blowing wiper fuses?
Old Apr 10, 2004 | 10:20 PM
grndmasnightmar
Guest
Posts: n/a
i was driven in the rain when my wipers just quit. it ended up being a fuse but everytime i put a new one in it blows immediately when i turn the key. is there anything else on this circut and what the heck would make this happen...anyone. Thankyou
Old Apr 11, 2004 | 03:38 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Check this schematic out and see if it helps.
Whoops!!!! Sorry dude, wrong picture.
Here is the right one and no, there does not appear to be anything else in the circuit that could cause the problem.
Old Apr 12, 2004 | 06:05 PM
grndmasnightmar
Guest
Posts: n/a
wheres the wipers on that diagram.. anyway are u also saying its definetly wires grounding or something?? i need a starting point or a usual point of failure in these things???
Old Apr 12, 2004 | 06:55 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Sorry Dude,
I put the wrong picture in there the first time. I have corrected that and marked the wiper switch and motor.
Old Apr 13, 2004 | 06:37 PM
grndmasnightmar
Guest
Posts: n/a
i messed with all the exterior wires and i put a fuse in and the wipers worked but later the fuse blew again whats my next step to fixing this problem, how can i check for bad wires and where do he wires go through the firewall for the wiper switch????
Old Apr 13, 2004 | 08:00 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I have some more schematics that give a more concise view of the wiring. I have one question, are your wipers pulse or standard?
Old Apr 14, 2004 | 11:27 PM
AlbertaFbody's Avatar
Car: 86 z28
Engine: 305 carbed with 3" Y pipe back
Transmission: 700r4 that is breaking down
here is the prob i am almost sure of it if you can't find a dead short then you have a short in the motor itself i know it sounds strange but happends all the time both my other cars had the problem. the only way to fix it is to buy a new motor now keep in mind the fuse is good till you hit the wipers then snap there she blows
Old Apr 17, 2004 | 09:45 PM
grndmasnightmar
Guest
Posts: n/a
update..
well i fixed the problem and i thought i should let you guys know...it was a dead short. when i had everthing in the engine compartment detached from the wiper motor i said what the heck let me see if its still going to blow a fuse so i put one in and it blew right when i turned the car key. this led me to assume the short must be under the dash so i dropped the fuse box to chase the wires and i put another fuse in when the box was down and i saw i spark near the kickpanel, well i looked to the left of the fuse box by the door and there was a large bunch of wires leading to i guess the steering column and what not and it was resting on a metal lip of the body and after 15 yrs it finaaly rubbed through and cut the elctric tape and insulation to a green wire which was causing my grounding out repaired the wire and put rubber over the metal and presto. 10.00 bucks on fuses later my wipers work again. i posted this so anyone who ever has a short like this can look to the same place where gm decided to butt 20 wires up against a metal lip causing a rub through......:lala:
3rd gen money
Oct 11, 2019 09:57 PM
Hal87
Exterior Parts Wanted
Nov 8, 2015 03:40 PM
thunder57
Nov 7, 2015 02:28 PM
Fanatic1074
Oct 2, 2015 03:47 PM
Hal87
Sep 26, 2015 09:26 PM
