Cant find the fuse for ..............
Old Jun 17, 2001 | 02:13 PM
BossHossZ-28's Avatar
my door locks, horn and lights dont work i think it is the fuse. Where the hell is the onther fuse block on a 1991 Z28 I know the one under the insturment panal but where is the one to contorl the locks, horn, and lights???? HELP PLESE
Old Jun 17, 2001 | 02:27 PM
Stuart Moss's Avatar
Accessory fuse.
EDIT: can't spell
[This message has been edited by Stuart Moss (edited June 17, 2001).]
Old Jun 17, 2001 | 02:28 PM
were is it located in the car Under the dash in the trunk????? I cant find it
Old Jun 17, 2001 | 02:33 PM
Guess I misread your original post.
There is only one fuse block, and I think you've found it. It is under the dash to the left and above the clutch (brake) pedal mounted directly below the instrument panel, above the hood release lever.
The only other fuse you'll find (at least from the factory) is the fuel pump fuse located next to the battery, but then that's not a fuse block, just the closest thing to one...
Old Jun 17, 2001 | 02:41 PM
I was looking in my chiltons and it gives another diagram of another fuse block with the horn relay, hazard flasher and other ones called HDLP HEadlamp?? maybe
THey call it the COnveniece center.
[This message has been edited by BossHossZ-28 (edited June 17, 2001).]
Old Jun 17, 2001 | 02:53 PM
I'm not sure what you're interperting as a "fuse block", but there is only one.
Anyway, I don't know what "HDLP HEadlamp" is, but the accessory fuse (labled "ACC") is a 20 ampere fuse located in the one and only fuse box located as posted above, and it indeed controls the horn.
Now the "convience center", located above the area near the accelerator pedal, does contain a relay that turns on the horn (among other things - key in/headlight alarm, flasher, etc.), but the fuse that provides power to this relay (and thus the horn) is the accessory fuse located in the fuse box. This is the same fuse that also powers the door locks, dome light, map lights, mirrors, cigarette lighter, and so forth. This convenience center has nothing to do with the door locks or dome/map lights.
Since the accessory fuse is common to all of the items that are not working, it's probably the fuse, not the convenience center (unless the convenience center is causing the fuse to blow...).
When you removed this fuse, was it blown?
Old Jun 17, 2001 | 03:07 PM
Yes it was blown. all better now got a horn power locks and dome lights again. Thanks alot for your help.
Old Jun 17, 2001 | 11:58 PM
RARE-ROC-Z's Avatar
hey boss make sure your cigarette lighter isnt blowing that fuse. or you will have to take it out or change the holder.
it did that in my car and i hated it. i took the lighter out and now i am working on putting a fuel pressure gauge there or something.
Jarrad
1990 IROC-Z L98 350 TPI
TH-700R4
G92- 9 Bolt Borg-Warner 3.27gears
Bright Red Hardtop/ Grey "Custom" Interior
NOT STOCK, NO WHERE CLOSE!
NEW RED PAINT and WELD PROSTARS.
DAILY DRIVER: 1991 GREY S10 2.5L/5SPD -FOR SALE. leaving for army.
64goatman
Sep 9, 2015 01:09 PM
IROCZ1989
Sep 4, 2015 11:54 AM
85Special
Sep 3, 2015 04:21 PM
90formulaVortec
Sep 3, 2015 09:26 AM
