need help with 32b to 6E car wont start
Old Aug 28, 2019 | 08:20 PM
m300slr's Avatar
Car: 1985 Z28
Axle/Gears: 3.90 10 bolt eaton posi
Im new to burning, but have been able to burn $32b bin files no problem and the car runs well. However when I try to burn a 6E i cant get the car to start at all... I made some mods to the bin file like injector constants for Bosch III injectors and turned off smog pump etc and used the same chip offsets that worked for the $32b files. Am I missing something here. I feel like I am going crazy trying to figure out what is wrong. I have also tried different bin files.
Old Aug 28, 2019 | 08:43 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: need help with 32b to 6E car wont start
Have you disabled vats ?
Old Aug 28, 2019 | 08:49 PM
m300slr's Avatar
Car: 1985 Z28
Ugh... I bet I didn’t! Can’t believe I missed that!!! Thanks so much!
Old Aug 28, 2019 | 08:53 PM
Engine: Lb9
Transmission: M20
Also check your fan switch setting, if it’s incorrect your fan will run when you start your engine .
Old Aug 28, 2019 | 09:10 PM
m300slr's Avatar
Car: 1985 Z28
It is running.. where do I find that setting?
Old Aug 28, 2019 | 09:15 PM
Engine: Lb9
Transmission: M20
If your using tunerpro its a flag. Cooling fan request normally (x=open)
Old Aug 28, 2019 | 09:25 PM
m300slr's Avatar
Car: 1985 Z28
You are awesome! Every time I have a problem with prom stuff you are there to help out! Thanks again!
Old Aug 28, 2019 | 09:59 PM
Engine: Lb9
Transmission: M20
No problem
camaro1185
Feb 27, 2010 05:05 PM
runningagain
Aug 1, 2008 10:09 PM
TraviZ
16
Jan 21, 2006 01:45 PM
86Tra/maro
May 17, 2002 06:32 PM
