Low Voltage
Old May 2, 2001 | 12:27 AM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
Low Voltage
Ok i just got a new alternator and battery 4 months ago i have a 140 AMP alt on it insted of the 105 AMP. I have a 91 V-6. basicly when im at stoplights my volts go down some turn on the blinker and wacth it go down to 12 volts and i thoguth my ams were drainign the poer so i trned everything off and it still went down low. Start to drive again volts go back up to 14. any ideas why my volts go soo low at idle?
Old May 10, 2001 | 12:06 PM
Ozzy88GTA's Avatar
Car: 1988 Trans Am GTA
Engine: 5.0 TPI
Transmission: TH700-R4
What are the engine RPMs? Also do you have underdrive pulleys, or is the cooling fan(s) running?
Reason why I ask about the underdrive crankshaft pulley is that it will lower the alternator RPMs. Engine should be idling at 550-900 RPM for auto tranny, anything lower than 500 will affect the alternator output.
Old May 10, 2001 | 01:23 PM
PhantomTPI's Avatar
Car: 1986 Pontiac Trans Am
Engine: 5.0 TPI
I have the same problem in my 86 TA...same symptoms....when stopped or idiling, the voltage is low..idle is about 1000 or just under...no underdrive pulleys...sometimes, cooling fans are on, but not always...its an atuo tranny. Same thing...slow blinkers, etc...and when i start to move again, the voltage goes back up and everything seems pretty much ok. I had replaced the battery, the plugs are bosch platinums, and a new distributor cap. The only other thing i can think of is the alternator...i havent looked at that yet. If anyone has any additional info/possible solutions, please post here.
1986 WS6-Equipped 5.0 TPI Trans Am
Random Tech High-Flow Cat
Two Chamber Flowmaster Muffler
Megs Custom 4.5" Stainless Steel Rolled Tips
1999 Grand Am GT In-Dash CD Player w/Equalizer(fits like '86 original)
5% Tint On Rear, 35% On Sides
http://www.pitt.edu/~zyhst/trans86/
OTHER RIDE:
1998 C5 6Spd. Corvette Coupe
Silver w/Gray Leather Int.
12/14 Options
Stock(for now)
Best 1/4th: 13.5 @ 104.4MPH
Old May 12, 2001 | 02:46 PM
FAST RS's Avatar
the engine RPMS are aroudn 750 but for some reaosn at ilde it surges a litle not bad tho. I have the Crank pully on the car but i took off the alternator pully.
Old Aug 31, 2003 | 03:00 AM
CamaroRS91x's Avatar
I have the EXACT same problem.....did you end up fixing it? and if so, how?
Old Aug 31, 2003 | 04:15 AM
FAST RS's Avatar
I think part of the problem is my under sized crank pully. I got a 140 amp alt and it died a few months ago so i went and just got a autozone one and havent had a ny problems but my voltage is still low at idle but with my system and everything elese runnig i havent had any problems. Just make sure you have a good battary i got a red top and havent had any problems. I just wish i could speed up my blinker i got a new relay for it but it still blinks once every 15 seconds. How do the ricers get there to blink soo fast? I figure if i pu tone of those in mine should blink like a normal car.
Old Sep 1, 2003 | 01:15 PM
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
are you running a 552 blinker? if not what number the lower the the number the quicker it will blink under the same load of a larger one.
thanks
anthony
Old Sep 1, 2003 | 03:55 PM
FAST RS's Avatar
im not sure what im running bt i know its what the compter called for at autozone so im sure its a OE number blinker.
327IROC85
Sep 23, 2015 12:11 AM
gta_knight
Sep 17, 2015 03:48 PM
ULTM8Z
Sep 16, 2015 09:15 AM
Formula_88AE
Sep 3, 2015 01:47 PM
RyanJB
Sep 2, 2015 01:27 PM
