Turn Signals.......
Old Jul 27, 2001 | 06:22 AM
CloudIROCZ28's Avatar
Turn Signals.......
I'm having a problem with my left turn signal in the front fascia of the car ..... it sporatically does'nt work, and in the dash the left turn signal will light green without clicking it...... is there any other way to fix this...I changed the bulb and everything... these lights are the biggest pain in the A** in my car.....Should I just goto the junk yard and look for just maybe the front socket there and cut and splice a new one in or is there somethin else I'm missin??
1987 IROC-Z
G92, LB9 305 TPI, 3.23, Bright Red with Carmine Interior, Pioneer DEHP47DH CD deck.2 JBL DS645 4*6 (F).. 2 JBL DS965 6*9 (S).. Soon to get new 305 TPI
Old Jul 27, 2001 | 03:42 PM
Jza's Avatar
Jza
Check the flasher relay.
Old Jul 27, 2001 | 08:26 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
If the right side works fine, then the relay is not at fault. It could be as simple as a broken wire in (or to) the socket or a bad ground connection; maybe even corrosion in the socket.
Pete
Pete's Place
HiOutput Tech Page
83 SC
originally a V6...now
210+k mile LG4/5-speed
14.891@95.54
My karma ran over my dogma
Old Jul 27, 2001 | 08:28 PM
camaro chick's Avatar
Like Pete said-check your wires!
Old Jul 28, 2001 | 06:22 PM
hummmmm maybe i'll goto the junk yard sometime rip it offa f-body ....i have a questtion could i rip one off of a newer f-body 93-01
1987 IROC-Z
Old Aug 5, 2001 | 12:13 PM
Flash84Z28's Avatar
Car: '03 S-10/ '87 Trans Am
Engine: mild 350
Transmission: TH350
Hey make sure that all the copper elements are still in tact inside the socket. I had a similar problem when my light stopped working.
Matt
Matt
1984 Camaro Z28
-'78 350 with Edelbrock 650 Carb, Edelbrock Preformer RPM Air gap intake, ACCEL plugs & wires, 14" K&N filter.
-TH350 with Hurst Pro-matic shifter & B&M Street shift kit.
-Audiobahn single 12" Sub powered by Sony Xplode amp, Farenheit 6x9" & 4x6" speakers, with a Sony Xplode headunit.
Old Aug 10, 2001 | 06:31 PM
hey what is the GM number for the Sockets for the front Turn Signals ??? I'm just gonna buy new ones for both Front and maybe I could get the new Sockets for the new Camaros??? Will the new Camaro Sockets Work???
1987 IROC-Z
Old Aug 10, 2001 | 07:09 PM
what's is the GM numbers for the sockets in an 87 IROC-Z will newer ones work from maybe an 4th gen and what are there numbers
1987 IROC-Z
Old Aug 16, 2001 | 06:28 PM
nj88v6's Avatar
I actually had a similar problem. Only one side was effected however after time, it seemed to spread to both sides. What was happening to me was that the signal flasher relay was blowing almost every month. I simply got one that was rated "heavy-duty" and the problem has not happened since.
gta892000
Aug 11, 2019 11:16 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
bbsr72
Sep 27, 2015 05:55 AM
greenyone
Sep 8, 2015 08:41 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
