Can I swap no delay wipers for intermiten?
Old Aug 18, 2001 | 10:33 PM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
Here's the deal. I can swap into my car an entire tilt steering column with the leather Camaro wheel for a standard column? The problem is currently in the car are regular wipers and the tilt column has intermitent. Is there a difference in the wiring? What needs to be rewired and does anyone have a diagram on them? Do I need to change the wiper motor also?
86 Camaro Black SS Coupe, T Tops, Flowmaster, Custom Paint, Dunlop Road Kings S/R tires, Wheel Country Directional Chrome Wheels,new charcoal & gray interior including seats and door panels, new carpet and headliner, complete front end suspension rebuild, new Valve seals, and more mods to come
http://www.angelfire.com/sports/niterider/86camaro.html
Morgan_Andre@hotmail.com
Old Aug 22, 2001 | 08:33 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
You'll need to swap in an intermittent motor as well; it'll just plug in and go. Your existing motor will work the same, except for it won't have the delay feature. No wiring changes need to be made (unless the column is from an 82 or 83 F-body).
Pete
Pete's Place
HiOutput Tech Page
83 SC
originally a V6...now
210+k mile LG4/5-speed
14.891@95.54
My karma ran over my dogma
Old Aug 25, 2001 | 01:21 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
It depends on the years of the column. I changed over from reg to intermitant. I had to get a new turn sig lever and a new switch inside the column. Also, I did not have to change wiper motors. Only the wiper motor's black plastic cap has to be changed. If it's an 86, I can give you the GM part number if you want it.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 5/30/01)
There can be only one!!
[This message has been edited by Justins86bird (edited August 24, 2001).]
Old May 16, 2003 | 02:30 PM
bubbakutz's Avatar
Car: 1987 "1991 Z" Sport Coupe
Engine: LG4
Transmission: TH700R4
back from the dead
my 87 sc has only low and high and i hate it to hell......
justin i think u did what i want to do.....could u tell me a little more about it? all i need to do is find the parts from the scrap yard? thank you
Old May 16, 2003 | 06:51 PM
jwattsjr's Avatar
Car: 84 & 86 T/A
Engine: LT-1 & 5.7L
Transmission: 700R4's
Justin,
I'm looking to make the same swap on my 86. I could use that p/n.
Thanks,
Jeff
Old May 16, 2003 | 08:05 PM
There are 2 parts required for the swap: the wiper motor cover and the wiper switch. The turn signal stalk should work but it just wont have the markings for the int wiper settings.
I'll look up the p/ns for you guys and post back later.
Old May 16, 2003 | 08:20 PM
jwattsjr's Avatar
Car: 84 & 86 T/A
Engine: LT-1 & 5.7L
Thanks. I've already got a new turn signal stalk w/the int wiper settings.
I just need the switch and cap.
-Jeff
Old May 16, 2003 | 09:22 PM
bubbakutz's Avatar
Engine: LG4
by wiper switch, do u mean the thing u turn to turn them on...like mine is low and high?
Old May 16, 2003 | 09:33 PM
jwattsjr's Avatar
Car: 84 & 86 T/A
Engine: LT-1 & 5.7L
The thing you turn to turn them on is what we're calling the stalk.
The actual switch is in the steering coulmn, and is one of the items
that must be replaced. Justin's saying you should be able to keep
your Hi/Lo stalk.
Or, to put it another way: You'll have to replace your wiper switch
but not your turn signal/wiper/cruise lever.
-Jeff
Old May 16, 2003 | 09:39 PM
bubbakutz's Avatar
Engine: LG4
ohhh.....thanks for clearing it up.......how hard is it to do this swap?
Old May 16, 2003 | 09:55 PM
jwattsjr's Avatar
Car: 84 & 86 T/A
Engine: LT-1 & 5.7L
The column shouldn't be hard at all. The switch shoould be just a
few layers down. I dunno about the wiper motor, though.
-Jeff
Old May 16, 2003 | 11:26 PM
-Jeff
The switch is inder the turn signal stuff in the column and is held in by a pin. The motor doesn't have to be changed, just the black cover held on by 3 screws.
Old May 16, 2003 | 11:28 PM
bubbakutz's Avatar
Engine: LG4
one last thing.....would a haynes manual help me through this step by step?
Old May 17, 2003 | 12:17 AM
A manual may help, but it's not really hard to do. Just pull the wheel and remove some screws and you get down to the switch
Heres the p/n's and group numbers for cars with cruise and tilt.
pulse wipers RPO CD4
84-86 pulse wiper cover kit - grp 10.150 - p/n 22039684
84-89 cruise/tilt/pulse/turn sig lever - grp 2.897- p/n 25111262
84-86 pulse wiper switch w/ tilt - grp 2.459 - p/n 7843683
Old May 17, 2003 | 07:48 AM
jwattsjr's Avatar
Car: 84 & 86 T/A
Engine: LT-1 & 5.7L
Thanks, Justin.
Old May 17, 2003 | 12:16 PM
bubbakutz's Avatar
Engine: LG4
ok, thanks
Frozer!!!
Jan 19, 2024 04:55 PM
db057
Sep 4, 2015 07:57 AM
siberian3rdgen
Interior Parts Wanted
Aug 31, 2015 09:37 PM
Randomtask2
Aug 26, 2015 03:34 PM
slade5612
Aug 11, 2015 07:19 PM
