Injector Offset question
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Im running accel 24's and have the offset data from their website, but the chart jumps and leaves holes in the correction table on the ARAP bin im running. Is there a more complete data set out there? I did some searching and did not come up with anything. Thank you
Re: Injector Offset question
Yes, thank you!
I'm running Bosch 30 pounders in my Holley HP EFI. ....I had the same issue, and yes...linear interpolation. My method was a little unorthodox, but it worked. Remember when your math teacher said you'll use this everyday? First time I've have to graph a curve since college, lol.
Here's what I get with their datasheet...
Only goes from 6.4 to 16V, but the reality is you shouldn't be operating anywhere outside of 13V to 15V anyway...
[img]data:image/png;base64,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[/img]
Thank you all. Will see if I can plug those in and start making some changes here and there! Much appreciated.
Car: '89 Firebird
Engine: 7.0L
If you graph the curve in Excel then you can let Excel curve fit and show the equation. Might be a better fit than linear interpolation.
Jerriko 3.4
May 17, 2004 09:10 PM
