 cop car offests into it if you haven't already. Get it up and running and look at the VE table as you get them dialed in. If the lower RPM starts to bathtub, increase the offsets by a couple hundred usecs at a time until the VE table starts to look correct.
Old Jul 14, 2014 | 02:09 PM
Car: 1990 Camaro RS
Engine: L31
Re: L31 TBI 746 ECM
Thanks guys!
Old Jul 15, 2014 | 01:37 AM
Car: 1990 Camaro RS
Engine: L31
Re: L31 TBI 746 ECM
I used the timing table from this post of RBob's:
https://www.thirdgen.org/forums/post...606-post3.html
And the ANLU cop car bin injector PW table and offset and came up with this bin. I have hopefully deleted the EGR inside of it as well as functionally deleted the speed limiter.
File Type: zip
Old Jul 23, 2014 | 04:23 AM
Car: 1990 Camaro RS
Engine: L31
Re: L31 TBI 746 ECM
Fast, what did you mean by bathtub?
With this ecm, is there anyway to datalog knock counts? I was able to make a history table for blm but when I try to make one for knock it isn't available in the drop down.
I have moved to the vortec timing table due to the car not liking part throttle tip in. Without being able to monitor knock I just feel like the lt1 table is too aggressive.
Old Jul 23, 2014 | 09:11 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: L31 TBI 746 ECM
The upper byte of the knock counter is in the data stream.
RBob.
Old Jul 23, 2014 | 09:48 AM
Car: 1990 Camaro RS
Engine: L31
Re: L31 TBI 746 ECM
Does that mean it is missing from the adx?
Old Jul 23, 2014 | 10:25 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: L31 TBI 746 ECM
I don't know. IIRC, WinALDL provides history on knock.
RBob.
Old Jul 23, 2014 | 10:29 AM
Car: 1990 Camaro RS
Engine: L31
Re: L31 TBI 746 ECM
I think I found it, I believe OLDPA3 to be knock. I made a table using it and it is filling. Thanks for taking time to help me out.
Johnoooooo
Sep 22, 2015 08:55 AM
Glowsock
Sep 11, 2015 11:09 PM
92rsvortec350
Sep 10, 2015 10:54 AM
Wylecoyote08
Sep 8, 2015 08:26 AM
Billy Decker
Sep 4, 2015 03:46 PM
