vss?
Old Jun 6, 2004 | 04:12 PM
GreyFox's Avatar
Car: 1991 Firebird
Engine: V6
Transmission: ATOD
vss?
are there any consequences for driving with a disconnected vss?
Old Jun 6, 2004 | 08:19 PM
S10Wildside's Avatar
Transmission won't know when to lock up the converter. I have heard that this can ruin a transmission. I have no personal experience to prove it though. Shift points will not be affected b/c it has nothing to do with a speed signal.
The ECM requires the speed signal for some other functionalities, too.
Old Jun 7, 2004 | 11:46 AM
VetNutJim's Avatar
Car: Different One Every Day
Engine: LS1,LS6,L98,L83
Transmission: 700R4, 4060E,Turbo 350, Turbo 400
I'm running TPI on my 73 Chevy Truck.
No VSS.
Runs VERY well.
I've run my 84 Vette 5 years with no TCC lockup.
It shifts MUCH better without lockup.
TCC IS RECCOMENDED, however.
YMMV.
Old Jun 7, 2004 | 12:15 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hey VetNutJim,
Does your vette & truck have a manual or automatic transmission?
Old Jun 8, 2004 | 06:39 PM
GreyFox's Avatar
Car: 1991 Firebird
Engine: V6
Transmission: ATOD
why exactly is it recomemded, better mileage? because if you don't need it and it wont burn out my trans then i'm just gonna kill it
Old Jun 8, 2004 | 08:53 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Kind of vague but, on some applications, the VSS input affects TCL (as said), IAC and ignition timing.
Generally, unplugging the vss will also cause the SES lamp to come on (ECM is 'seeing' a problem).
As far a the converter locking up.. it's mileage mainly and a little of helpiing keep the trans cooler since the converter doesn't slip when locked. Burning up the trans... doubtful.. the converter will not lockup anyways untill: a certain operating temp., unter WOT, or below 32mph (or close to that speed).
As far as running fine w/o... sure but, you can also unplug just about all sensors and the engine will still run (not well but,...), doesn't mean it's running as it should.
Old Jun 9, 2004 | 08:32 AM
GreyFox's Avatar
Car: 1991 Firebird
Engine: V6
Transmission: ATOD
i don't believe it affects ign timing maybe i outa just live with it until i can fix it fully
Old Jun 9, 2004 | 09:20 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
you have a electric speedo.. so your speedo wont work.
as mentioned you dont get torque converter lockup
and you will never see "highway mode" to save gas.
but the car will run fine... on a long hwy trip however, the trans will run hotter...
Old Jun 9, 2004 | 09:49 AM
GreyFox's Avatar
Car: 1991 Firebird
Engine: V6
Transmission: ATOD
what is considered a highway trip because i run for work about 26 to one store and if i have to go out to the other one its 50 mi, and after i disconnected it my spedo still worked
Old Jun 9, 2004 | 10:03 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
you unplugged the plug from the trans that looks like this one?
or did you unplug the other one?
why the heck do you want to drive without it connected anyway?
Old Jun 10, 2004 | 01:45 PM
GreyFox's Avatar
Car: 1991 Firebird
Engine: V6
Transmission: ATOD
i unhooked that one in the pic, becase there is something wrong with the system, irratic engine speed while driving, it would constantly lock and unlock while at any speed sustaind, accelrating or slowing, unhooked it for diagnose and it was that, now i have to trace out which component it is, hopefully its the TPS, is that a common part to go out on that system??
Old Jun 10, 2004 | 01:46 PM
GreyFox's Avatar
Car: 1991 Firebird
Engine: V6
Transmission: ATOD
well i believe it was that one, as long as that plug has the four wires on it which i believe it does
Old Jun 10, 2004 | 01:49 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
nope.
it has two.
the 4 wire connector is on the front of the trans and is the power for the TCC lockup.
the pic i showed is the VSS. its two wires... yellow and red.
Old Jun 10, 2004 | 05:32 PM
GreyFox's Avatar
Car: 1991 Firebird
Engine: V6
Transmission: ATOD
ohh ok casue the four wire one is what i disconnected and then my problem went away, either way from my understanding they work together in the tcc lock up along with the TPS and i believe in that group is where my problem is
Old Jun 10, 2004 | 05:38 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
What you disconnected was the wires for the TCC solenoid.
Old Jun 10, 2004 | 10:04 PM
GreyFox's Avatar
Car: 1991 Firebird
Engine: V6
Transmission: ATOD
yep, and it solved my problem with irratic engine speed, however i read it was bad to do so, so now i have to find the cause of the problem, don't worry i did disconnect it
$750 L98
Feb 1, 2025 02:25 PM
GTAman
Jul 3, 2024 07:29 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
