got the 140 amp police package alt on my 92Z 305
Old Dec 15, 2000 | 01:17 PM
necrophile's Avatar
well I gave up on it cause I couldn't get the bracket to fight right on the alternator and dropped the car off at my mechanic's. He said that he had to grind the bracket and even grind the alternator down somewhat to get the bracket to wrap around the alternator properly. Now that its on, it fits no problem looks fine, and we used the same fan belt, plugged right in, I think he needed to change the brace on teh back of the alternator as well, cuz its in a box with the original alternator as parts he took off. (I always save em) I honestly have to say that I see no difference between this 140 amp alt, and the 90 amp one that was on there when I blast my stereo system (1200 watts rms kinda killed the first alternator at 19K miles)but I think thats due to the fact that my battery is in sad shape. To top it all off my starter has been spinning freely, it finally decided to take a nosedive at the mechanic's so I wound up with a new starter too. so 260 for the mechanic with parts an labor, and 200 after the alternator (no core charge)with 460, and the fact that I still need a battery, really lets me wonder what kinda problems go on with a car that is rarely used for 4-5 years.
Steve
Old Dec 15, 2000 | 03:31 PM
dnovotny's Avatar
A lot of us have problems with our electrical systems. This is something that is common with all cars, including Japanese cars. I've burned up several reman alternators, and have found no cure as of yet for dips in voltage when the car gets loaded. I was curious if the 140 amp alt from GM would be the cure, but I guess it isn't. I'm going to put in an underdrive pully on my alternator, and see if that helps. I already put in a new battery, no difference there. I also put in a reman that was 140 amp alternator, I have had more problems with it than the original alt before it died. Only other option is to start putting in fatter wires everywhere.
Dave '91 T/A
Old Dec 15, 2000 | 07:04 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
You probably actually mean an overdrive (smaller diameter than stock) pulley, which increases an alternators output capacity at a given rpm, relative to the stock diameter pulley, if you are trying to boost the alternator output at low rpm. An underdrive (larger diameter than stock) pulley slows the alternator down, which reduces its output capacity at a given rpm, relative to the stock diameter pulley.
Tim
Old Dec 15, 2000 | 08:15 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
You should start with the wire from the alt. to the battery. It should be 4 gauge at minimnum with a 140 amp alt.
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Trick Flow Heads, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Dynomax Cat-back, Serpentine belt setup, Dual IROC Fans.
http://www.sethirdgen.org/octride.htm
Old Dec 15, 2000 | 09:11 PM
necrophile's Avatar
ya know, it never dawned on me for the 4 guage, I remember when I switched the amp for my subs from 8-4 gauge it was a world of a difference, hopefully that'll do the trick.
Old Dec 16, 2000 | 01:32 AM
Black Beauty's Avatar
Car: 90 Camaro RS
Engine: 305 TBI
i heard that the b4c alts arent really 140 amp anyways. also what years were the b4c camaros made...im gonna try to look em up at work....auto part store....later
Rick
90 Camaro RS 305 TBI
400 small block, Hooker 1 3/4 LTs, Random Tech Cat, Hooker aero chamber cat back on the way!!
TH700-R4 with Trans-Go shift kit (corvette servo here...but not installed yet)
MacEwen Motorsports White Gauge Overlays
14" K&N X-Stream Open Element
GTS Headlight and Taillight covers
5% Limo Tint all around
Classic White Chevy Bowtie sticker on rear window
http://www.geocities.com/esvalenz
Man if my camaro were a rice-rocket all those mods would give me what...easily 50-60 hp!!!
"Just because I've done it, doesn't mean I knew what I was doing!" - Me
Old Dec 16, 2000 | 10:24 AM
necrophile's Avatar
well the alternator has 140 amps stamped on it. took some time to look at the alt on dad's 96 buick roadmaster wagon thats 140 amps. and I looked at the alternator on my 2000 tahoe (old body style) that one actually has a police package, its another 140 amp. then again even my tahoe with 18K miles has flickering lights if you blast the heat quick, or even crank the stereo up all the way. I think my camaro needs an optima battery at this point, its eating delcos.
Old Dec 16, 2000 | 09:47 PM
Car: 90 Camaro RS
Engine: 305 TBI
optima is the way to go...i have one....it has 3 year free replacement...where can i find one of these 140 amps...i work at a auto parts store so a car that comes stock with it would help. thanks
Rick
jbates346
Car Audio
25
Jun 10, 2020 08:27 PM
Vintageracer
Jan 10, 2020 05:33 PM
RedLeader289
Jan 22, 2016 03:05 PM
IROCZDAVE (88-L98)
Aug 24, 2015 06:54 AM
