Gauge problem
Old Apr 23, 2004 | 08:25 PM
stevecvash's Avatar
Car: 85' Camaro Sport Coupe
Engine: 1970 LT1
Transmission: 700-R4
Axle/Gears: 3.23 Posi
Gauge problem
I bought a iroc full gauge, gauge cluster to go in my SC, I followed the tech article about swapping them, then I got out the old cluster and when i went to put the iroc one in and i turned it over the, the oil pressure and tach didn't want to work
please help me, thanks
Old Apr 23, 2004 | 09:13 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Couple of questions here, what year iroc did the cluster come out of. Did you replace the oil pressure sending unit like the article said, did you check the Printed Circuit Board (PCB) Tape on the back of the cluster for any tears. Did you check the wiring for the tach?
Old Apr 23, 2004 | 10:13 PM
stevecvash's Avatar
Engine: 1970 LT1
the iroc was an 87, and i did replace the oil pressure sending unit, and there are no tears, and the white wire is plugged up for the tach
Old Apr 24, 2004 | 12:19 AM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Since they are both on the same unit, I'd suspect a bad power feed or ground connection.
Old Apr 24, 2004 | 03:37 PM
stevecvash's Avatar
Engine: 1970 LT1
i got the oil pressure to work properly(it wasn't plugged up )
but the tach still dont work right, but it is getting power b/c when i go to start it it moves and when i start the car it jumps to 7 grand and stays there
Old Apr 24, 2004 | 04:03 PM
StealthElephant's Avatar
Car: 87' Iroc
So it sits at 0, and when you put the key in the "ready" position it jumps to 7000?
My tach was being stupid, it would sit at 6500 with the key out, and when the key was put in "ready" it would go to 7000.
As per someones advice, I pulled my gauge faceplates off, used my finger to turn the tach needle to 0, start the car, and the tach worked. Not sure if this is the same thing.
Old Apr 24, 2004 | 04:32 PM
stevecvash's Avatar
Engine: 1970 LT1
this is whats happening #1.....
Old Apr 24, 2004 | 04:40 PM
stevecvash's Avatar
Engine: 1970 LT1
forgot the pic
Old Apr 24, 2004 | 04:43 PM
stevecvash's Avatar
Engine: 1970 LT1
the engine is starting to turn over
Old Apr 24, 2004 | 04:46 PM
stevecvash's Avatar
Engine: 1970 LT1
justed started and running in the last one
Old Apr 25, 2004 | 09:19 PM
ss85tadude's Avatar
Car: 85 Trans Am
lol Why are your pics triple like that?
Yeah you probably have a wiring problem somewhere.
Ghettobird52
Jul 5, 2024 11:18 PM
rocn7roc
Sep 21, 2021 02:16 PM
Infested
May 22, 2018 11:56 PM
db057
Sep 4, 2015 07:57 AM
justin57
Aug 20, 2015 07:05 PM
