Ignition Conrtol Module Probs. w/n
Car: 89 Trans Am GTA
Engine: 383 TPI
Axle/Gears: 3:27
Ive been going thru them about every month and a half. Im on my third on now, what could be frying them?
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Are you putting the grease on it when you install? Its very important to keep the module from overheating.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.23 @ 107.62 MPH
Southern California
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
I've had similar problems with ignition modules before. I thought mine were going bad but they really weren't. Everytime I changed it the car would start again. It ended up being one of the connections to the module. You might want to try cleaning all of the connectors and checking the wires.
best 1/4 mile so far: 13.4 @ 101mph
84 Camaro 305 ported & milled heads, 3 angle valve job, Edelbrock Performer RPM intake, Hedman full length headers, Accell ignition, Crane 274H cam, B&M 700R-4, 3000 stall speed, 4.10 gear,
M/T ET street tires
visit my website at http://www.geocities.com/jbenge/page1.html
M/T ET street tires
just changed my pick up coil. you might look at that it is cheap and they usually wear out over the years. Mine was so corroded the connecter from it to the module turned from plastic to goo, and the wires were cracked. My car was running very bad then I put a new pick up coil in and it runs like its new again. maybe thats shorting out you module. When oyur in the dist. that far clean all the contacs real well , they will be a little rusty.
Car: 1992 Camaro RS & 1992 Camaro RS
Engine: 3.1 L v6 & 305 (5.0L) v8
Transmission: 4L60 Auto
It's the pick up coil going to ground that frys the module. If it's not the pick up coil then you have another short in the main ignition coil or wire leading to it.
Did you change the spark plugs just before the control module started frying on you? It is possible that if a plug is not seated correctly the control module could burn out. That is my experience with some older GM electronic ignitions (70's and some early 80's), but may not apply to your situation. Figured I'd mention it just in case.
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
