VAT Bypass
Old Sep 23, 2001 | 12:59 PM
todd56's Avatar
VAT Bypass
OK, I've purchased the multimeter and a pack of resistors and measured the resistance of my key (3.72). I can't find the "yellow wires and connector" coming out of the steering column. The directions sound easy enough on the "VATS Malfunction Diagnosis and Bypass" tech article, but I'm stumped. Could someone please help me locate these yellow wires? Are they a separate pair or are they together with several others leading to a larger, flat connector? Thanks.
91 Z28 convertible, 305 TPI.
Old Sep 23, 2001 | 10:15 PM
bad@ss89camaro's Avatar
Car: 91 Z/28 convertible
hey man what did you set your meter at to find the resistance
92 25th annv. camaro
midnight black
stock 305 tbi
t-tops
89 camaro
carburated 305
bored .030 over
flat top pistons
bigger valves
heads and block shaved
spoiler
tinted windowshuge white chevy symbol on back
92 stock rims
92 ground effects
www.geocities.com/thirdgenerationcamaro
Old Sep 24, 2001 | 04:36 PM
mat89RS's Avatar
I had the same resistence with my old 305 .... I did the thing with the resistence, it worked like a charme and 3.72 is the correct value ... it's 3720 ohms ... i think , can't remember exactly, I did it with my LT1 also witch had a value not listed in the 15 normal values.
LT1 POWERED
HEADMANS HEADERS
NEARLY 300 HP.
EATS MUSTANGS FOR BREAKFAST
next mods:
crane roller rockers 1.6
lt4 hotcam kit
airfoil
58MM edelbrock trottle body
new paint (wet look blue)
17' rims with 275 zr 40 and 245 zr40
Old Sep 25, 2001 | 11:41 PM
90blueRS's Avatar
ok .. i just did this with my 90 rs... it should be the same... you will be better off lookin for two 24 gage wires... one is purlple/white one is white/blk. to find it start at the base of the steering column. they should be right there... (they may be in a Larger yellow gage wire.. but if your careful and strip that back you will see them. But mine were right there. let me know if you have any other ?'s
john
Old Mar 7, 2010 | 10:12 PM
LS1Camcam's Avatar
Re: VAT Bypass
http://www.youtube.com/watch?v=AKfn7J9CeZM&feature=fvw breaks it down easy
Old Mar 8, 2010 | 02:28 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
Re: VAT Bypass
Originally Posted by todd56
OK, I've purchased the multimeter and a pack of resistors and measured the resistance of my key... I can't find the "yellow wires and connector" coming out of the steering column. Could someone please help me locate these yellow wires? Are they a separate pair or are they together with several others leading to a larger, flat connector?
You probably won't find yellow wires. I've only heard of one case where they were yellow, though there might be others. Try looking for 2 white wires, and they'll be inside an orange sleeve(the orange sleeve being what you'll see coming out of the steering column). And the white wires go into a small black connector around the top of the brake pedal area. There are some good pics in the thread linked below:
https://www.thirdgen.org/forums/elec...plain-why.html
As for your resistance value, do you think publishing your security system's value on a world wide forum is a good idea? You might consider editing that out.
Old Mar 8, 2010 | 03:06 PM
Mgb86's Avatar
Car: 89 Camaro RS
Engine: Carb'd 350
Axle/Gears: 3.70
Re: VAT Bypass
If he is bypassing the system what does it matter if the resistance is posted in the thread?
Old Mar 8, 2010 | 06:29 PM
LAFireboyd's Avatar
Re: VAT Bypass
It was just a suggestion. You never know what the future has instore. He(or a future owner of that car) might someday undo the bypass. And suppose someone in Florida who knew that car learned of the resistance value. Car thieves are good enough already, no need to hand them the "keys" to your car by allowing them access to your security system.
Old Mar 8, 2010 | 06:53 PM
Mgb86's Avatar
Car: 89 Camaro RS
Engine: Carb'd 350
Axle/Gears: 3.70
Re: VAT Bypass
Good point
$750 L98
Feb 1, 2025 02:25 PM
RS Reaper
Oct 17, 2018 07:52 PM
djmarch
May 8, 2016 11:32 AM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
Racerx974
Sep 19, 2015 10:16 AM
