VATS problem???????
Old Apr 24, 2004 | 04:28 PM
Slowmaro91RS's Avatar
Car: 91 Camaro RS
Axle/Gears: 10 bolt posi/3.23
VATS problem???????
I have a 91 RS that's becoming useless to me. For the past 2 days it went into security mode when I tried to start it. I got it working again both times but I'm really getting sick of it. Any ideas on what is causing it or how to fix it? Thanks for any imput.
Old Apr 24, 2004 | 08:14 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It is probably a broken wire inside the steering column that goes to the lock cylinder. USe a multimeter to measure the resistance value of the pellet, then put the key in the lock cylinder and disconnect the wire harness coming from the steering column to a two wire (black/white & purple /yellow)connector. Again measure the resistance value the wire connector at the steering column. If the value is different, your problem is either a broken wire, bad contacts in the lock cylinder or worn contacts on the key. If the value is the same, your problem is elsewhere in the circuit.
Old Apr 24, 2004 | 08:59 PM
Car: 91 Camaro RS
I don't think that's the problem. My security light doesn't stay on. The ignition enable relay looks fine too so I'm thinking it might be something else. Any ideas?????
Old Apr 24, 2004 | 09:51 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hello Slow,
I got your PM a little bit ago an I seem to remember you had another post recently but, I couldn't find it. I have some schematics that I will post here for you to browse over. In the meantime, e-mail me with the specifics of your problem.
Old Apr 24, 2004 | 09:59 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
schematics
Here are the schematics I mentioned in my last post.
Old Apr 24, 2004 | 10:00 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
page 2
Old Apr 24, 2004 | 10:01 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
page 3
Old Apr 24, 2004 | 10:02 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
page 4
Old Apr 24, 2004 | 10:07 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
page 5
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
greenyone
Sep 2, 2015 03:39 PM
